Old 2nd April 2009, 16:46   #1
nishantgandhi's Avatar
Thanked: 151 Times
Default Getz 1.3 - Metal scraping sound from the front
Of late, I have been noticing weird sound from the front of the car.
If I hit a speed breaker/bad roads at speeds of more than 15-20 kmph, there is a sound akin to scraping of the underbody. This is a remote possibility, since the Getz has a good enough ground clearance.
The sound seems to be metallic in nature, as if two metal sheets are rubbing against each other, or as if something is loose underneath.
I am quite worried by this. Could it be a major problem? My mechanic discounted my fear though but I would still like to be sure. What should I ask him to specifically check for?
The car is Nov 2004 registered and done 34,000 kms till now. 90% city and 10% highway run. The suspension feels smooth and soft otherwise and ride is quite comfortable.
nishantgandhi is offline   Reply With Quote
Old 2nd April 2009, 17:35   #2
ilangop's Avatar
Thanked: 591 Times
Hi Nishant,
Once my dad encountered a similar situation in his car. It was sound similar to poking in a small twig into a table fan. Was periodic and increased with wheel speed. First I doubted if it was from the mud flat rubbing the tyres. But it was not so. On removing the wheel it was found that the mus cover plate for the front disc brake was a little bent and it was touching the rim from inside. Just hammered it a bit and the sound was gone.
Just sharing a piece of my experience, could a possibility too.
ilangop is offline   Reply With Quote
Old 3rd April 2009, 04:23   #3
iraghava's Avatar
Thanked: 156 Times
I think your engine is about to fall through the bonnet Nishant. Better sell this and get a new car soon.
Old 3rd April 2009, 19:45   #4
Thanked: 152 Times
Hi !
I think you should get the chassis welding checked as when you brake , hit a bump , go over speedbreaker the the chassis is twisting.So i would just suggest get all the seam welding , joints checked
Trust_In_Thrust is offline   Reply With Quote
Old 4th April 2009, 10:59   #5
Thanked: 103,731 Times
1. Your suspension is sagging and it is, indeed, the underbody scraping against speedbreakers
2. Your tyre is rubbing against a loose wheel arch cover / mudflap
Old 2nd June 2009, 10:53   #6
Thanked: 151 Times
I dont think tyre scraping is an issue.
Will have to get the sagging suspension issue checked, now that you have introduced that point. I didnt even know such a thing could happen!
What are the causes for it?
Swift : Making metal rubbing sound : Help manjubp Technical Stuff 9 5th December 2010 11:17
Swift ZXi - Metal Scrapping Sound - Initial invincible7 Technical Stuff 9 9th June 2009 13:01
A little hum and slight metal grind kind of sound sreenivass Technical Stuff 11 17th May 2008 20:05
Scraping the Underside of my OHC aveek Modifications & Accessories 21 21st October 2005 14:15
