Old 30th July 2013, 20:42   #406
Viraat13's Avatar
Thanked: 127 Times
Default Re: Mercedes W124 E Class Support Group
Originally Posted by manikjeet View Post
Just out of curiosity i wanted to ask that when I unlock the car a buzz sound comes for 10 -15 secs from the rear seats and then stops. Its like a small electric motor sound.What is that sound.
The vacuum module that controls the rear head rests is under the rear seat. Maybe you have a leak that you should check out.
I've had this long standing problem of the E220 shutting off whenever I am coasting to a halt at a red light or even if I have to press the clutch for a very slow turn. The problem comes and goes, but it has become really bad these days. The idle isn't steady like it should be, and the engine isn't as silent as other E220's when the hood is open. On scanning, it gives some HFM error. I have suspected the LLR, but I have no way of knowing for sure, and I refuse to spend a five digit sum based on a hunch. Does anyone have any ideas?!
Viraat13 is offline   Reply With Quote
Old 30th July 2013, 21:02   #407
DeepakMenon's Avatar
Thanked: 145 Times
1. Check the Air Mass Sensor
2. Do a baseline tuning [Spark PLugs, Leads,]
3. So the standard check like OVP
4. Do a throttle body clean
5. Adjust the throttle cable
I would check all that before i jump into LLR; my friends E220 had exactly the same issues as you mentioned; over a period of time he did all the above 5; and now he does not have that issue.. so not really sure what worked
As far as noise; try and isolate from where the noise is coming; typical culprit is the FAN; and that needs a replacement
DeepakMenon is offline   Reply With Quote
Old 30th July 2013, 21:12   #408
Viraat13's Avatar
Thanked: 127 Times
1. MAF sensor is fine. No codes, nothing. Even checked with a new one.
2. Spark plugs are 16000 kms old. Cables too.
3. All relays are fine. OVP is new.
4. Done 500 kms back.
5. Adjust the throttle cable to what? I have to get it changed, as the adjusting spring/nut is broken.
I HAVE done everything, it's why I'm suspecting the LLR. But what about the EGR. Does the E220 have one? Where?
Fan clutch was replaced in September last year. By noise I meant that the engine makes more noise while idling. Smooth and everything, just noise.
Old 31st July 2013, 11:26   #409
Thanked: 11 Times
All the OM 606 which were official imports through Tata did not had EGR and Catalytic convertors. Its the same with mine which was imported through Tata. I am yet to see a OM 606 TD in India through.
911varun is offline   Reply With Quote
Old 31st July 2013, 15:47   #410
Viraat13's Avatar
Thanked: 127 Times
This is a M111 engine though. Maybe it was different for the petrol? My silencer fellow told me that the E220 does have a catalytic converter.
Old 31st July 2013, 16:32   #411
Thanked: 145 Times
E220 has a cat con; and does have a EGR as far as i know
How is the general health of your engine wiring harness??
Old 31st July 2013, 17:00   #412
Viraat13's Avatar
Thanked: 127 Times
The wiring harness was replaced with a brand new one in August 2010. So, A+.
EDIT — Would you know where the EGR is located?!
Old 2nd August 2013, 11:05   #413
Originally Posted by jeeva View Post
You can go to Car-Mechs, situated in Teacher's colony, Jakkasandra, Koramangala.
Pretty straight forward guys and they know their stuff with Mercs.
I also bought my W124 E220 through them and also give my car there for all kinds of tweaks/service/repairs. They are competent on all kinds of car, especially the imported/luxury brands. I have seen them working with Porsche/Ferrari also. That said, 4 out of 5 cars I see in the workshop is a Merc, all kinds of them, from 190D to SLK350.
blackcloud is offline   Reply With Quote
Old 2nd August 2013, 11:50   #414
DudeWithaFiat's Avatar
Thanked: 376 Times
By any chance could that be coming from the rear antenna motor?
DudeWithaFiat is offline   Reply With Quote
Old 2nd August 2013, 12:49   #415
manikjeet's Avatar
Thanked: 109 Times
Nope the Chip on top of the antenna has been disconnected for a long time and it is not connected to a power source also.
manikjeet is offline   Reply With Quote
Old 2nd August 2013, 13:54   #416
Thanked: 145 Times
Pune Guys; Where do you get your alignment done for your W124; the normal guys are just not able to get it right
Old 2nd August 2013, 14:07   #417
manikjeet's Avatar
Thanked: 109 Times
If you want I can send you the table sir.
Old 2nd August 2013, 16:16   #418
Thanked: 145 Times
Ya do send me the table; but i guess the guys are not very proficient with our cars..
Also is the rear adjustable?
Old 2nd August 2013, 16:37   #419
manikjeet's Avatar
Thanked: 109 Times
Sure Sir I will send you the tables. I would scan the Pages of the owners workshop manual and upload it.
I think the rear is adjustable.
Old 2nd August 2013, 18:59   #420
Viraat13's Avatar
Thanked: 127 Times
The rear is adjustable, but the regular guys don't touch it at all, because they don't know what to do. The best results will only be found if you go to the authorised service centre, but they charge about 4000 for wheel alignment. At least here in Delhi.
The Mercedes W124 E-Class Archive: Pics, Videos & Reviews Screwdriva The Indian Car Scene 37 16th January 2018 09:38
Land Rover support group! Sudarshan Post-War 295 6th August 2017 02:53
Mercedes E-Class (W124) Used Value? Raja Luxury, Imports & Niche 88 3rd September 2016 15:18
W124 - Mercedes E220 or E250D? Which would you buy? GTO The Indian Car Scene 119 6th June 2016 15:24
USB/iPod support for a OEM HU w/o USB Support MadRash In-Car Entertainment 26 2nd August 2014 00:40
