Old 26th March 2009, 11:27   #16
ImmortalZ's Avatar
Thanked: 312 Times
With the Civic, the problem is that if you leave the handbrake on overnight, the parking brake shoes get stuck and you get a noise as they release themselves. This happens especially if you have come in after a spirited drive and the assembly is really hot when you put the parking brakes on. They "cook" and get themselves stuck bad.
Old 26th March 2009, 12:35   #17
reignofchaos's Avatar
Thanked: 1,304 Times
Why did it happen in the first place? Did they tell you why?
The car wasn't used for a week as I was hospitalized. During that period the car was washed everyday by my watchman. Seemingly this standing water inside the brake caused the jam. I've instructed the watchman to be a bit more careful when washing the wheels from now on.
Old 26th March 2009, 13:50   #18
suman's Avatar
Thanked: 257 Times
Oh yes, a standard feature for all car cleaners - splashing water liberally on the wheels
Old 26th March 2009, 14:48   #19
thedreamcatcher's Avatar
Thanked: 62 Times
I would suggest you get it checked out. The brakes should not stick like that. It may cause wear and tear. Diagnose why it happened in the first place
thedreamcatcher is offline   Reply With Quote
Old 26th March 2009, 16:14   #20
ImmortalZ's Avatar
Thanked: 312 Times
Parking brakes will stick when kept active for long periods of time.
Grinding noise coming from the front brakes of Swift Vxi when rolling back vivekchugh Technical Stuff 10 9th October 2015 21:06
Ford Ikon Flair Making loud Noise (Fan/Engine). snaronikar Technical Stuff 15 10th February 2015 23:31
Grinding noise from rear wheels Hashim Technical Stuff 0 7th November 2009 00:25
Grinding noise in Honda City 4At His Highness Technical Stuff 0 28th July 2008 17:14
Grinding noise in gear-change! ramzsys Technical Stuff 3 1st October 2007 22:37
