Old 15th May 2005, 11:20   #31
c10
c10's Avatar
Exclamation
Originally Posted by Sahil
Dude when the roads r bad the car shocks r going up and down...not left and right! unless u r being banged from the left and from the right constantly in ur driving condition!
So you mean cars dont tilt either to left or right?????
Ok....
c10 is offline   Reply With Quote
Old 15th May 2005, 11:32   #32
kooldude's Avatar
hey guys i m not a car expert that i can know everything anyways i have come to know that button is choke. anyways guys why are you getting so worked up you could have just told me the correct thing.
kooldude is offline   Reply With Quote
Old 15th May 2005, 11:34   #33
Sahil's Avatar
Thanked: 2,712 Times
Dude what r u talkin abt man? u r car tilts from left to right...what r u driving a car on hydraulix?
The car does bend to the side when cornering but thats different... pushing the chasis constantly is more hard than it curving on the bend.
Old 15th May 2005, 11:40   #34
c10
c10's Avatar
Exclamation
I meant this....The car bends to the side when cornering...
Old 15th May 2005, 11:50   #35
turbo_lover's Avatar
okie the Z button might be the choke button incase kooldude your druve a carv esteem...
otherwise check for NOS in the boot..
turbo_lover is offline   Reply With Quote
Old 15th May 2005, 11:57   #36
kooldude's Avatar
Ha ha ha turbo but actually that Z button is a actually a knob not a button sorry for my mistake again
Old 15th May 2005, 12:21   #37
speedsatya's Avatar
Thanked: 712 Times
hahaha,
no one is getting worked up on you.
hahahhaha.
thats why, avoid driving before you get your licence.
speedsatya is offline   Reply With Quote
Old 15th May 2005, 12:24   #38
kooldude's Avatar
Originally Posted by speedsatya
hahaha,
hahahhaha.
hey satya
have stopped driving specially out of my sector. just drive 1 or 2 kms that too in cbd and that too once in 2 or 3 days now i m eagerly waiting to get 18 then i will get my licence
Old 15th May 2005, 14:41   #39
Deeps's Avatar
Thanked: 68 Times
Actually, when you do the shaking thing, one side of the shocks is going down the other is going up. I imagine this wouldn't really contribute much to the suspension/chassis wear.
Deeps is offline   Reply With Quote
Old 15th May 2005, 14:42   #40
Deeps's Avatar
Thanked: 68 Times
The how DID you manage to activate reserve with the choke button?
Old 15th May 2005, 15:06   #41
kooldude's Avatar
no i didnt activate it i just pulled it so the car turned on. it helped in starting the car not activating the reserve
Old 15th May 2005, 16:15   #42
yah because a choke increases the flow of fuel ...
has nothing to do with reserves...
anyway i think kooldude has understood how it all works ...
lets just leave it to that..
Old 15th May 2005, 21:33   #43
Montoya's Avatar
THis thread is going really funny.. haha..
I guess he pulled the choke so the car took in more fuel and this explains the concept of 2kms per 5 liter of fuel.. lol.. anywayz coming back to the topic.. whole cornering you wont affect you suspension but your shocks and tyres wear out due to excessive cornering.
Montoya is offline   Reply With Quote
Old 17th June 2005, 16:33   #44
Originally Posted by Deeps
I agree turbo lover. I have not heard of any car in which one is required to activate the reserve part of the fuel tank manually.
Was going through the archives. Sorry to rake this thread up but the Standard Herald actually did have a lever that allowed you to switch between the main and reserve fuel tanks. The lever could be operated from inside the boot.
hrag
hrag is offline   (1) Thanks Reply With Quote
Old 24th August 2007, 19:30   #45
Default Monitoring car FE simple way
We can monitor the car FE on the basis of ODO Reading at 50% level and maintaining the fuel level around the 50% level(eg: 30%to60%)
A)Record the ODO Reading when fuel gauge reading is exactly at the 50% mark.
B)When the fuel level is well below the 50% level the tank, refill to get fuel level well above the 50% mark.Record the filled quantity.
C)Record the ODO Reading again when the fuel gauge is at 50% mark.
We can compute the FE = (Difference in ODO Reading)/ Fuel quantity.
Continue recording ODO Reading and fuel filled alternatively. FE after each fill can be calculated for monitoring purpose.
For better accuracy,first and last ODO readings and cumulative fuel filled over a period (say a month) can be taken for calculation.
ODO Readings are to taken when the car is on levl road.
vinsen is offline   Reply With Quote
Fuel tank capacity measurement, how? giri Technical Stuff 79 26th June 2018 15:17
Just a thought - Units of measurement jat Technical Stuff 40 14th October 2013 18:11
Measurement of in-cab noise FourWheelDrift The Indian Car Scene 0 20th August 2010 23:36
Measurement of MM540 AlfaRomeo 4x4 Technical 2 5th August 2009 10:55
Velocity measurement kit khajam Technical Stuff 6 23rd July 2008 09:32
