Old 27th March 2009, 14:08   #16
Perakath's Avatar
Thanked: 28 Times
Originally Posted by raja748 View Post
This I strongly noticed when day before yesterday I passed a spot where some people were burning garbage.Though my window glasses were closed,I got a strong burning smell inside the car.My AC was off and so the blower fan.
Very few car models are completely air-sealed, even with the a/c vent set to internal recirculation-- this explains the air noise at high speed travel. Burning garbage/leaves produces a large amount of smoke/emissions, some of which were bound to hit you.
The HVAC recirculation-fresh air flap is located behind the dashboard. If bad odour problem persists, please check passenger/driver emissions to rule out other possibilities.
I'm often to blame, myself!
Perakath is offline   Reply With Quote
Old 30th March 2009, 12:49   #17
Today I was trailing a garbage truck as there was no space to overtake it.AC was off,Blower was off,circulation was off....and suddenly I got breeze of dirty smell of the garbage...my God!!!! it was so horrible..I immediately switched on the AC and put it on inner circulation mode.
Guys..I need to do something to solve this problem.Believe me the problem was not there 3-4 months back.
raja748 is offline   Reply With Quote
Old 30th March 2009, 13:03   #18
pulsar56's Avatar
Thanked: 319 Times
Please keep the Inner Circulation mode ON even if the AC/blower is off. That should solve your problem.
pulsar56 is offline   Reply With Quote
Old 30th March 2009, 13:26   #19
Ok Pulsar56..I will try doing so.
Old 30th March 2009, 13:33   #20
sudipt123's Avatar
Thanked: 20 Times
How can we add an ac pollen filter with cars which don't have one? Are they available at accessories/ spares shops? I would be interested to add one for my chevy spark, also I think swift doesn't have this filter.
sudipt123 is offline   Reply With Quote
Old 30th March 2009, 13:56   #21
gpa
gpa's Avatar
Thanked: 274 Times
+ 1 to this. it is also good to keep your recirc flap permanently closed. If at all you want fresh air into the vehicle, just roll down the windows a few minutes. Saves you a lot of trouble in the long run.
Cheers,
gpa
Old 30th March 2009, 14:43   #22
Perakath's Avatar
Thanked: 28 Times
How can keeping the recirculation flap permanently closed save any trouble in the long run?
Old 30th March 2009, 15:01   #23
gpa
gpa's Avatar
Thanked: 274 Times
Because you will not leave the recirc flap open when you park under trees, where leaves and other debris can fallin thru the slats up front near the bonnet area and enter you're car's AC system and clog the cooling coils and blower.
Cheers,
gpa
Old 30th March 2009, 15:13   #24
Perakath's Avatar
Thanked: 28 Times
Oh! I try not to park under trees except when there's no other shade source available-- that's to avoid bird droppings and squished fruit spoiling the paint. Here's one more reason!
Old 16th April 2009, 13:48   #25
You were absolutely correct bro!!! my problem vanished as soon as I have started keeping inner circulation on.
Thanks a lot to everyone...
Old 16th April 2009, 22:43   #26
ask77's Avatar
Is the recirculation flap on cars with push button recirculation system operated by a solenoid or a motor ? The ones in cars having the sliding switches is connected thru a cable and one gets to know whether the flap is open or not as there is a slight thump of the flap closing. But how does one know whether the push button system is working or not ?
ask77 is offline   Reply With Quote
Finally In - Smells like Home ! Or should I say Gasoline? Arch-Angel Introduce yourself 2 4th January 2013 19:57
Car exhaust smells like burnt paper, whats gone bad? gigy Technical Stuff 12 14th September 2009 20:45
Sony VAIO bought on ebay auction, seller smells fishy, what to do? & Craigslist ntomer Gadgets, Computers & Software 25 19th April 2009 13:21
Why blower smells after AC is switched off penpavan Technical Stuff 2 5th April 2008 23:00
Is it possible to release the hand brake from outside the car? Stig Technical Stuff 33 15th September 2007 22:06
