Old 15th April 2009, 16:52   #1
Default Alto - Engine Proportionality
Hi All,
I have an Alto LXi - 3 years old.
I've been having a problem the last couple of months like thus. On an incline, if I try to increase power by pressing the accelerator, the engine revs up immediately, but there's no increase in the speed / pull. Sometimes, if the AC is on, this happens even on a level road. But it rarely happens when the engine is cold.
I took it to the Maruti Service Station a couple of weeks back for servicing and explained the problem to him. They reported that the clutch plate has hardened and there is a consequent loss of "proportionality". They said they have adjusted the clutch plate and I should try to use it now. If problem persists, the plate will have to be replaced (cost around 4.5K or so).
Well, the problem resurfaced yesterday. Not too sure what to do ... would appreciate any suggestions from the knowledgeable folks here.
Also racking my head as to what habit of mine has caused this problem in the first place. Is it normal to have this kind of wear and tear in just three years ? I follow the normal practices ... rest your foot on the floor, not on the clutch pedal ... don't use half-clutch to start-off on an incline (use handbrake instead) ... use engine-braking where you can. I do have to tackle a lot of start/stop traffic though (but don't we all).
Apologies if I'm rambling. Would appreciate any pointers.
Thanks,
Sonal.
WizardOfDoze is offline   Reply With Quote
Old 15th April 2009, 17:19   #2
esteem_lover's Avatar
Thanked: 451 Times
How many Kms has your Alto run ?
Old 16th April 2009, 11:53   #3
She's done about 27K kms so far.
Old 16th April 2009, 13:36   #4
amit_mechengg's Avatar
Thanked: 1,556 Times
are you finding the clutch release operation hard? clutch being hard is different and clutch slipping is different. i have a hard clutch after 40k kms, but its not yet slipping.
sometimes if portions of the clutch plate surface becomes hard then there is a proportional slippage. u will feel minute variations or jerks.
show it to a competent mechanic. he will judge better.
Old 16th April 2009, 14:13   #5
rjstyles69's Avatar
Thanked: 795 Times
I cant think of any thing else other than the clutch. Get the clutch changed and you should be good to go.
Old 16th April 2009, 14:33   #6
Thanked: 451 Times
For some reason, your clutch has worn out prematurely. Get it replaced & try to find out why it has worn out earlier than it should.
Old 16th April 2009, 14:38   #7
Rehaan's Avatar
Thanked: 25,038 Times
WizardOfDoze,
My guess here is that its one of the following :
1) The clutch setting is not proper - therefore when you release the pedal completely, it is stll not making proper contact. (If im not mistaken this is a possibility)
The above problem could have been the initial problem, that then led to the following (even if problem (1) was rectified later - as you mentioned).
2) Due to the constant slippage of the clutch, it has got worn out way faster than its usual life (which is closer to double of the kms you have currently run).
If this is the case, the clutch willl have to be replaced. Having your mechanic take a look at the clutch will tell. Just make sure that problem (1) has been solved before putting a new clutch in, otherwise the same thing will happen again.
Do you smell anything when driving? A rotten egg smell ?
cya
R
Old 19th April 2009, 19:30   #8
gpa
gpa's Avatar
Thanked: 282 Times
+1 to this. I had experienced this problem on one of my previous cars at about 50,000 kms on the odo. The clutch was replaced and the problem was solved.
Cheers,
gpa
Alto K10 vs Alto 800 vs Hyundai Eon Added_flavor Hatchbacks 176 26th August 2015 10:34
Alto 1.1 PW steering to Alto 800.non PWS Ramsagar Modifications & Accessories 12 15th October 2009 18:00
All New Japanese Alto VS Indian Alto (A-star) pictorial comparo sidindica The Indian Car Scene 25 7th October 2009 11:06
RTO Formalities for Engine change in Kerala (XDP4.9 engine to the XD3 engine) 4x4addict Modifications & Accessories 16 14th April 2009 21:51
To All Alto Owners / Experts: Need suggestion about Alto ICE Installation. nitin.dangayach In-Car Entertainment 12 19th August 2008 11:22
