Old 12th April 2009, 11:18   #1
Default Indigo --battery Light on when start and RPM meter is dead
Hi
Hi
I was having the same problem in my Indigo 3.3 ys old
'battery light which stays
on when start and RPM meter is dead. On slight
acceleration the RPM meter comes to life and battery light is
gone.'
still exists even after Lucas guys changes the regulator and oil seal to rectify the problem of overcharging
Earlier Tasc says it required alternator servicing but the issue is something else
Also i see some chik chik noise when window rolled down and goes more with the speed
Any one faced the same issue..
Pls throw light
virender is offline   Reply With Quote
Old 12th April 2009, 14:10   #2
gd1418's Avatar
Thanked: 656 Times
Already a similar post with similar heading exists and is running here. Shift there...
How to Jump Start your car (dead battery) mithun Technical Stuff 174 30th November 2017 18:25
Indigo --battery light which stays on when start and RPM meter is dead virender Technical Stuff 11 17th July 2012 11:17
Battery Light coming up on low rpm kavesh55 Technical Stuff 12 25th November 2008 18:27
Start battery dead cars without jumper cables using static electricity revvedup Technical Stuff 23 25th February 2007 00:13
Wanted RPM Meter ! khaadu75 Shifting gears 7 15th August 2004 11:30
