Old 17th September 2011, 21:50   #31
Thanked: 2,394 Times
Default Re: White Smoke ?
This
Originally Posted by abhibh View Post
Guys I own an Alto 2000 Model. It as completed 1 Lac+ KM.
Started the car and engine oil light refused to go away and engine was make in clak clak clak sound.
and
Around 10 Years OLD. ODO reading states 125k KM. Engine oil, oil filter change every 5k KM. Air Filter + Spark Plugs + Brake Oil + Gear Oil + Misc every 20k Km.
refer to the same car?
If so, how many KMs between the two incidents?
Sutripta
Old 17th September 2011, 22:52   #32
IndigoXLGrandDi's Avatar
Thanked: 161 Times
Default Re: Alto : Engine Oil Light stays on. And some other issues
@revintup..
Is your car under warranty? If yes, then it should be replaced free of cost under warranty.
Please give details of your Swift.
IndigoXLGrandDi is offline   Reply With Quote
Old 18th September 2011, 21:54   #33
Thanked: 161 Times
@Sutripta..
He has mentioned in the previous post as 1Lac + Kms and in next post as 125K Kms.
I think you got answer to your question.
Old 18th September 2011, 22:07   #34
Posted in different threads. The threads were merged by the mods.
Sutripta
Malfunction-Indicator light stays on after push-starting car. How serious is this ? supremeBaleno Technical Stuff 18 17th August 2017 16:49
ABS light stays ON! Reason? lambuhere1 Technical Stuff 44 31st May 2017 16:30
Engine Oil Light stays on! S5157 Technical Stuff 33 8th June 2014 10:56
Indigo --battery light which stays on when start and RPM meter is dead virender Technical Stuff 11 17th July 2012 11:17
Vista Tdi - Engine oil and the Check engine light turns ON skartik2 Technical Stuff 4 27th August 2009 14:50
