Old 15th April 2009, 21:56   #16
Nitin's Avatar
Thanked: 9 Times
Originally Posted by Jaggu View Post
I dont think its an ECU reset issue, if so also it would be back to normal within 10-15 kms of running. Check you air filter and its plumbing.
More over swift P doesnt have that kind of pep under 2k rpm, if there is an issue at high rpm then it needs to be checked.
I agree with that. Somehow I feel its got something to do with the air filter.
It definitely is weird, as we always hear about a car running a lot smoother & the engine feeling rejuvinated after a service (but in this case, 3K on the odo seems a tab bit early for such a feel).
Nitin is offline   Reply With Quote
Old 16th April 2009, 00:27   #17
aerohit's Avatar
Thanked: 588 Times
it depends what you call a service
For most Maruti dealers, service is all about adding wiper fluid, coolant and checking blubs.
Thats why I tend to do real service separately myself - for example adding new oil and air filter which can be done at any small shop
aerohit is offline   Reply With Quote
Old 16th April 2009, 02:05   #18
Nitin's Avatar
Thanked: 9 Times
I would imagine the above mentioned to be done in a 3k service. Oil & filter change.Check tires, top up other fluids. What else is done on a car thats relatively new?
Old 20th April 2009, 10:35   #19
ashwinurao's Avatar
Tried the disconnect-battery-rev-hard method but didn't help. Also checked the air filter and it is super-clean.
Also, I am not expecting swift to have pickup like a Civic or NHC but I am comparing it to how it was before the service and right now. It is only a problem when the car is fully loaded. I have to press the throttle all the way to get it moving in 1st/2nd gear after a speed breaker. It was never this bad.
Another trip to the service station and this time I will make others to sit inside and then try to explain the problem :(
ashwinurao is offline   Reply With Quote
Old 20th April 2009, 23:41   #20
Roy.S's Avatar
Thanked: 93 Times
I am intrigued. Do keep updating. Have you completely ruled out bad fuel and clogged injectors?
Experts, any opinions?
Roy.S is offline   Reply With Quote
Lateral support reduced, after fitting seat covers DCEite Modifications & Accessories 2 20th June 2014 23:13
Swift DDIS Booking amount reduced P.S.Grewal The Indian Car Scene 26 23rd November 2010 16:00
Bought a Skoda 1.8 TSI. Prices reduced right after my purchase imp! The Indian Car Scene 35 20th January 2010 10:35
Bought Swift Zxi (second hand Aug 2006) NVI2112 Hatchbacks 18 8th September 2009 20:50
Less pickup after servicing of OHC 1.5..Urgent ashish22 Technical Stuff 9 17th December 2008 13:06
