Old 3rd April 2009, 15:13   #1
throttleking's Avatar
Thanked: 336 Times
Default Problem while braking
I recently got Yokohama S-drives on my magnum. Original tyres was Goodyear GT3 196/60/R15 the new ones are 205/55/R15. Along with the tyre change i got the wheel alignment and balancing done. Then i noticed car is wobbling at high speed and it was pulling on one side, so got the re-alignment and balancing done again.
Now the pulling problem is not there plus the wobbling issue is also resolved. However while breaking and experiencing huge wobbling. I could not notice this on earlier tyres and i am not sure if this due to new tyres.
Experts, what could be the issue here and how to resolve it?
throttleking is offline   Reply With Quote
Old 3rd April 2009, 15:22   #2
siddartha's Avatar
Thanked: 22 Times
second time alignment and balancing was done in the same place? if yes i suggest you try a diff place and then consider further issues.
siddartha is offline   Reply With Quote
Old 3rd April 2009, 16:00   #3
predatorwheelz's Avatar
Thanked: 1,112 Times
Throttleking,
Just a hypothesis, but did you have an incident where either of the front wheels crashed into a bump/ditch at very high speeds, after fitting the new tyres?
Such an impact could have bent the rim as well as the brake disc on one of the front wheels. This is why you were having wobbling and pulling at speeds.
Subsequently, you rectified the rim by balancing. This stopped the car from wobbling under normal throttle. But since the caliper is still bent, the car wobbles when you brake hard.
Get the brake discs checked on both wheels.
predatorwheelz is offline   Reply With Quote
Old 3rd April 2009, 18:56   #4
Thanked: 336 Times
Originally Posted by predatorwheelz View Post
Throttleking,
No didnt have any such accident.
in last service at 15k service advisor told me that break pads are worn out and need to be changed, it would last for another 3-4k. this could be the reason for wobbling while breaking? i have done 5k after the 15k service.
Old 3rd April 2009, 19:27   #5
1self's Avatar
Thanked: 267 Times
Change the brake disks & the brake pads...your disks are warped hence the wobbling during braking. It will cost you a bit though.
1self is offline   Reply With Quote
Old 3rd April 2009, 19:28   #6
SS-Traveller's Avatar
Thanked: 11,019 Times
Check if the tyres are mounted and running in the correct rotational direction on all wheels. The tyres should be mounted on all wheels such that the apex of the V pattern is the leading part of the tyre as it rotates forwards - as per the picture. Otherwise you can have thie problem you describe. Needless to say, you'd have to re-balance all the wheels once the tyres are properly mounted.
Old 3rd April 2009, 21:14   #7
Since the car is only 20k old. Suggest you have the discs polished and change brake pads. If it still continues wobbling under braking, change brake discs.
Indian1979 is offline   Reply With Quote
Old 3rd April 2009, 23:20   #8
Thanked: 91,885 Times
If the wobbling is there ONLY when you brake, you need to change your brake pads. Most probably, your disc would need to be skimmed as well.
Old 3rd April 2009, 23:55   #9
Nikhilb2008's Avatar
Thanked: 5,103 Times
I agree with the people above me. The brake pads might have worn out. The Magnum is a fast car and I think your brakes would have seen their fair share of hard braking! SO, better get them changed.
Nikhilb2008 is online now   Reply With Quote
Old 4th April 2009, 02:04   #10
vikram18's Avatar
Thanked: 19 Times
If I remember correctly, there was a thread about the S-Drives that wasn't very flattering about these tyres. Do search for that one.
vikram18 is offline   Reply With Quote
Old 4th April 2009, 04:28   #11
iraghava's Avatar
Thanked: 154 Times
It's Brake Judder you're experiencing Tk, get your brake pads changed and the discs skimmed at the next service and the judder will go away.
Old 4th April 2009, 19:15   #12
Is this a wobble of the entire car while braking, or brake judder? I would think the two are entirely different things. Tk, could you be a little more descriptive in explaining your problem? Have you tried out the same braking with a different set of tyres? IMHO worn brake pads / discs don't set off a wobble in the chassis when braking hard.
Old 5th April 2009, 14:12   #13
Thanked: 336 Times
guys with doubt in mind of remotely possible root cause for wobbling while breaking, i checked the tyre pressure. and noticed that all 3 tyres except front left tyre had 37 pressure of nitrogen and rest 3 had 30. immediately got it corrected and problem is apparently partially resolved. but it still exists.
What is disk skimming?
yes i have gone through that thread, and then took a chance. i hope this is not the problem with S-Drive.
What is break judder? etire car is not wobbling, i mean passengers can not even feel it. i get wobbling only in steering.
Old 5th April 2009, 14:27   #14
ASHISHPALLOD's Avatar
Thanked: 286 Times
@throttle,
gaddi jara dhire chala, problems apne aap solve ho jayega.
aur ek solution,
tu gaddi hi badal de.
change brake pads.
is magnum going by skoda way?
brake pad change within 20000km???
ASHISHPALLOD is offline   Reply With Quote
Old 5th April 2009, 14:41   #15
Thanked: 336 Times
Originally Posted by ASHISHPALLOD View Post
@throttle,
aur ek solution,
change brake pads.
yaar ashish mai dheere hi chalata hu aur i would love to change my vehicle to Captiva if i could afford it so wait till i complete 5 years on my Magnum. Meanwhile i might do something which 1self has done to his Elantra
Even i am wondering how come i need to change breakpads so early, there are magnums on forum which are driven more than 30k and still going strong
Annoying problem while braking.. ashthedivx Tyre & Alloy wheel Section 13 10th February 2017 12:03
Shuddering/Vibrations while braking! Need help! asethi Technical Stuff 76 17th February 2013 18:16
Brake Pads "cheen-cheen" Screeching Sound While Braking vebmetal Technical Stuff 74 16th February 2013 07:26
A thud from the rear while braking!! avigster Technical Stuff 23 29th May 2011 14:37
A strange sound while braking zaks Technical Stuff 2 11th February 2009 22:24
