Old 25th April 2009, 02:09   #1
Thanked: 54 Times
Default Side indicators stop working after parking in the sun!
Hi Guys,
This is a weird one , whenever I park my car (esteem) in sunlight for some time , the side indicators just stop working! they start working after the car is driven for some time !
I just can't figure out what's wrong! any ideas?
Amit
techn0l0gist is offline   Reply With Quote
Old 25th April 2009, 02:20   #2
alexnazim's Avatar
Originally Posted by techn0l0gist View Post
Hi Guys,
Amit
How old is the car? Happens when switches get old. (If the car is not that old there may be a loose connection somewhere or maybe a lose fuse).
alexnazim is offline   Reply With Quote
Old 25th April 2009, 04:24   #3
ghpk's Avatar
Thanked: 193 Times
Hello,
it should be a loose connection either in indicator holders or in the flasher circuit.
you can try to turn ON indicators while the car is SUN HOT, and then try to check wire and the flasher.
Old 25th April 2009, 06:57   #4
Thanked: 146 Times
Few question:
1. Time of day?
2. Orientation of parked car?
3. Color of car?
4. Which side indicator?
5. How far driven before indicator works?
6. What speed to be driven for indicators to work?
7. Is it just the indicators that are not working? What about horn?
and finally...
8. Are you serious!
EDIT:
This is going to go the 'anything but Vanilla ice-cream & Ford (was it Ford)' way!
HappyWheels is offline   Reply With Quote
Old 25th April 2009, 11:51   #5
Thanked: 54 Times
car is 9 years old, i can't see any connection thats obviously loose
Originally Posted by HappyWheels View Post
Few question:
1. Time of day?
3. Color of car?
and finally...
8. Are you serious!
EDIT:
its really funny actually, but it happens at noon or any other time when there is hot sun and the car is parked in the sun, if its parked in the shade, it works fine! the car is some sort of golden beige color
the indicators work after driving some distance - no exact figure sometimes immediately, sometimes it takes 15 mins or so.
and the horn works fine, its just the indicators
Yes, I think it just might go the vanilla ice-cream way!
Old 25th April 2009, 12:22   #6
vikram_d's Avatar
Thanked: 940 Times
This problem seems to be related to heat. Some contact in the indicator circuit must be expanding because of the heat and contracting when it cools down. Now you need to figure out which contact it is. It can be anything, right from the switch to the bulb holder. You will have to check the entire circuit.
Where does it happen more often? Bangalore or Goa?
Old 25th April 2009, 12:34   #7
Thanked: 54 Times
hmm seems to be more likely the case, i guess i'll have to get my hands dirty and trace it out !
Happens everywhere, bangalore and goa both
Old 25th April 2009, 12:45   #8
vikram_d's Avatar
Thanked: 940 Times
Do the front & back indicators work properly? If they do then I suspect the bulb holder is the problem.
If none of the indicators work then I suspect it is a problem with the switch. The contacts must be worn out and the problem will be getting exaggerated by the heat.
A quick test that you can do is to park the car out in the sun for sometime and then try using the hazard lights. If the hazard lamps work then it is definitely a problem with the indicator switch.
Old 25th April 2009, 13:35   #9
Thanked: 54 Times
The hazard lights dont work either! i'm really baffled , i checked most of the things some half an hour ago! it all looks sane!
Old 25th April 2009, 13:41   #10
vikram_d's Avatar
Thanked: 940 Times
Check for any loose contact in the fuse box both under the dash board and also under the hood.
Old 25th April 2009, 23:42   #11
Thanked: 54 Times
vikram you were right ! today evening when i went out , the indicators stopped working completely! follwed the side indicator wires and there was a loose connection in the engine bay - there was a relay which was bolted to the body inside the engine bay, and under the bolt a 3-4 wires were grounded, looks like someone overtightened the bolt when i gave it for service last time around and the threads got damaged resulting in the loose connection, i replaced the bolt and now it seems to work fine.
I think the problem might have got solved, will have to wait till tomorrow for the sun to come up keeping my fingers crossed! But i'm still baffled about the heat part!
Old 26th April 2009, 09:05   #12
vikram_d's Avatar
Thanked: 940 Times
I'm glad you found the problem. Hope it does it not give you any more problems.
Sun Protection, without sun film - Options? tsk1979 Technical Stuff 55 17th December 2015 23:24
Not using side mirrors & indicators when shifting lanes = a trivial mistake? Think again! Tamarind Street Experiences 55 30th May 2015 16:42
Defogger not working / damaged after sun film fitting razor4077 Modifications & Accessories 56 21st May 2014 02:52
Brand new Swift ZDI : Glow plugs indicators not working manjubp Technical Stuff 10 13th January 2012 12:31
