Old 13th April 2009, 21:35   #1
Thanked: 45 Times
Default Lancer condenser leak?
There is an small condenser (i suppose, not sure), behind the bumper on right side, its much smaller, but there is some leak it seems, in the thread area, where pipe and condenser are joined.
Is it serious problem? What is the use of that condenser?
I have noticed the leak, There was black oil like stuff there, so i spotted leak.
rajivanoj is offline   Reply With Quote
Old 13th April 2009, 21:42   #2
SS-Traveller's Avatar
Thanked: 11,631 Times
Small condenser? You're sure this is not the intercooler?
Old 13th April 2009, 21:57   #3
Sivia's Avatar
Thanked: 23 Times
You are talking about the intercooler , it is located on the right side behind the front bumper .
Sivia is offline   Reply With Quote
Old 14th April 2009, 00:08   #4
muneemmk's Avatar
Thanked: 18 Times
But the Lancer dosen't come with an intercooler, at least not in India.
muneemmk is offline   Reply With Quote
Old 14th April 2009, 00:10   #5
muneemmk's Avatar
Thanked: 18 Times
But the Lancer doesn't come with an intercooler, at least not in India, it must be the a/c condenser.
Old 14th April 2009, 00:57   #6
Sideways's Avatar
Thanked: 18 Times
Is it a diesel Lancer? In that case it is the oil cooler.
Sideways is offline   Reply With Quote
Old 14th April 2009, 09:36   #7
Can't have black stuff in AC condenser/intercooler pipe leak. I think you're right, Sideways, it should be the oil cooler. Rajiv needs to confirm if it's a diesel car.Remote diagnostics isn't easy...
Old 14th April 2009, 12:02   #8
Thanked: 45 Times
yes, its a diesel car (lancer), but i am not sure what it is, whether intercooler or oil cooler.
But am sure it is not AC condenser. its just an size of an average book. does this affect performance of car? or will it lead to any bigger problem?
Old 14th April 2009, 12:30   #9
gd1418's Avatar
Thanked: 656 Times
You are loosing engine oil dear. That could lead to engine seizure in the worst case. Check your oil level dude in the morning.
Get the leak corrected pronto..
Old 15th July 2009, 20:42   #10
Thanked: 45 Times
I am not losing oil much, its not dropping leak, its like leaking seal in the threaded pipe which connects to oil cooler. But i think i have to correct this leak soon, But Can i get the seals(packing) washer for it? once i remove the pipes, and if i could not source the packing, then it would be worse,. And . If available, what would be the average price?
Old 15th July 2009, 22:52   #11
muneemmk's Avatar
Thanked: 18 Times
It's been three months and you still running around with a leaking oil cooler ? It's bound to do more than some damage.
Old 16th July 2009, 16:47   #12
Thanked: 45 Times
Default @ muneem
actually the leak is not by drop, there is not even a single drop below it. but its like air leak, i noticed accidentally when changing tyres. i wonder i can get spares for that, once i attempt to repair it, then i have to get spares immediately, else the leak cant be plugged once back with older spares.
Skoda Laura L&K Compressor and Condenser question duke Technical Stuff 60 20th November 2017 23:28
car ac compressor and condenser problem honda3938 Technical Stuff 9 3rd December 2015 21:09
A/C Condenser slightly deformed - Do I need to replace it? Oceanstar Technical Stuff 4 10th December 2014 11:01
Condenser replaced = car starts jerking msetlur Technical Stuff 6 31st May 2012 22:10
What is a condenser? v1p3r In-Car Entertainment 23 3rd June 2007 04:34
