Old 16th January 2013, 09:03   #181
Thanked: 1,012 Times
Default Re: Mercedes W124 E Class Support Group
Originally Posted by kutlee View Post
Bolt should not be made on a lathe. Bolts are made from drawn steel wires and head is forged into shape. The threads are rolled not turned as made on a lathe. That gives the strength. Lathe made Bolt will just shear off.
Sorry to hear of the mishap of bolt shearing off.
In my post I had specified a "High Tensile Steel" bolt. It is true that most bolts are rolled for added strength, but a lot of bolts are also cut on the lathe. You have to follow the following steps
. The base material should be high tensile steel. Available easily from a specialist steel retailer.
. To add strength you can "case harden" the bolt either using induction heating or cyanide treatment.
Contrary to popular belief a lot of parts for high tech (aerospace and military included) industry are made in small dedicated machine shops.
Old 16th January 2013, 12:06   #182
laxmanrk's Avatar
Thanked: 58 Times
The original bolt that was broken off is attached here.
The area that is brazed is where it had broken off originally. I have brazed it so that I can retain it.
The bolt reads 12.9! Which according to most people is quite strong.
Now, the bolt we made was cut on a lathe and then hardened in oil.
The reason we think it sheared off was because the guy tried to strengthen/ harden it the original bolt's strength, which is way more than what the actual material could take and hence it became brittle and sheared off.
Learnt some metallurgy here and finally ordered an original bolt from Mercedes Benz of South Atlanta, who had one in stock.
Will update you on progress of the car.
laxmanrk is offline   Reply With Quote
Old 17th January 2013, 14:31   #183
DeepakMenon's Avatar
Thanked: 145 Times
A Bolt from SA.. wow..
Anyway This is for PUNE W124 owners
where is good mechanic in this city, i have moved here and i have to get my suspension bushing, engine bushing and clutch bleeding done.. any help
DeepakMenon is offline   Reply With Quote
Old 17th January 2013, 14:49   #184
Thanked: 84 Times
You can contact Ajaz Sayed of Bhoomi Motors bang opposite Victory theatre in Camp area.
floyd.bell is offline   (1) Thanks Reply With Quote
Old 21st January 2013, 17:39   #185
laxmanrk's Avatar
Thanked: 58 Times
Here's the Final (hopefully) list of parts that are getting replaced:
1) Two Intake Valves (not found yet) - any help is really appreciated. Part number 6060531101
2) Head Gasket
3) Bolt (left turn) for Fuel pump
4) Inlet Camshaft - bought from MB-specialist online. Awesome guys and very quick delivery. Highly recommend this website to fellow W124 owners
5) Timing Chain
6) Oil Seal over crank shaft
All injectors have been removed and re-conditioned by Bosch. Apparently one was completely closed
All the piston heads seem clean.
Request fellow bhpians for inputs on what other works I may consider doing whilst I am building my engine.
Shall post pictures soon.
Old 30th January 2013, 15:13   #186
Thanked: 84 Times
I tried to PM you but your settings don't allow you to receive any PMs. Can you please check.
floyd.bell is offline   Reply With Quote
Old 11th February 2013, 11:23   #187
Thanked: 11 Times
Hi Guys,
My 124 has met with an accident, could anyone help me with the best workshop in Delhi and the best source for parts for the same.
Varun
911varun is offline   Reply With Quote
Old 11th February 2013, 12:55   #188
Thanked: 145 Times
Originally Posted by 911varun View Post
Hi Guys,
Varun
Damn; what are the damages
Parts i know few shops here in Mumbai; he will deliver in Delhi however only OEM
Old 11th February 2013, 13:54   #189
Thanked: 11 Times
Send you a PM on the parts needed, please let me know ASAP.....
Its front end damage, with headlights, grill, radiator, condensor, etc.
Old 11th February 2013, 16:28   #190
Thanked: 145 Times
COntact numbers in your inbox; Best of luck
some of those parts will cost you the earth; Headlights you can get DEPO ones they are much cheaper than the BOSCH ones and are good quality [At least all the feedback on US forums say so]; however you will lose your headlight adjustments using the vaccum switch in your dashboard
What about bumpers; panels and all?? are they alright and worth repairing?
Old 1st March 2013, 21:59   #191
laxmanrk's Avatar
Thanked: 58 Times
Hi guys
My car is still to hit the road!
Basically the engine has all been put together and FIP and all bits are back in place.
Problem: Vehicle cranks but does not start at all.
Have checked all timing related items. Seems like an Electrical issue.
There are 2~3 connections on top of the Fuel Pump. If anyone has or can point me to a E300 D - Engine wiring diagram I will really be obliged.
Can anyone help
Vehicle has been off the road for more than 2 months now!
Old 2nd March 2013, 08:40   #192
Thanked: 11 Times
Originally Posted by laxmanrk View Post
Hi guys
Can anyone help
I have the same E300 Diesel, have you checked the glow plug relay? The possible cause would be the glow plugs or the wiring harness. E300 Diesel has two wiring harness one for the glow plugs and other for the engine. Please put some pics of the engine, I would be able to help you out better... Also, is it giving white smoke on long cranking?
Old 2nd March 2013, 11:40   #193
laxmanrk's Avatar
Thanked: 58 Times
Thanks for your reply Varun
I am appending 2 photos - one of the engine and one of the FIP!
Do let me know if you need any further photos.
Old 2nd March 2013, 13:23   #194
Viraat13's Avatar
Thanked: 127 Times
Curious to know what white smoke on cranking means. Could you please explain further?
Also, can anyone help me source a automatic transmission modulator for the E250D Automatic? I need the one for the first and second gears. It's a red coloured modulator. Even the part number would help.
Thanks.
Viraat13 is offline   Reply With Quote
Old 3rd March 2013, 06:44   #195
laxmanrk's Avatar
Thanked: 58 Times
Hi all
Finally, after much fanfare and loads of trials and errors, we disconnected the vacuum stop line from the key to the FIP.
This did it. The vehicle finally starts and stays at idle. But vehicle does not stop if you turn the key off. The vacuum pipe needs to be re-connected to turn it off.
Now, I need to figure out the vacuum diagrams and check that. Vacuum pump seems to be in good order.
Any other inputs appreciated.
Viraat, Is your E250D a W124 or W210? Please PM me your VIN number. I will get you the part number and probably links of where you maybe able to order it on the internet.
The Mercedes W124 E-Class Archive: Pics, Videos & Reviews Screwdriva The Indian Car Scene 37 16th January 2018 09:38
Land Rover support group! Sudarshan Post-War 295 6th August 2017 02:53
Mercedes E-Class (W124) Used Value? Raja Luxury, Imports & Niche 88 3rd September 2016 15:18
W124 - Mercedes E220 or E250D? Which would you buy? GTO The Indian Car Scene 119 6th June 2016 15:24
USB/iPod support for a OEM HU w/o USB Support MadRash In-Car Entertainment 26 2nd August 2014 00:40
