Old 15th February 2017, 11:35   #1006
Thanked: 1,011 Times
Default Re: Mercedes W124 E Class Support Group
Originally Posted by DudeWithaFiat View Post
while braking, I hear a grinding noise coming from around that area (or could be from front left wheel). The noise is there only when braking hard
Most probably a small rock has lodged itself between the brake pads and the disk. You can check for it after taking the wheel off.
Last edited by khan_sultan : 20th March 2017 at 15:19. Reason: Edited quoted post for better readability
Old 15th February 2017, 15:53   #1007
msaudf's Avatar
Thanked: 151 Times
Since then, while braking, I hear a grinding noise coming from around that area (or could be from front left wheel). The noise is there only when braking hard. No noise when braking very lightly. No noise when driving. Car stops fine too. I did a visual check, couldn't see anything. What could be wrong? Brake pads (no warning lights on the meter console)? Tyres?
Note1 : Wheels are out-of-alignment.
Note2 : Tyres are bad and they are 205/65R15 (not the correct size). I intend to go back to 195/65.
I suspect a broken suspension bush. The grinding sound could be caused when there is metal to metal contact and that would obviously happen if a bush is broken and while braking the wheel moves slightly backward giving way for the lower arm's mounting bracket to touch the metal in the arm. This movement is normal in any suspension while braking but the cushion here is the bush.
A simple test is to attach your wheel spanner to one of the wheel lug nuts and simulate the tightening action using your foot by jerking the wheel spanner downward. If you have excessive movement, you need to look at replacing the bushes.
On a side note: I recommend that you replace the tyres to either 205/55/15 or 195/65/15 not 205/65
msaudf is offline   Reply With Quote
Old 15th February 2017, 17:34   #1008
DudeWithaFiat's Avatar
Thanked: 376 Times
I hope that is the case.
Would it explain why the noise comes only when braking hard and not when braking slowly (when there is enough road ahead). And it is not exactly a grinding noise, but kind of humming + slight grinding.
About the tyres, yes, I`m replacing with 195/65.
DudeWithaFiat is offline   Reply With Quote
Old 18th February 2017, 08:17   #1009
Thanked: 49 Times
Have you checked both pads - it sounds like pad wear getting to metal on metal?
benz220 is offline   Reply With Quote
Old 18th February 2017, 22:42   #1010
Thanked: 376 Times
Thanks for the replies guys. I took the car to fellow BHPian Tharakan's garage. When I started off, as usual, I kept the windows opened for a minute to let the trapped air go out and I realise there was also a squealing sound. I hadn't heard that before since the car was driven with windows up till now. Anyways, at Tharakan's place, we found that one of the bolts that hold the caliper was missing and the caliper (body?) was tilted a little and was touching the rotor. The rotor wasn't rotating freely when we tried to rotate it by hand after removing the tyres. Luckily, he had a spare bolt of the correct size. The sound is gone now and I can sleep peacefully tonight .
Old 18th February 2017, 22:48   #1011
Thanked: 49 Times
That was an easy fix! I normally use Loctite on all "critical" nuts and bolts. Its the Blue version that is opened with a spanner when needed (do not use RED). All my brake hardware has this installed, as it eliminates bolts coming loose with rough road and vibrations.
benz220 is offline   (1) Thanks Reply With Quote
Old 24th February 2017, 23:18   #1012
Thanked: 376 Times
I saw the mechanic applying a red paste on the bolt, so I guess its Loctite.
Old 10th March 2017, 23:03   #1013
Hi every W126 owner and lover,
I'm based in Mysore, have recently come into an E250 Diesel (August 1996 model by TELCO, India) and have been hunting high and low for the Owner's Manual, as I would like to have some details on the lubes she uses. I found the engine oil grades, but require information on the grades of transmission oil and rear axle oil.
Going online, I found this information for the German-built W124 (pre-facelift, petrol car)
Transmission oil : Manual 5-speed transmission : Auto trans fluid for manual transmission (Sheet no. 236.2, which gives a list of oils & their makers, only one of which I recognize - Mobil ATF200 - was this in use back in 1996 in India? I ask this because I know that it is not a good idea to mix different grades of transmission oil)
Rear Axle : Hypoid gear oil SAE 90, 85W/90.
Can anyone assist me in this? Can anyone also let me know how to check the transmission and rear differential oils?
I would also like to have a copy of the India-built car's Owner's Manual, even a pdf version would do.
Thanks in advance.
CLYDE
CLYDE is offline   Reply With Quote
Old 15th March 2017, 16:30   #1014
sportz_kruzer's Avatar
Hello everyone. What are you doing for your beauties with respect to the 15 year old ban, especially Delhi/NCR folks.. Now that most W124s are 20 years or above? Please share or PM me if there are any updates to the same? Scrapping it will inly get you 30-35K? is that the only way left for these beauties?
sportz_kruzer is offline   Reply With Quote
Old 16th March 2017, 12:05   #1015
Viraat13's Avatar
Thanked: 127 Times
You can use Mercedes Benz Automatic Transmission Fluid for the gearbox, and any SAE90, 85W90 Hypoid Gear Oil for the differential.
I'm not sure how exactly the gear oil is changed, as most mechanics seem to know where it is.
The differential requires a 14 no. Hex key to open. It has a drain plug at the lowest point, so make sure your car is on level ground when it is opened. The filler is at the top and you need to fill the oil till it flows out. If I recall correctly, it takes about 1L.
Viraat13 is offline   (1) Thanks Reply With Quote
Old 17th March 2017, 07:36   #1016
Thanks a lot, Viraat. I want to get both the oils checked & topped up sometime next week.
Old 20th March 2017, 14:42   #1017
Well with a heavy heart I have decided to sell of the parts of my W124 E220 1996. Do PM me if you need parts of this car. I have also posted the same in the classifieds section. The car is in Gurgaon.
Old 20th March 2017, 18:44   #1018
Thanked: 6,852 Times
Good you have found the problem. Loctite is (nearly always) good.
However, I do hope that the bolts were properly torqued with a torque wrench. That is actually much more important than applying some Loctite.
There are many bolts and nuts that you can just torque up by feel. But especially on items like brakes, suspension and steering components it makes a lot of sense to use a proper torque wrench. That is the only way you really can unsure itís not overtightened, nor will it come off either.
Jeroen
Jeroen is offline   Reply With Quote
Old 6th April 2017, 16:53   #1019
Thanked: 376 Times
How rev-friendly are the 250Ds (OM605). I change gears around 1600rpm on level roads. Is it healthy? I like the sound it makes when revved hard.
Old 10th April 2017, 19:46   #1020
Viraat13's Avatar
Thanked: 127 Times
1600? How much lower can you go?
Viraat13 is offline   Reply With Quote
The Mercedes W124 E-Class Archive: Pics, Videos & Reviews Screwdriva The Indian Car Scene 37 16th January 2018 09:38
Land Rover support group! Sudarshan Post-War 295 6th August 2017 02:53
Mercedes E-Class (W124) Used Value? Raja Luxury, Imports & Niche 88 3rd September 2016 15:18
W124 - Mercedes E220 or E250D? Which would you buy? GTO The Indian Car Scene 119 6th June 2016 15:24
USB/iPod support for a OEM HU w/o USB Support MadRash In-Car Entertainment 26 2nd August 2014 00:40
