Old 13th March 2010, 23:05   #16
wanderernomad's Avatar
Thanked: 579 Times
I am looking to buy a W124 E250D which is a 1993 Mercedes Benz, Made in Stuttgart, 5 Cylinder-250 Diesel, W124, Import. Drove it today the car is slightly sluggish and found the clutch to be lethargic. It takes a long time to engage. Is it true of all W124's? Also what should be a good offer price for this car? It has done about 1,12,000 Kms till date.
The known problems as on date are:-
1. Central locking not working.
2. Side indicator is missing.
3. ABS light is always on.
4. Power windows need to be checked.
Apart from the above the body is neat and only a few rust spots around the door hinges and the wheel well. Everything about the car is stock.
Please give urgent advise and more so for the clutch. The car doesnt move forward till you really linger on withe the clutch release and keep pressing the throttle. Even then it moves like a snail but picks up at around 2000 rpm.
__________________
wanderernomad is offline   Reply With Quote
Old 14th March 2010, 16:40   #17
V-16's Avatar
Thanked: 829 Times
Originally Posted by Pune Doc View Post
Can anyone suggest where in Pune/Mum can I procure an AC relay and wiring harness for a W124 E250 D? and how much would it cost?
Best wishes
Pai auto electric in Mumbai is great for electric work on any cars. Beware of randomly believing the Merc dealership and changing parts. They often ask you to change what they cannot understand or repair. IF you do want to drive down to Bombay any one of these days, Pai will diagnose and fix it up in a jiffy. If it does indeed need a new wiring harness, then that can be arranged too.
V-16 is offline   Reply With Quote
Old 15th March 2010, 09:58   #18
Ravindra M's Avatar
Thanked: 194 Times
Dear V16,
Thanks for the info.
Could you please share the contact details of M/s Pai electricals.
- Ravindra
Ravindra M is offline   Reply With Quote
Old 15th March 2010, 10:58   #19
deutscheafrikar's Avatar
Thanked: 306 Times
Originally Posted by V-16 View Post
Pai auto electric in Mumbai is great for electric work on any cars. If it does indeed need a new wiring harness, then that can be arranged too.
V 16 is that the same one, Pai Auto Electric works at Shivaji park you speak about? This old man is an expert. Do they have branches or diffrent ones by the same name in mumbai
deutscheafrikar is offline   Reply With Quote
Old 19th August 2010, 23:52   #20
Thanked: 13 Times
Default Heavy Clutch in W124
I have two issues now with my W124
1. I own a 1996 E220 which has clocked around 76K kms. For the last 1 week I am feeling a heavy clutch in my vehicle , before this I felt it once in a while. For the past three days my knees are aching badly after driving in a traffic for nearly 30/60 mins. What may be the cause and solution for this?
2. When I had a fuse bulb in my headlight I changed it and did a Hella Relay since I went for a 90/100 W Halogen bulb. After this change, the light notification is glowing in my panel. I checked all the other lamps and they seems to be fine. What may be the cause for this?
vasanthjn is offline   Reply With Quote
Old 23rd August 2010, 15:38   #21
V-16's Avatar
Thanked: 829 Times
Hi Vasanth, the heavy clutch may be due to many reasons, most common of them are the low fluid in the reservoir but that would mean low brake fluid so that may not be the reason. Sometimes due to wear and tear the "fingers of the pressure plate" may get hard, that mean its time for a change.
Coming to your second point, if you are certain that there is no fused bulb, then obviously the electrician has messed up and not wired the relay correctly, thats why the waring light shows.
In any ways, the cause is cannot be pinpointed unless the car is seen personally. Please get it checked up by someone who knows his job.
Old 5th October 2010, 21:47   #22
GordonGekko's Avatar
Thanked: 21 Times
Hi guys
Just bought an e220. Needs some work on it. Will post pics later.
I am planning to get 17" monoblock amg (or replica) rims. Anyone know where in ncr would be good? Also, what tyres to go for, that will give it a nice low profile look.
GordonGekko is offline   Reply With Quote
Old 30th December 2010, 15:38   #23
K a s h's Avatar
Thanked: 31 Times
Thumbs up Re: Mercedes W124 E Class Support Group
Its good to see lot of personal experiences shared in this thread which will help other owners.
Well i'm on the lookout for a W124 - E220. If you guys come across a good E220 in Bangalore, send me a PM.
K a s h is online now   Reply With Quote
Old 14th January 2011, 08:21   #24
Thanked: 47 Times
Default Re: Mercedes W124 E Class Support Group
Post deleted by the Team-BHP Support : Posting the same query over and over again, across multiple threads is STRICTLY prohibited on Team-BHP. This is considered as SPAM.
We advise you to read the Announcements and Board Rules section before proceeding any further.
benz220 is offline   Reply With Quote
Old 14th January 2011, 10:49   #25
Screwdriva's Avatar
Thanked: 335 Times
Count me in. I've owned a 1996 E220 for the past 2.5 years,
My biggest issue is sourcing a good German rear bumper. Can't find one in Mumbai. Any suggestions would be helpful!
Screwdriva is offline   Reply With Quote
Old 14th January 2011, 23:41   #26
Thanked: 47 Times
Last edited by GTO : 15th January 2011 at 16:42. Reason: See Mod note in your post
benz220 is offline   Reply With Quote Received Infraction
Old 9th February 2011, 04:14   #27
Thanked: 47 Times
Default Re: MBZ W124 Tyre recommendation
I need to replace the tyres on my W124. It currently has 195/65/15 and I was looking for suggestions on what type of tyre members prefer on this car.
It seems in Pune, the options are Michelin Primacy LC, Goodyear, Pirelli. Has anyone used any of these on a E220 W124, and if so please post your review.
Also, is it recommended to go to a 205/60/15 on the stock alloys?
Thanks for the help.
Old 9th February 2011, 15:28   #28
jubin's Avatar
Thanked: 11 Times
i used 205/65 good year tyres on my W124.
perfect for economy and ride comfort
jubin is offline   Reply With Quote
Old 20th February 2011, 10:48   #29
Thanked: 164 Times
Can someone please recommended a good place in Mumbai to get the central locking on a W124 fixed?
My Dad just got the power window on the drivers side door fixed on his '96 E250 Diesel, and the central locking just stopped working since then.
RandomUsername is offline   Reply With Quote
Old 21st February 2011, 18:38   #30
Thanked: 75,735 Times
If an experienced Mercedes owner like V-16 says Pai Electric (in Shivaji Park) is good, well, he has to be good. Why not check them out to get your central locking repaired?
Land Rover support group! Sudarshan Post-War 289 28th May 2017 10:29
The Mercedes W124 E-Class Archive: Pics, Videos & Reviews Screwdriva The Indian Car Scene 34 23rd May 2017 22:12
Mercedes E-Class (W124) Used Value? Raja Luxury, Imports & Niche 88 3rd September 2016 15:18
W124 - Mercedes E220 or E250D? Which would you buy? GTO The Indian Car Scene 119 6th June 2016 15:24
USB/iPod support for a OEM HU w/o USB Support MadRash In-Car Entertainment 26 2nd August 2014 00:40
