Old 26th April 2009, 12:16   #1
Default Fiat Uno (non PS): Car steers by itself
I am experiencing a strange problem with my steering since yesterday. Well, it is not as scary as the title sounds - but still is a major problem.
Problem- When I apply accelerator the car steers by itself to the right a little bit and when I takes my foot off from the accelerator it steers to the left.
Background- I took my car for wheel alignment and found that the front left wheel has got a very bad free play. They told me to change the steering ball joint before doing the alignment. Called the authorized dealer to hear the usual "not available" reply. So called up MyTVS all car service - spare available but only for Power Steering version. Took it to the second MyTVS in the city - They rectified that the problem is not just with steering ball joint but also with the steel rod that it connects to. They mentioned some nylon bush had got torn away some time back which caused the steel rod to wear, which in turn might have caused the tooths of it break.. etc etc - Net result - needs some leith work.
I wanted my car badly that day itself and so I took off from there and gave the car to a local workshop and did all these work the next day. They did all necessary leith work and assembled them back. The pending work is to change the left lower arm (or the bush that comes with it) - they couldnt get the spare for it.
So, can a loose lower arm can cause the problem I mentioned above - The car steers by itselves?
Please advise - on the cause and remedy.
Thanks everybody in advance.
Abhiraj is offline   Reply With Quote
Old 26th April 2009, 18:57   #2
Default No response yet!!!
Any wild guess!!! Absolutely anything is welcome.
Meanwhile I am finding this newly added feature very useful while overtaking - I take care of the acceleration task and the car takes care of steering task.
Old 26th April 2009, 20:26   #3
MileCruncher's Avatar
Thanked: 357 Times
I also have a Non PS Uno and never had any problem with the steering, but have changed the lower arms twice I think. The lower arm has a rubber bush with which it is connected to the car body and the other end handles the wheels and the suspension and steering tierod. If any of the component develop play then the steering will not be straight and steer the car in a particular direction especially when power is applied (due to unequal distribution of torque thereby activating the differential as well).
MileCruncher is offline   Reply With Quote
Old 27th April 2009, 08:14   #4
BenjiRoss's Avatar
Thanked: 164 Times
Buddy.... the aliens have landed. Transformers part III is now real life!
Just my 2 cents. I don't have any tech knowledge for a better solution.
BenjiRoss is offline   Reply With Quote
Old 27th April 2009, 15:48   #5
This seems to be a convincing cause for the issue . So do I have to replace the whole lower arm or can I remove just the bush in it? Anyway let me check whether the bush is available.
Thanks...
Old 27th April 2009, 15:57   #6
ilangop's Avatar
Thanked: 591 Times
Are there any loose bolts from the suspension side, engine mounts, or steering joints. Are the CV joints proper?
ilangop is offline   Reply With Quote
Old 29th April 2009, 10:44   #7
Originally Posted by ilangop View Post
Took the car to another local workshop. No problem on these areas whatsoever...
Old 29th April 2009, 20:43   #8
Thanked: 103,710 Times
Have your ball joints, bushings, arms and struts checked. Something is either worn or broken.
Old 2nd May 2009, 18:09   #9
Default Issue Resolved; Replaced lower arm bush.
These were verified at the local workshop but they told everything is fine including the lower arm bushes. The wheel didnt move at all when they tried to shake it. But in fact the issue was with the lower arm bushes.
This exactly was the issue. Though in Uno, lower arm is triangular shaped in which 2 ends have bush. The ends having bush are connected to body and the other end to wheel assembly. Both the bushes were worn out (just a little). So I was very much apprehensive about the resolution when the mechanic told about replacing them. But once I test drove after fitting them back it was altogether a different story - no issues at all. Never thought such a small thing can have such a drastic impact .
The authorized service centre would have replaced the complete lower arm for the same issue.
Thanks everybody for your support.
Old 4th May 2009, 06:35   #10
Thanked: 357 Times
Hey Abhiraj, good to know that your problem is solved. One thing that I have learned through my ownership of the Uno is that you really (I cannot emphasise this enough)need to know your car. Most of the normal mechanics including authorised service station don't have too much clue about the car and scarcity of spares makes the whole thing even more difficult.
Enjoy your car and happy driving
Old 13th June 2009, 08:27   #11
shineshine's Avatar
Thanked: 37 Times
I am also experiencing the same with my Palio. Although there is no toruqe steer, I could hear loud metal to metal noises when going through rough patches of roads and severe vibrations all over the body. On visual inspection, I could see the rubber bush on Front Right lower joint being worn out.
I had replaced the right and left ball joints almost 2000 kms back and it even did not hold up to 2000 kms. When I consulted with the spare parts shop, they said that its beacuse of the inappropriate method of hammering when replacing makes the joint less reliable. Both removal and insertion has to be done in a professionally qualified workshop.
btw, the ball joint comes around 450- 650 and the entire lower arm with joint comes around 1750 in local shops. The original lowerarm with joint comes around 3500 in authorised shops.
shineshine is offline   Reply With Quote
Old 13th June 2009, 08:51   #12
Thanked: 357 Times
I guess you have no option but to go the Authorised workshop or to a Fiat Specialist. Another thing that i have learnt over the years is not every mechanic is capable of fixing a Fiat because of intricate mechanisms. So take care and keep us updated.
Old 13th June 2009, 23:54   #13
nickname your car as TARZAN the WONDERful CAR
passion4cars is offline   Reply With Quote
Old 14th June 2009, 00:49   #14
Thanked: 13 Times
Wow thats indeed a great suggestion.That would, in all probability solve his problem
aravindwarrier is offline   Reply With Quote
Numero Uno : Fiat Uno hillram Test-Drives & Initial Ownership Reports 84 29th November 2012 11:32
Swift Diesel Steers towards the left. tush Technical Stuff 132 29th September 2010 10:22
Progetto di restauro FIAT Uno (Uno Restoration) arununo Technical Stuff 35 6th May 2010 10:44
The Fiat Grande Punto - will history repeat itself yet again? Sawyer The Indian Car Scene 80 13th July 2009 11:45
