Old 16th August 2013, 14:05   #31
Thanked: 16 Times
Default Re: Toyota Corolla/Corolla Altis
Toyota absolutely rips off when it comes to bulbs - asking for 11k for D4R bulb. Can anyone share inputs on who can ship /courier / sell a pair in bangalore?
Originally Posted by ricky_speed View Post
I have my Altis' low beam bulb in my hand and it reads HB3 9005 / 12 V / 60W ECE / 65W SAE.
On a side note, what is the best place to find a replacement bulb in New Delhi? The dealership quotes me 8.5k for one bulb!
vivekrvcse is offline   Reply With Quote
Old 16th August 2013, 15:05   #32
Thanked: 12 Times
Correction: The HB3 Bulb I mentioned was the High Beam bulb. The D4R is the correct low beam bulb and I got it at about 3k from a Philips authorized reseller instead of 10k that the dealership was asking. Just look for authorized resellers of Philips on the website and call them up to check availability.
I bought my D4R from Parnamai Enterprises in Gurgaon. The owner is pretty awesome - he agreed to change the bulb without hassle since I first bought the wrong model.
Of course, the philips distributor won't install the bulb. In my case, the galaxy toyota folks in Okhla sent back my driver when I sent him to install the bulb that I bought outside despite it being the exact same make and model that the dealership supplied . So I got it fitted at a local mechanic who took 1 hr but did the job finally!
ricky_speed is offline   Reply With Quote
Old 16th August 2013, 16:20   #33
getsurya's Avatar
Thanked: 967 Times
Can somebody give me the fog lamp bulb specifications for the new Fortuner?
Thank you in advance!
getsurya is offline   Reply With Quote
Old 15th June 2014, 11:42   #34
drmohitg's Avatar
Thanked: 3,843 Times
Default Re: Stock bulb types of indian cars.
Reviving an old thread. What is the bulb set up in headlight of Altis? Are there 2 separate bulbs for low beam and high beam or a single one? I just got my car repaired and the front right side headlight had to be replaced. The dealership has charged me for 2 bulbs amounting to Rs 1.1k each and the insurance company is hell bent on counting it as consumable and hence I need to pay for them.
drmohitg is online now   Reply With Quote
Old 22nd June 2014, 09:51   #35
Thanked: 12 Times
As I've written above, its D4R for low beam and HB3 for high beam. Which one shows on your invoice? The D4R costs 10k+ at the dealership so it cant be that. My altis came with spare HB3's so I wonder if they restocked your spares? Perhaps you had a missing spare so they charged you for two? In either case they have to consult with you before charging you!
EDIT: Typical insurance doesn't pay for electronics.
PS: A good way to find the new bulb is to compare the brightness in a dark place.
Above is for petrol corolla altis highest spec at time of launch.
Old 22nd June 2014, 10:04   #36
drmohitg's Avatar
Default Stock bulb types of indian cars.
As I've written above, its D4R for low beam and HB3 for high beam. Which one shows on your invoice? The D4R costs 10k+ at the dealership so it cant be that. My altis came with spare HB3's so I wonder if they restocked your spares? Perhaps you had a missing spare so they charged you for two? In either case they have to consult with you before charging you.
They have charged me for two bulbs, both costing Rs 1100. The d4r that you have mentioned must be the HID ones. Mine is the mid variant.
Old 22nd June 2014, 14:25   #37
arunphilip's Avatar
Thanked: 4,825 Times
Ford EcoSport
Headlamp: H4
Fog lamp: H11
Front indicators: PY21W
Rear brake lamp: P21/5W
Rear fog lamp: P21W
Reverse lamp: P21W
Rear indicators: PY21W
Side indicator: WY5W
arunphilip is offline   Reply With Quote
Old 22nd June 2014, 14:31   #38
mukeshgoel's Avatar
Thanked: 385 Times
VW Polo
Headlamp: H4
mukeshgoel is offline   Reply With Quote
Old 22nd June 2014, 16:10   #39
vigsom's Avatar
Thanked: 604 Times
As far as I know the HB3 9005 is the hi beam bulb while the HB4 9006 is for the low beam.
Both are single filament bulbs and retail at approx Rs.300 each for the Philips make.
Old 23rd June 2014, 10:10   #40
Can anyone help me to replace my Scorpio (mHawk 2009 model) brake light bulb? What is the bulb type? Appreciate if you can specify the bulb type for brake lights and reverse light too. Thanks
AnilRaj is offline   Reply With Quote
Old 29th July 2014, 15:22   #41
meetbadri's Avatar
Thanked: 77 Times
Suzuki Ritz
Headlamp: H4 (60/55W)
Fog lamp: H8 (35 W) but can be upgraded to H11 (55 W)
meetbadri is offline   Reply With Quote
Old 13th November 2014, 17:58   #42
DRIVE_ADDICT's Avatar
Thanked: 181 Times
Can someone throw some information on Figo's fog lamp bulb spec.
DRIVE_ADDICT is offline   Reply With Quote
Old 7th November 2016, 21:18   #43
New Scorpio 2014
Low - H7
High - H7
Fog - H1
Static Bending - H1
petersurya is offline   Reply With Quote
Old 10th April 2017, 14:02   #44
Thanked: 16 Times
Can anyone share the bulb type for Santa Fe? 2014 model
Old 11th April 2017, 03:12   #45
avinash_clt's Avatar
Thanked: 930 Times
Default Hyundai Santa Fe III (DM) bulb specifications
Assuming 2014 variants means the third generation Hyundai Santa Fe (DM), I am attaching a snippet from the owner's manual for the car. All the bulb types are specified in it, you could reconfirm with your owner's manual too
Name:  Hyundai Sante Fe III DM bulb specifications.JPG
Source. To check, I randomly compared some of the bulb applications using a Osram vehicle bulb finder tool and it seems to be correct.
Cheers,
Avinash
avinash_clt is offline   (1) Thanks Reply With Quote
Different types of Clutches ...? amitoj Technical Stuff 12 7th April 2010 13:29
Types of M Lancers Vulken Auto Technical Stuff 15 26th October 2005 00:22
Top Speeds of Stock Indian Cars Technocrat The Indian Car Scene 2 13th May 2005 13:55
Types of S-Class Stratos The International Automotive Scene 9 24th April 2004 04:32
