Old 14th April 2009, 17:37   #16
Originally Posted by vid6639 View Post
What's the compression numbers your getting? Have you done the compression test by disconnecting the fuel pump?
The compression for the Lancer is 180psi. Mine is barely 160psi.
what significance does this have?
silver_shadow is offline   Reply With Quote
Old 14th April 2009, 18:50   #17
Vid6639's Avatar
Thanked: 20,984 Times
I did it once without disconnecting the fuel pump. The compression numbers did not cross 100psi. I asked Sideways (Farhan) and he informed me that you need to turn the fuel pump off so that fuel is not injected into the cylinder.
If you remove the plugs and crank it with fuel pump on you will get petrol wash resulting in erroneous numbers for compression.
Old 14th April 2009, 19:00   #18
oops yea. good point. you do need to remove the fuel pump.
Car audio losing sound at low rpms! EDIT : Solved by "The Steg" GTO In-Car Entertainment 165 18th June 2014 16:10
What makes the Cast Iron (CI) engined Bullets cruise effortlessly at low rpms? aruncheloor Motorbikes 30 2nd July 2012 23:00
My Lancer jerks at low rpms wanderlustindia Technical Stuff 31 13th September 2011 10:19
