| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #46 (permalink) |
| Senior - BHPian Join Date: Dec 2007 Location: Bangalore
| One question. The milage can be calculated only when we keep filling the tank full for every fill right? What if we fill say 500rs in between and then tank full sometimes? In this case, how should we calculate the milage? Any idea?
__________________ Sometimes I Win; Other times I Learn, I NEVER loose. --- Aveo 1.4 LS Special Edition Honda Activa Zen LXi, RX100, RX135 (Sold) |
| | #47 (permalink) |
| BHPian | okay: Lets say you filled for 500rs so 10 liters (assumption). Note: I am assuming you did tank full till this 500 rs refill and you had set your trip meter to 0 or noted down kms travelled in your Odo 1. Fill for 500rs (10 litres), dont reset you trip meter to 000 2. Drive till you have a need to fill 3. Now fill tank full. 4. Make a note of Petrol filled (assume 20 ltrs) 5. Note the total distance traveled in the trip meter Now calculation. Lets assume you have travelled 350 kms from you last full tank Total distance travelled = 350 KMS Total Petrol Filled = 10 (500 rs) + 20 Ltrs = 30 Ltrs Total Mileage = 350 / 30 = 11.6 kmpl This is what I do. |
| | #48 (permalink) | |
| Quote:
__________________ Sometimes I Win; Other times I Learn, I NEVER loose. --- Aveo 1.4 LS Special Edition Honda Activa Zen LXi, RX100, RX135 (Sold) | |
| | #50 (permalink) |
| Senior - BHPian | Calculating FE is very simple, Best way is use same bunk which you trust most. First time do tank full I mean really tankfull by shaking the car as well. Also make sure you have started from ZERO in Bunk reading because If they had filled 2 ltrs Petrol for bike they would not reset it for cars since at least 10ltrs petrol car owner will fill. so chances to cheat him is easy. First fill full tank and drive for 50kms and then do full again and drive for 50km. Repeat the same thing 2 or 3 times. During every fill note down kilometers travelled and quantity of fuel filled. Take average of all those 4 or 5 times you filled the tank. I do the samething when I calculate FE for my cars. After I stopped using Shell from last 3 months FE has come down by 1.5km :( which indicates either quantity or quality is missing. Regards, Ravi. |
| | #51 (permalink) |
| Newbie Join Date: May 2007 Location: Navi Mumbai
| Hey guys, I don't understand the need to shake your car for full tank filling. It's simply hilarious! Fuel being a liquid always gets emptied (consumed) from higher level to lower level in the tank. So whenever you are going to top up the level, it is only the top empty space of the tank that gets filled up and, being a liquid, automatically takes the shape of the container. Remember the science funda we were taught in class 3 or 4 in school? It still holds true! Getting out trapped air could be true only when the tank is completely empty right upto the fuel pump inlet, and there is air trapped in the fuel lines. Anyways, coming back to the point, to ensure same level of "tank full", I always go to the same fuel station and try to refill from the same pump, same nozzle, using auto cut-off method. And best is to maintain a log of all refills, and then calculate FE over a few thousand kms. This averages out the -ve and +ve errors to almost zero. And I do get 16.3kmpl in my Wagon R.
__________________ A fine is a tax for doing wrong. A tax is a fine for doing fine. |
| Thread Tools | |
Similar Threads | ||||
| Velocity measurement kit | khajam | Technical Stuff | 6 | 23rd July 2008 09:32 |
| Whats is the accurate method of measuring FE | Anju | Technical Stuff | 9 | 10th December 2007 15:52 |
| Practical VFM - i10 / Swift / Logan | ashishpodar | Hatchbacks | 17 | 20th November 2007 21:10 |
| Fuel tank capacity measurement, how? | giri | Technical Stuff | 36 | 5th September 2007 19:08 |
| Just a thought - Units of measurement | jat | Technical Stuff | 8 | 15th February 2006 01:44 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
