Old 18th May 2005, 20:12   #1
Surprise's Avatar
Thanked: 129 Times
Default Engine Output and Torque power
I found the following in technical specs of Zen
Engine Output: 60@6000 and Engine Torque: 8@4500
I was tempted to compare with Santro
Engine Output: 62@5500 and Engine Torque: 9.1@4000
What this actually means. I think that more BHP, its more pick up. What is the role of the figures mentioned after @
What is engine torque means. How do you arrive that the combination is better
Surprise is offline   Reply With Quote
Old 18th May 2005, 20:17   #2
johnjacob's Avatar
Thanked: 24 Times
The figures after the @ refer to RPM. Therefore the Zen has a peak power of 60 BHP and this power is generated at 6000 RPM.
At any RPM, your pick-up is proportional to the Torque at that RPM. Power (BHP) is calculated as Torque*RPM / Constant (I think the constant is 5250, don't remember for sure). So an engine that generates high-torque at high RPM (ie revs freely) will have high power. This is why petrol engines have higher power figures than diesels, but because diesels have higher low-end torque, they may be more driveable in city conditions.
johnjacob is offline   Reply With Quote
Old 18th May 2005, 20:26   #3
Surprise's Avatar
Thanked: 129 Times
If we compare Zen and Santro, the torque of Santro is higher than Zen, but at RPM comparison Zen has higher figures than Santro. In this case which one is more powerful.
Iam I getting wrong?
Old 18th May 2005, 20:28   #4
Shan2nu's Avatar
Thanked: 87 Times
The constant is 5252.
Power (BHP) is calculated as Torque/RPM * Constant
BHP = torque * rpm / 5252.
Well, technically speaking. the figures on the Santro would be more ideal as you're achieving more power and torque at lower rpms but, there are other factors that can affect this.
1. Gearing
2. Loss of power between flywheel and wheels.
3. Weight of the vehicle
4. Rolling resistance
5. Aerodynamics etc
On paper, the Santro looks impressive but, it's not the case when you actually drive it.
This site should be able to explain better : Torque and Horsepower
Shan2nu
Old 18th May 2005, 20:41   #5
Shan2nu's Avatar
Thanked: 87 Times
When you calculate horse power, you have to remember that torque is always calculated in foot-pounds (lbft).
Zen - 8kgm = 78.48nm = 57.88lbft
Santro - 9.1kgm = 89.27nm = 65.83lbft
Shan2nu
Old 18th May 2005, 20:48   #6
johnjacob's Avatar
Thanked: 24 Times
Man, you're FAST! I caught the error and edited my post, but by that time you had already posted
Old 18th May 2005, 20:50   #7
johnjacob's Avatar
Thanked: 24 Times
The RPM per se doesn't matter. What is important is the torque curve - the car that generates high torque over the largest range of RPM will be faster. Also remember that the weight of the vehicle (power-to-weight ratio) comes into play here.
Old 18th May 2005, 20:53   #8
Shan2nu's Avatar
Thanked: 87 Times
May, you're FAST! I caught the error and edited my post, but by that time you had already posted
Thats bcoz we've gone through this torque and horsepower theory so many times, that I don't even need to think twice about it. LOL
BTW, here are 2 more threads on similar topics.
1. Torque and Horsepower (Torque vs BHP?)
2. Torque, Horsepower and Speed (Torque, HP, Speed)
Shan2nu
Old 18th May 2005, 21:23   #9
sparco's Avatar
Exclamation
guyz i own both santro xing and 97 carb zen the pik up n power of my zen is much more than tht of my xing my xing refuses 2 go above 135....both r stock
sparco is offline   Reply With Quote
Old 18th May 2005, 22:10   #10
Shan2nu's Avatar
Thanked: 87 Times
Why that, drive the Alto and the Wagon R (which are supposed to have the same engine) and you'll se a world of diff between the way these 2 perform.
Shan2nu
Old 18th May 2005, 22:35   #11
DCEite's Avatar
Thanked: 476 Times
Shan2nu
couldnt get that. Are you talking about the discontinued 1.1 Alto?
If so, whats the difference you are talking about? I thought both performe equally well.... please elaborate
DCEite is offline   Reply With Quote
Old 18th May 2005, 23:11   #12
Shan2nu's Avatar
Thanked: 87 Times
Nope. Their performance is not the same. While the Alto used to finish 100kmph in 14-15 secs, the Wagon R takes 17 secs.
Then there's also the drivability, the Alto feels much more peppy compared to the Wagon R.
And i dunno if you've noticed it. The Alto engine seems to be more revv happy than the Wagon R. Dunno what causes this.
Shan2nu
Old 18th May 2005, 23:30   #13
merve_extreme's Avatar
Thanked: 12 Times
Shan2nu
Wagon R take 14.31 sec for 0 t0 100.acc to autocar
merve_extreme is offline   Reply With Quote
Old 18th May 2005, 23:34   #14
Shan2nu's Avatar
Thanked: 87 Times
Can't believe anything Autocar says. They say the Corolla is faster to 100kmph than the Skoda RS. they say the OHC 1.5 has a higher top speed than the OHC Vtec.
Autocar figures are the last thing you should look at.
ANyway, this isn't a OD vs ACI discussion so, lets stick to the topic.
Shan2nu
Old 20th May 2005, 21:00   #15
v1p3r's Avatar
Thanked: 26 Times
Shan, I've seen a WagonR do a sub 15.5 sec 0-100kph run. Dead stock. 17 seems a bit high.
Understanding Power, Torque, Gearing and Top Speed Harbir Technical Stuff 60 4th June 2016 23:33
2007 Indica Xeta: Engine losing power all of a sudden and regaining power after mins mohandas Technical Stuff 17 3rd May 2016 07:37
How BHP, Torque and power-to-weight ratios can be misleading VeyronSuperSprt Technical Stuff 16 19th April 2016 07:25
DIY: Testing/Measuring the true power output of your Amplifier. cvc2145 In-Car Entertainment 6 21st December 2009 05:37
