Old 27th April 2009, 11:17   #1
mithun's Avatar
Thanked: 49 Times
Wink Battery Terminal Coat - It it worth ?
Is this Battery Terminal Coat worth the purchase or is this another marketing gimmick ?
In lieu of this, can we use the good ol' cheap White Petroleum Jelly ?
Old 27th April 2009, 11:55   #2
Prowler's Avatar
Thanked: 285 Times
I don't know about 3M product. But I have seen my UPS guys using some imported spray coat which gives much better protection than the normal petroleum jelly. The problem with Petroleum jelly is, you need to apply them after cleaning the contacts, terminals with an abrasive for best protection.
This spray appears to penetrate the outer surface and saves you the hassles of cleaning beforehand.
Prowler is offline   Reply With Quote
Old 27th April 2009, 12:08   #3
gpa
gpa's Avatar
Thanked: 274 Times
I read thru the link and IMHO, I would stick to good 'ol petroleum jelly
Cheers,
gpa
Old 27th April 2009, 12:30   #4
Hyundai Service Centre uses a similar spray. Not sure whether it is 3M or something else. Terminal will be in blue colour.
varma is offline   Reply With Quote
Old 27th April 2009, 12:31   #5
Thanked: 252 Times
Mithun, if you don't mind the cost of it, by all means go ahead and use it!
Petroleum Jelly is a simple to procure and very inexpensive solution (or jelly!).
Volvo Lounge @ Terminal 3, IGI Airport, New Delhi rajneeesh The Indian Car Scene 1 8th November 2014 21:09
Airport-like Bus Terminal in Vadodara, GJ Mpower Commercial Vehicles 18 14th October 2014 13:20
Hot Battery terminal? humm Technical Stuff 7 13th January 2010 00:31
Panasonic Base Terminal - Useless Battery indicator tsk1979 Technical Stuff 6 12th July 2009 16:37
