Old 16th June 2010, 10:50   #16
aargee's Avatar
Thanked: 2,143 Times
@Jino - Check out the specification & capacity to be filled regarding the coolant in your Owner's manual. Isn't this information available there?
Old 16th June 2010, 13:04   #17
Thanked: 436 Times
The coolant capacity is not mentioned in the Alto User Manual. I called the service center, but they say they are not sure because they fill coolant + water till the reservoir is full (I think they are trying to trick me into buying coolant from them).
jinojohnt is offline   Reply With Quote
Old 16th June 2010, 13:45   #18
anky's Avatar
Thanked: 107 Times
Red face Alto lx 3.5lts
Hi alto lx 3.5lts and vx 4.0lts mind u not a refill but full flush of radiator.
anky is offline   Reply With Quote
Old 16th June 2010, 14:46   #19
Thanked: 436 Times
Thanks anky for the info. I am planning for a full flush and replacement of coolant for my Alto Lxi 2008.
I have bought only 1 liter of coolant (1:2 coolant with water means total 3 liters only). That means I need to buy more coolant if I need total 3.5 liters of coolant + water.
Do you suggest anything that I need to look for, when I change the coolant at the work shop? Is it necessary to dismantle the coolant reservoir completely to flush out the old coolant?
Old 20th June 2010, 13:47   #20
Thanked: 436 Times
@anky,
I got the coolant changed in my Alto Lxi (2008), but I needed only 2.5 liters of "coolant + water" (not 3.5 liters as you suggested).
Did you get the info (verbally) from a mechanic or have you got the coolant changed by the mechanic in your presence?
I am worried that the one liter difference may be because the coolant may not have reached all necessary parts in my car (may be due to air bubbles).
I opened the radiator cap (top) when I reached home, and added some more coolant (around 100 ml) so that the coolant level in the radiator reaches the maximum possible (till the radidator cap). Do I need to check for anything else?
Coolant liquid leakage wanderlustindia Technical Stuff 32 30th April 2018 19:11
Hyundai Santro: Coolant Leakage from a strange location ghpk Technical Stuff 19 25th March 2015 07:29
Coolant Leakage in Esteem VX-2001 dev_kudle Technical Stuff 68 18th May 2011 23:02
Hyundai Accent coolant leakage problem livyodream Technical Stuff 3 16th June 2010 13:05
