Old 6th April 2009, 13:12   #1
ashthedivx's Avatar
Thanked: 22 Times
Default Chevrolet Optra - Tak Tak sound from rear left!!
It is very unsual sound which errupts on uneven road or even a immidiate small bump is crossed at a speed of mere 50-60km/hr. Looks like some nut got loosed from somewhere or like something is touching the underbody at the time of bump. The sound dosen't comes in a smooth road or small bumps on speed of 20-30Km/hr.
Shockers are changed recently say 2-3K Kms back only, so i suppose one can strike off bad shockers and mounting issue.
It get on nerves whenever car is on pott-holed roads !!
Old 21st April 2009, 01:34   #2
sajanpt's Avatar
I too have the same problem !! Will tell them during the next service !
sajanpt is offline   Reply With Quote
Old 21st April 2009, 09:42   #3
ashthedivx's Avatar
Thanked: 22 Times
It was fixed by replacing link rod in rear suspension.
Old 21st April 2009, 09:55   #4
wanderernomad's Avatar
Thanked: 806 Times
Ohh I just saw this thread and happily the problem has been solved. At times the rear mounting bush on the link rod is also a culprit. Best diagnosis is to either crwl under the car or get it raised up and visually check all bushes. A minor issue but very irritating none the less.
wanderernomad is offline   Reply With Quote
Old 21st April 2009, 09:58   #5
ashthedivx's Avatar
Thanked: 22 Times
Indeed it was very irritating.. Specialy when one drives with no music & closed windows it's like someone banging over your head continuously.
Old 21st April 2009, 10:18   #6
Thanked: 806 Times
OT: but why are you driving without any music?
Old 21st April 2009, 10:24   #7
ashthedivx's Avatar
Thanked: 22 Times
At times when you are in quite mood and fed up with office/phone chatters
Old 25th May 2010, 17:00   #8
I am facing the same problem for my Optra. Both front struts were replaced about 2K KM ago. Link rods seem a bit expensive :(
kumar77 is offline   Reply With Quote
Old 26th May 2010, 11:44   #9
ashthedivx's Avatar
Thanked: 22 Times
Get the shocker nuts checked which do no tighten up easily while refitting, they tend to be culprit one usually.
Chevrolet Cruze or the Chevrolet Optra - Which car and why? blueorchid Sedans 105 18th November 2011 10:03
Hyundai Verna Fluidic Vs. Chevrolet Optra Magnum vs Chevrolet Cruze soulweaver Sedans 55 3rd October 2011 10:48
Tak Tak Tak Sound from my Enfield Bullet Standard 350 1996 Model navin_v8 Motorbikes 5 13th May 2010 10:45
Spied:2009 chevrolet optra J200 and chevrolet beat M300 (matiz) sidindica The Indian Car Scene 41 29th May 2009 08:55
Tak Tak Sound : Accent Viva CRDi mobike008 Technical Stuff 12 26th June 2008 01:22
