Old 25th April 2009, 12:55   #1
gaurav_diavolo's Avatar
Thanked: 54 Times
Angry Ikon Indicator Stalk frightfully expensive!!!!
Hello ppl!! My left side indication does not autocut, when I enquired, there is no repairing, only replacement of entire stalk for such a small issue and guess what, its for over whopping 3 grands!
Is there any solution to it? Can a local mechanic fix it with 'jugaad' or should i get it replaced without thinking twice. Please suggest.
gaurav_diavolo is offline   Reply With Quote
Old 25th April 2009, 13:14   #2
Rudra Sen's Avatar
Thanked: 4,294 Times
Suggest you go for a new one. Local mechanic won't be able to fix that. Most of these return clips are made out of plastics. They'll try something and you can expect other issues coming up.
Alternatively you can try out second hand part market. May be you'll get a clean one from there.
Old 25th April 2009, 13:15   #3
nitrous's Avatar
Thanked: 285 Times
I've changed the combination switch twice in my Sumo.
3k is not expensive for a ford. Go for it.
Old 25th April 2009, 13:17   #4
Thanked: 39 Times
Well i had a problem with my switch assembly and had to change the whole unit (damages Rs.3600). The ford guys told me that this switch cannot be repaired and the whole thing has to be replaced. I also tried for some repair work locally but did not find some one who does it. So had to get it replaced since the head lights were not working.
dkhatau is offline   Reply With Quote
Ikon TDCI discontinued ? EDIT: Confirmed: Ford stops Ikon production greatmana2000 The Indian Car Scene 61 10th February 2011 19:20
Ford Ikon mod - fiesta head on ikon block? madhunm Modifications & Accessories 2 2nd July 2007 09:24
Ikon 1.3 v/s Ikon 1.6 normally_crazy Sedans 4 11th October 2004 13:42
World's 10 most expensive car auctions.. _Crazi4Speed_ Shifting gears 4 11th May 2004 07:44
