Old 25th April 2009, 17:55   #1
ralstonraz's Avatar
Default OHC 1.5 Type 1 compressor gone bad
My AC compressor has gone bad and needs to be changed.
Any suggestions where could I source a new one/ reconditioned one in Mumbai?
Which are the brands that I need to consider?
All help towards this is welcomed.
Tks
Ralston
ralstonraz is offline   Reply With Quote
Old 25th April 2009, 18:39   #2
manveet's Avatar
Thanked: 586 Times
Hey Ralston, you may refer this thread, it will answer all your Queries.
http://www.team-bhp.com/forum/techni...fo-advice.html (AC Compressor Problem: Info & Advice)
Cheers!
Edit: Mods you may merge and close this thread.
manveet is offline   Reply With Quote
Old 25th April 2009, 22:29   #3
Thanked: 660 Times
compressor can be repaired!! have you considered that.
BTW subros and sanden are oem for most manufacturer in india.
Old 25th April 2009, 22:39   #4
Thanked: 28 Times
Is it possible to open the compressor and service/repair it ? I have my doubts.
I have a spare sanden compressor, problem is that i have not sealed the inlets. Am i in trouble ?
Gurus please advice.
kavesh55 is offline   Reply With Quote
Old 26th April 2009, 00:08   #5
SS-Traveller's Avatar
Thanked: 11,630 Times
IIRC all HCs come with Denso AC compressors. Repair kits/spares for the same are not available in the market , so changing is the only option.
Was quoted Rs.16000 for equivalent Sanden/Subros compressors for HCs, plus service & labour costs of @Rs.2500 from my AC specialist.
@ kavesh: Not sealing the inlet/outlet may get dust inside, and cause failure. Get the insides cleaned out with a dry nitrogen blow and flush with compressor oil before installing/running/gas charging, and hope for the best.
Old 26th April 2009, 02:14   #6
manveet's Avatar
Thanked: 586 Times
Thats incorrect - OHC's came with Sanden's. The one I replaced and the one that went in was the same part no.
Old 26th April 2009, 02:24   #7
ankitahuja's Avatar
Thanked: 46 Times
Absolutely correct. OHC's OE A/C compressor is from Sanden.
Attaching pictures of the OE compressor and another part that is changed (sorry forgot the name) that I had sourced for a fellow BHPian's friend.
I just can't recall the cost
EDIT: @ralstonraz - IMHO avoid repair at any cost. The compressor can pack up again anytime or crack while opening.
ankitahuja is offline   (1) Thanks Reply With Quote
Old 5th May 2009, 12:31   #8
ralstonraz's Avatar
Thanks guys.
Spoke to a couple of AC guys too and even they recommended changing the entire compressor.
Got a quote of Sanden(original japnese) for 9.5k. In addition will have to change the drier/receiver too. The total cost should work out to around 12k.
It was hilarious when I wrote to Sanden, that they mentioned that they supply only to 's Honda. That's when I wrote back stating a person form their head office itself recommended by to one of the dealers in Mumbai. You should have seen the Sanden Head of Sales ------ He was at a loss of words!!! hahaha...
I plan to get this sorted next week. Will update you on how it goes.
Old 22nd May 2009, 16:58   #9
ralstonraz's Avatar
Done.
Compressor changed. Cooling back to normal.
Will post the pics a little later.
I am looking out for AC vents left and centre one above the ac blower switch.
Ac compressor gone bust? tsk1979 Technical Stuff 108 9th February 2017 00:13
5009 KMS-A'bad-Calicut-Bangy-Hyd-Aur'Bad-A'Bad-Report ramkya1 Travelogues 48 4th August 2010 00:04
Alto AC compressor gone bust amit_mechengg Technical Stuff 10 25th May 2010 22:11
Palio 1.6 ac compressor gone kaput kapilsharma80 Technical Stuff 3 3rd July 2009 16:33
My accident - Bad brakes, bad rain, bad luck... vezj420 Street Experiences 41 22nd May 2007 10:49
