Old 3rd June 2010, 21:03   #16
smokin's Avatar
Thanked: 13 Times
Originally Posted by greenhorn View Post
could you please elaborate which swifts come with H8 and which ones have H11?
Originally Posted by anantnehru View Post
Sx4 - H7/H8
Swift - H7/H8/H11 is I remember correctly. Maybe not H8. Never really figured out for both.
But usually most after market fog lights are H3. Meant to be more powerful.
h8 and h11 model is the same nothing is different in these two so you can look out for any one of it
smokin is offline   Reply With Quote
Old 4th June 2010, 12:33   #17
bottle's Avatar
Thanked: 138 Times
Palio Stile
Low - H7
High - H7
Fog - H1
Retro Palio
Low - H7
High - H1
Fog - forgot!
bottle is offline   Reply With Quote
Old 4th June 2010, 12:54   #18
Sankar's Avatar
Thanked: 4,637 Times
A-Star:
Headlamp - H4
Foglamp - H8
Yes, physically they're identical and swappable. Where these bulb differs is in wattage, H8 is 35W intended to be used as fog/aux driving lamp, and H11 is 55W and also used as headlamp bulbs. Higher wattages are available in H11.
Old 4th June 2010, 13:05   #19
aaggoswami's Avatar
Thanked: 1,541 Times
What is major difference between H1 and H7 ? Both of them have almost identical ratings for Watt and lumens ?
Almost all Maruti Suzuki cars with single filament headlamps come with H4 for hi/low beam. IIRC, the bulbs are common across almost the entire range.
aaggoswami is offline   Reply With Quote
Old 5th June 2010, 18:40   #20
bottle's Avatar
Thanked: 138 Times
^H7 has blacked out tip , I guess intended use is for low beam ?
H4 has 2 filaments for high/low beam afaik
Old 5th June 2010, 23:53   #21
Thanked: 356 Times
What are the stock bulbs in the 2004 Alto, 2008 Honda City(NHC) and 2008 Ford Fusion?
wildsdi5530 is offline   Reply With Quote
Old 6th June 2010, 21:44   #22
vivekgk's Avatar
Thanked: 433 Times
@wildsdi5530 : Alto comes with H4 headlamps.
Tata Indigo/Marina:
Pre-facelift (2002-Oct 2006) - H4
Post-facelift (Oct 2006-current) - H7 - Lo, H1 - Hi
Indigo CS
Pre-2009 - H4
2009+ - H7 - Lo, H1 - Hi
No idea about fog lamps though.
vivekgk is offline   Reply With Quote
Old 7th June 2010, 03:39   #23
iamback's Avatar
Originally Posted by agbenny View Post
Willing to change for my Scorpio? Recommendations? Thanks in Advance.
Mahindra Scorpio : Main - H4 - P43t
@agbenny this thread is only for bulb types. For any help regarding headlight upgrade visit Auto Lightning Thread
iamback is offline   Reply With Quote
Old 7th June 2010, 06:46   #24
ImmortalZ's Avatar
Thanked: 312 Times
Honda Civic (2006 -)
Low beam : 9006 (51W)
High beam : 9005 (60W)
Fog lamp : 9006 (51W)
ImmortalZ is offline   (1) Thanks Reply With Quote
Old 7th June 2010, 12:11   #25
agbenny's Avatar
Thanked: 115 Times
Sorry, My question had lack of clarity. I wanted to replace the stock bulbs.
Thanks for the suggestion.
I changed to Philips H4, But didn't touch the fog lamps, I wish I could do that too, But budget didn't permit.
agbenny is offline   Reply With Quote
Old 14th June 2010, 11:52   #26
ImmortalZ's Avatar
Thanked: 312 Times
Originally Posted by absynthguzzler View Post
what bulb is it for Honda CRV Low beam ? This is a 2005 model prior to the newer generation one being sold now.
The CR-V until 2004 used H4 for both low and high beam and HB4 (9006) for fogs. The 2005+ CR-V used projectors for low beam (D2S I believe) and HB3 (9005) for high beam.
Old 16th December 2010, 23:09   #27
Thanked: 356 Times
Default Re: Stock bulb types of indian cars.
Ford figo : H4 60/55
Old 14th February 2011, 20:20   #28
Thanked: 12 Times
Default Re: Toyota Corolla/Corolla Altis
High Beam - HB3/9005 halogen 60W
Low Beam - HB4/9006 halogen 51W or D2R 35W HID lamp (Altis)
Fog Lamp - H11 halogen 55W
Rgds,
I have my Altis' low beam bulb in my hand and it reads HB3 9005 / 12 V / 60W ECE / 65W SAE.
On a side note, what is the best place to find a replacement bulb in New Delhi? The dealership quotes me 8.5k for one bulb!
ricky_speed is offline   Reply With Quote
Old 30th January 2012, 16:11   #29
Thanked: 34 Times
Hi Bhpians,
whats the Fog lamp bulb type for Mahindra scorpio (Latest Model). the headlight one is H4. kindly advice me as to the bulb type for Mahindra Scorpio's Fog Lamps.
Gocool2007 is offline   Reply With Quote
Old 30th January 2012, 18:44   #30
sagarpadaki's Avatar
Thanked: 1,337 Times
Originally Posted by Gocool2007
Hi Bhpians,
Its H8 type socket for fog lamp
Different types of Clutches ...? amitoj Technical Stuff 12 7th April 2010 13:29
Types of M Lancers Vulken Auto Technical Stuff 15 26th October 2005 00:22
Top Speeds of Stock Indian Cars Technocrat The Indian Car Scene 2 13th May 2005 13:55
Types of S-Class Stratos The International Automotive Scene 9 24th April 2004 04:32
