Old 19th April 2009, 11:45   #1
abhibh's Avatar
Thanked: 34 Times
Angry Alto : Engine Oil Light stays on. And some other issues
Guys I own an Alto 2000 Model. It as completed 1 Lac+ KM.
Yesterday i gave my car to my dad. He came back after 5 - 6 hours and said there is some major problem with your car. How do you even drive it ?
I thought he was pointing towards heavy steering, uneven tyres or gear lever vibrations. He said i think your engine went kaput.
I was no it can't be. I went down and popped the hood checked the engine. Everything was intact under the hood. Started the car and engine oil light refused to go away and engine was make in clak clak clak sound. Turned the car off checked the engine oil and to my surprise the bloody oil level was 2 - 3 inches above. But then I came back to senses and checked the engine oil after 2 hours and to my surprise the oil was still 2 - 3 inches above the normal level.
I am suspecting its either piston or piston rings. Any pointer guys....
P.S. The car was standing on a plain surface while i checked the engine oil.
Old 19th April 2009, 12:06   #2
jithudigitised's Avatar
Thanked: 96 Times
Did you change the engine oil recently?
Which oil are you using - MIneral or Synthetic?
Please give details as this will be helpful to nail down the problem.
jithudigitised is offline   Reply With Quote
Old 19th April 2009, 12:11   #3
abhibh's Avatar
Thanked: 34 Times
I use Mineral oil and no i didn't change the engine oil.
Old 19th April 2009, 12:22   #4
karankapoor's Avatar
abhi i think its time that you change your car.
when did you last get your car serviced.
karankapoor is offline   Reply With Quote
Old 19th April 2009, 12:23   #5
deepclutch's Avatar
Thanked: 110 Times
I had a maruti 800 seized after radiator fan stopped working in a ghat section.there will be heavy knocking and imminent engine seizure.ask your father whether engine stopped in the way?.
Consider a Engine Overhaul or atleast piston ring replacement if the damage is very less.
deepclutch is offline   Reply With Quote
Old 19th April 2009, 12:23   #6
Thanked: 253 Times
Seems like the oil pump has given up and the bearings are burnt out!
Does the oil level drop when you start the car? If it remains the same, you'd better expect substantial damage.
Old 19th April 2009, 12:34   #7
abhibh's Avatar
Thanked: 34 Times
I know KK, i am just waiting for some more $$$ so i can buy a good acoustic car
And you are most welcomed to Donate to ABHIBH's Acoutic Car Fund
Last service was done around 7K km ago.
@deepclutch My dad says the car stopped once but it was not over heating. I am suspecting a engine overhaul.
@anupam i am guessing a substantial damage
Old 19th April 2009, 12:40   #8
Prowler's Avatar
Thanked: 305 Times
Looks like the engine is starved of oil circulation - possibly due to own of these things - oil pump failure, clogged oil filter (unlikely as there is a valve to by pass the filter in the event of a failure) etc.
Open the Oil filler cap and start the engine. You should see some sort of oil "spray" or droplets of oil when the engine is running. If there is no sign, stop the engine. It needs to be opened up for detailed investigations. It is time to call the professionals. Whatever you do, don't race the engine - you will only be adding to the damages.
Prowler is offline   Reply With Quote
Old 19th April 2009, 12:42   #9
akshay4587's Avatar
Thanked: 1,686 Times
Engine oil light is supposed to come on when oil level is low
in your case its above normal?????
Old 19th April 2009, 12:52   #10
abhibh's Avatar
Thanked: 34 Times
I'll try to do that and see. I am thinking of getting it towed and i think i will get the car fixed in May only and let is rest till then, as i have exams.
Ya dude its way way way way above normal. I'll take a pic and post.
Old 19th April 2009, 13:23   #11
abhibh's Avatar
Thanked: 34 Times
Here is the pic of engine oil level
An update. Just started the car to park in shade. The engine oil light went off after a few seconds. The tak tak / clak clak sound was there when i started the engine but went away after 15 - 20 seconds. on idle. Didn't drove the car just moved it like 10 feet in shade.
Alto : Engine Oil Light stays on. And some other issues-19042009189.jpg
Old 19th April 2009, 13:26   #12
Thanked: 253 Times
The engine oil light is for low pressure, not level.
Old 22nd April 2009, 17:01   #13
ScarySkulls's Avatar
Thanked: 19 Times
Time to tow the car and get compression checked.
Dont drive it with all those sounds coming.
ScarySkulls is offline   Reply With Quote
Old 22nd April 2009, 20:35   #14
pranavt's Avatar
Thanked: 274 Times
Drain the extra engine oil too first.
Old 22nd April 2009, 22:36   #15
Jaggu's Avatar
Thanked: 8,693 Times
Take it to a garage and get it checked ASAP. Sounds like oil pump failure and/or compression failure.
If it was carb'ed engine with a mechanical pump, then it could have been fuel pump diaphragm failure but this is a ECU car i guess.
Malfunction-Indicator light stays on after push-starting car. How serious is this ? supremeBaleno Technical Stuff 18 17th August 2017 16:49
ABS light stays ON! Reason? lambuhere1 Technical Stuff 44 31st May 2017 16:30
Engine Oil Light stays on! S5157 Technical Stuff 33 8th June 2014 10:56
Indigo --battery light which stays on when start and RPM meter is dead virender Technical Stuff 11 17th July 2012 11:17
Vista Tdi - Engine oil and the Check engine light turns ON skartik2 Technical Stuff 4 27th August 2009 14:50
