Old 23rd October 2012, 20:02   #136
DeepakMenon's Avatar
Thanked: 137 Times
Default Re: Mercedes W124 E Class Support Group
Guys my yearly service is due, nothing serioud, normal stuff like Oil, filter etc, wanted to do it DIY as my mech is in mumbai and dont have the time to go there and nothing to do this weekend
Where i am stuck is what Oil Filter to use? I believe Skoda one fits or should i get a MB orginal from Mumbai shipped to me; any clue?
DeepakMenon is offline   Reply With Quote
Old 25th October 2012, 09:27   #137
Thanked: 136 Times
Dear Deepak,
I don't think the original would be very expensive. I bought it too.
Call Mahesh Bhai at Maganlal stores in Opera house ( +91 22 23826081/ 30016244), he has most w124 stuff in stock.
Aren't you in Mumbai itself?
vikramvicky1984 is offline   Reply With Quote
Old 25th October 2012, 12:02   #138
The original oil filter will cost you around Rs.800
tharakan9 is offline   Reply With Quote
Old 25th October 2012, 13:52   #139
Thanked: 137 Times
Originally Posted by vikramvicky1984 View Post
Dear Deepak,
Thanks will check with him,
No i am these days in Pune, Work.. :(
Anything else i should replace in the normal service?
Old 29th October 2012, 15:52   #140
ayushagarwal26's Avatar
Thanked: 84 Times
Originally Posted by benz220 View Post
Have you run a scan on the ECM, to check for any errors? I would then check the injectors, but you say it drives fine, so that may not be an issue. Also, not sure if we have this, but check the oxygen sensor, as these cause mixture issue if not working properly. Air cleaner been replaced?
Thanks for that note. I'll run a scan and check what's up. I suspect it could be the injectors, or maybe the fuel filter? I don't know if I have an oxygen sensor - I believe a scan should be able to help figure this out.
This may sound silly, but I don't know if the air cleaner has been replaced before I bought the car. It had been freshly serviced though.
An Update (suggestions welcome) -
Also, I ended up damaging the exhaust a bit. One of the clamps that holds the entire assembly in place (to the chassis) was loose, causing it to move a little over rough roads. I should have addressed it the first time I saw it :(
Anyway, the clamp gave way, causing the entire exhaust system to tilt down (almost to the road) at the tailpipe end while I was driving. No major impact (thankfully), and I got it temporarily fixed in order to get home - used a piece of metal wire to hook it up in position. However, the car is noisier (very little), and I believe there may be some small leak. Maybe I went over a bump after the clamp gave way! Need to get that done asap. I believe this is easy to repair and set back.
ayushagarwal26 is offline   Reply With Quote
Old 30th October 2012, 08:35   #141
Thanked: 11 Times
Its nothing major, around 300/- job, the guy will take it out weld the leak and put it back. Thats what it did for me, but mine came out from the joint. However, if the rubber mount is gone than its a 800/- part (khan market). Don't bother much though, just get it welded....thats it...
911varun is offline   (1) Thanks Reply With Quote
Old 3rd November 2012, 22:17   #142
Thanked: 84 Times
Finally got the exhaust work done.
It seems the exhaust pipe had been rusting for a bit - when the clamp gave way, the weight of the exhaust system finally caused it to give way. A major (almost circumferential) crack meant it wasn't a simple weld - I had to have a section replaced. Thankfully, I found a recommended 'silencer-wala' who did a thorough job. Looks like we're okay for now.
As for the initial first gear lag / jerk and the high fuel consumption - a ECU scan showed absolutely no engine faults, so I believe it is the filters at fault. The car was serviced 4000kms ago, but I don't know if the filters were changed or just the oil. Looking at the air filter, it looks like they weren't.
Next up - I drive another 1k kms to bring her to 5k since I bought her, and do a complete service - Oil filter, fuel filter, air filter, synthetic oil, engine flush and injector cleaning.
Also, thanks to today's visit, I got the opportunity to meet bhpian renegade, who has just got himself a lovely '96 E220 from bangalore (see pic). It was fun comparing notes and our machines - all of us should do this more often, perhaps?
