Old 13th April 2009, 23:40   #31
Thanked: 152 Times
Infractions: 0/1 (5)
@ Low_Bass_maker ; I have already added one 10Sq mm wire in addition to original wire from Alternator to battery.But When i switch on the Ac the lights dim.
Also could some one tell me the rating on Bher Indica Petrol radiator fan rating , as i have fitted this at rear and i believe this is too much for the poor M800.
Trust_In_Thrust is offline   Reply With Quote
Old 14th April 2009, 00:21   #32
Thanked: 294 Times
Have you ever measured the idle voltage in your car ?
Old 14th April 2009, 00:27   #33
Thanked: 152 Times
Yes .It is 13.9 Volts at idling with no load .And rises to 14.2 - 14.35 under acceleration.
It manages to stay at 13.5 volts with everything on except AC .
Old 14th April 2009, 01:08   #34
Thanked: 294 Times
Then it is normal. Check for voltage when dimming occurs. If the voltage returns to normal then everything is okay.
Old 15th April 2009, 00:45   #35
Thanked: 152 Times
Can some one please tell me the rating of Indica Petrol radiator fan Bher make .I have this installed and i believe this to be source of my problems .As without this there is no issue at all.
Old 15th April 2009, 09:50   #36
Thanked: 294 Times
Got to the shop from you purchased it. You can see the rating on the packing in which the fan came.
Old 15th April 2009, 22:18   #37
Thanked: 152 Times
@low_bass_maker ; tata radiator fan came with some product number .And on the fan it is mentioned 12 volts nothing about wattage.Anyways owing to the problem faced i have switched back to the Sanden fans with new bearings on the condenser at the back.
Thanks a lot everyone.
Old 16th April 2009, 14:02   #38
Prowler's Avatar
Thanked: 279 Times
It is sad that you have to leave the Tata Indica fan. You could do one thing (if you liked the Indica fan) - hook it up to the battery through an Ammeter and note the current it draws. Compare it with the other fan. Unless it is many times over - it need not be the main culprit in the consumption.
Prowler is online now   Reply With Quote
Old 17th April 2009, 01:19   #39
Thanked: 152 Times
@prowler ; Yes sure i did hook it up and it was showing about 22 Amps just the fan.
And my sanden fans are as mentioned on them 45watts*2 = 90 watts makes up 90/12Volts < 8 Amps .So no wonder the Indica fan was draining the life out of the Maruti800.
Old 18th April 2009, 13:15   #40
Prowler's Avatar
Thanked: 279 Times
That is a lot of power for a fan - it is about 264 W. Is it the design itself or the one in hand is a dud ? If it is the design, it must be belting out a lot of air.
Electrically-folding ORVMs - Aftermarket options? sachinayak Modifications & Accessories 15 24th August 2016 11:42
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Car Overloading - Harmful effects mithun Technical Stuff 21 14th May 2015 21:55
Electrically Adjustable Side-View Mirrors gd1418 Modifications & Accessories 16 11th July 2013 08:05
Maruti likely to renew Maruti 800 with a brand new car askicode The Indian Car Scene 32 13th February 2007 12:57
