Old 13th April 2009, 23:56   #1
Smile Adding LPG to Santro
Hi all,
I own a Santro Zing (XO) which is 2 years old. I drive nearly around 65km per day and its costing alot on my pocket with a added help of long traffic stops. I want to get LPG added to my Santro but i am not sure whether it has any adverse effect on engine performance. I am bit cautious because i haven't heard many getting gas to Hyundai Santro.
Can some one please help me out with the below points -
-> How will be the engine performance effected.
-> What would be the ideal mileage i can expect from Gas, calculation would help.
-> Can i cover the car Insurance after the Gas addition to it.
-> What is the Installation of LPG to santro costs me, and where i can get it done in Hyderabad.
Replies are highly appreciated.
Deepak.
Twister_In is offline   Reply With Quote
Old 14th April 2009, 01:24   #2
Thanked: 152 Times
It is better to go for CNG if it is available near you.Also LPG is dangerous and explosive and atleast here in Delhi there are no major savings compared to Petrol in LPG.
Engine performance will not be affected much with proper tuning.
As far as i know there will be a drop of around 10-15 % compared to petrol in mileage.Yes you can cover the gas kit in car insurance.There are many vendors for LPG kits and price range from 12-18000 Rs depending on make , type of cylinder etc.
Trust_In_Thrust is offline   Reply With Quote
Old 14th April 2009, 15:49   #3
Thanks for the Reply Brother.
I haven't seen much of CNG in hyderabad, but would request others to provide some information about the same if any.
some more replies and suggestions would really help me in understanding the facts and coming to a conclusion.
Old 14th April 2009, 18:15   #4
Gasolinejunkie's Avatar
On petrol motors LPG works better than CNG, I donít know if its because of the lack of CNG in Australia but thats what I hear.
With LPG youíll get a slight drop on power on your mid range and about 20% drop in fuel economy, caliculate the price difference between LPG & Petrol and the cost of installing the kit and work out for yourself how much youíll be saving.
I run my Pajero on LPG because I get 5kmpl and just canít afford the 85 liters of petrol that I was going through every week. Its been running well on LPG but obviously it does take a bit of extra maintenance.
If your going to put the Santro on gas treat yourself to a sequential vapour injection kit, they are more expensive than negative feed systems but are heaps better. Or if you get a standard negative feed system, try to get one that runs in closed loop. ie. Utilizes the oxygen sensor to adjust air:fuel mixtures.
Gasolinejunkie is offline   Reply With Quote
Old 14th April 2009, 22:15   #5
Thanked: 152 Times
May be this will help .
http://www.team-bhp.com/forum/indian...hyderabad.html (CNG stations in Hyderabad)
Atleast CNG Stations are there in Hyderbad .A CNG kit cost around 30-38000 Rs.Also you mileage for Santro will be around 18-19 Km/Kg. So it will definitely be cheaper in long run.
Old 16th April 2009, 14:02   #6
Thanks for the information guys, it helped.
Old 16th April 2009, 18:33   #7
ghpk's Avatar
Thanked: 193 Times
Don't forget to carry a Cease Fire, cause i feel its more dangerous to get LPG/CNG installed instead of getting a vehicle which comes factory fitted with the KIT.
I would prefer staying in Home than driving a Live BOMB.
just my 2cents.
Old 16th April 2009, 18:49   #8
Thanked: 31 Times
It is safe. I had it in my old santro and ran for 2 years(20k KM) before I sold it and it didn't gave any issues. Take care in getting LPG kit serviced every six months(IMP), Install pressure gauge to watch the level of gas left, Keep handy cease fire(if you want) and run on petrol for few KMs say 5 to 10 after one LPG tank full. You will get max 1.5 bucks/KM with AC depending upon the rate of LPG at Hyderabad.
Get you RC book updated along with Insurance(this is very important otherwise you will not get any claim during accident)
aka_iitd is offline   Reply With Quote
Old 17th April 2009, 01:46   #9
Thanked: 152 Times
@ghpk : CNG is exponentially safer than petrol , diesel , LPG fuels because ;
It is lighter than air and escapes in case of a leak in the atmosphere whereas petrol will make a pool , so will diesel , and LPG will accumulate around for an explosion.
CNG ignites at a much higher temp. than petrol , LPG.
CNG tanks are much more safer in case of an accident vis a vis Petrol , Diesel tanks.
Old 17th April 2009, 09:12   #10
ask77's Avatar
Agreed but it all depends on the quality of the kit and quality of the fitting also the fittings should be inspected regularly for damages , leakages etc.
ask77 is offline   Reply With Quote
Old 23rd April 2009, 23:56   #11
joe_mclaren's Avatar
Default LPG service centers in Bangalore!
Hi Aka
I just moved in from TVM to BLORE and I wanted to get my LPG kit serviced. Can u suggest a good place for me. Im staying next to CV Raman nagar
joe
joe_mclaren is offline   Reply With Quote
Old 24th April 2009, 18:05   #12
Mpower's Avatar
Thanked: 1,687 Times
Check with Hyn dealer.
They might install the official CNG kit from the Santro CNG.
Old 24th April 2009, 19:11   #13
kannan666's Avatar
Thanked: 70 Times
Hyundai have just introduced the Santro Eco which runs on LPG, so it is even available factory fitted now ! Check it out here - Hyundai Santro ECO-LPG version car Launched- Info and Price:Indian Automobiles News Forums
kannan666 is offline   Reply With Quote
Old 3rd June 2009, 11:44   #14
p'arth's Avatar
Thanked: 85 Times
Folks, any idea on the density of LPG pumps in Hyderabad? Do most pumps have it or is it a rare find?
@Twister_In: What was you final take? Did u check out the Santro Eco?
p'arth is offline   Reply With Quote
adding LPG kit to GETZ Prime 1.1 anupam9557 Modifications & Accessories 7 9th June 2010 11:18
Santro GL LPG or Spark LS LPG arunjeetsingh Hatchbacks 13 28th April 2010 14:37
LPG car for my parents (Old Alto or new 800 LPG) jits_1998 Hatchbacks 7 9th October 2009 11:19
Palio 1.2 fitted with LPG Kit - Petrol level keeps coming down in LPG Mode shineshine Technical Stuff 9 10th May 2009 04:52
Wagon-R: VXi+LPG OR LXi+Upgrades+LPG? EDIT: Now booked LXi sohu9 Hatchbacks 14 16th January 2007 13:37