Old 5th November 2012, 07:03   #143
Thanked: 41 Times
Be careful with synthetic oils. Once you switch out to synthetic, it is not recommended to switch back. I was told this by my Acura and Honda dealers in the US. Something to do with seals etc.
Change out the air filter now, and see if that helps. The fuel filter takes 15 minutes to change.
Good luck!
benz220 is offline   Reply With Quote
Old 6th November 2012, 17:36   #144
Thanked: 84 Times
Thanks... I'll read up on oils. Maybe semi synthetic is the answer... I still have time to carry out research!
On a different note, I was wondering who all in the NCR area own 124s (or are enthusiasts nevertheless) - I see Viraat13, renegade, 911varun, sportz_kruzer, and ricky63 on this thread often. Sorry if I missed someone.
I'm getting excited already with this idea before it pops out - why not have a mini 124 meet one of the coming weekends? A few car crazy people, endless discussions, and most of all, a bunch of german workhorses together sounds like a perfect day, especially owing to the beautiful weather! In fact we could even do this on a regular basis. A lot to share and learn, and the beautiful machines to drool over
What say? I'll PM you all too so no one misses this post! Please feel free to add anyone I may not know.
Ayush
Old 6th November 2012, 18:27   #145
Thanked: 137 Times
[/IMG]
The Intial Jerk in low gears can also due to Clutch nearing its life
BTW is only me or everyone; cant the see the pics.. :(
DeepakMenon is offline   (1) Thanks Reply With Quote
Old 7th November 2012, 08:07   #146
Thanked: 11 Times
I am in for the meet this sunday. I will suggest to meet early around 6 pm somewhere in central delhi, so that its near for everyone. Its a working day for me on sunday so I would be coming from Gurgaon...... I am open to any other dates for the meet.....
911varun is offline   Reply With Quote
Old 7th November 2012, 19:53   #147
Viraat13's Avatar
Thanked: 121 Times
The 2 beauties:
The damaged exhaust section:
Cannot see the pictures for some reason.
Originally Posted by 911varun View Post
I am in for the meet this sunday. I will suggest to meet early around 6 pm.
The Sunday before Diwali? At 6 pm? Doesn't sound like a good idea. All the markets will be horribly crowded.
Either way, I have no place in this conversation as I will not be attending the meet, (I have exams this entire month) but I just thought I'd mention it.
Viraat13 is offline   Reply With Quote
Old 8th November 2012, 01:37   #148
Thanked: 84 Times
Funny because I see the pics just fine! I'll check
Anyway, this Sunday, right before Diwali will be a little difficult for everyone I guess... we should plan for the Sunday after Diwali. Let me know who all is in!
Old 16th November 2012, 17:14   #149
Thanked: 84 Times
I checked in Palika Bhawan, Mann filters are available for 124s and are quite cheap. I'm worried if they're really made in germany... that's what it says though.
Oil, Fuel and Air filters together shouldn't cost you more than 2-2.5k.
Also, my car has been upto some diwali drama ;P
The power windows and wiper decided to stop working. Funny part is, the rest of the electricals work fine.
No fuses are blown, so there's no short circuit, I believe. Also, if I pull the relevant fuse out and put it back, the windows work for a few minutes, and then go off again. The mirrors work, the window rear lock works - so the electricals upto the center switch area are fine. I'll pop over to get it looked at tomorrow.
It's a little curious though!
Old 16th November 2012, 17:21   #150
Thanked: 137 Times
Check the fuse holder; they tend to go bad; rub the fuse with a sandpaper and the terminal that it sits
Sounds like a loose connection somewhere in the fuse box or fuse terminal
The Mercedes W124 E-Class Archive: Pics, Videos & Reviews Screwdriva The Indian Car Scene 30 12th January 2017 03:43
Land Rover support group! Sudarshan Post-War 287 1st January 2017 07:25
Mercedes E-Class (W124) Used Value? Raja Luxury, Imports & Niche 88 3rd September 2016 15:18
W124 - Mercedes E220 or E250D? Which would you buy? GTO The Indian Car Scene 119 6th June 2016 15:24
USB/iPod support for a OEM HU w/o USB Support MadRash In-Car Entertainment 26 2nd August 2014 00:40
