Old 25th May 2009, 22:04   #16
Originally Posted by VeeTee View Post
Also as the temperature raises, the coolant is
as much as 40%.
Dude,
Good explanation, I must say, you sound like an Engineer.
arun.m is offline   Reply With Quote
Old 26th May 2009, 12:32   #17
Thanked: 18 Times
Can anybody suggest how to get this problem sorted out? Do we need to change EGR valve, if yes how much it will cost?
mandyrana is offline   Reply With Quote
Old 26th May 2009, 13:01   #18
Default Re: Indigo CS Diesel Fuel
I need your help, I need to know which fuel is ideal for Tata Diesel car like Indigo CS diesel to get maximum fuel benefit and low maintenance?
Thanks in advance.
Later.
Old 4th June 2009, 21:29   #19
neel385's Avatar
Thanked: 401 Times
Well if you have gone through the earlier posts, you would have realised that the problem fundamentally is with the temperature of the intake air,so, probably the only thing that can make a difference will be a CAI. Removing the EGR will help because EGR essentially also cuts down on power, but, the issue being discussed will not be addressed.
neel385 is offline   Reply With Quote
Old 4th June 2009, 22:54   #20
greenhorn's Avatar
Thanked: 1,318 Times
Originally Posted by arun.m View Post
Thanks in advance.
Later.
use regular diesel with iftex system D
and a good engine oil like Mobil Delvac MX
Old 22nd June 2009, 14:24   #21
Thanked: 18 Times
I went to TASS last week , they said fuel pump needs to re-calibrated. I observed that temprature needle was slightly above half mark. A/C was on. I switched off the a/c still there was power loss. How to check whether EGR valve is working fine or not for my Indigo?
Old 22nd June 2009, 20:28   #22
trrk's Avatar
Thanked: 12 Times
See if this helps:
Yahoo! Groups
trrk is offline   Reply With Quote
Old 27th August 2009, 22:46   #23
HIGHNOON's Avatar
Thanked: 56 Times
Hi Buddy,
I got hold of a less run Indigo bs2 from a friend. car is in great shape. Engine is as good as it can get. Good pickup , almost no vibrations in the cabin except the gear knob. very smooth and quite silent on highway. have got full service done with all lubes changed , all filters changed. Coolant drained , flushed and replaced with new. All brakes serviced and wheels are rotating free with new bearings.
Now problem is that when i am struck up B2B traffic on hot afternoons , the damn thing becomes something else. Becomes very sluggish , vibrates noticeably , sounds rough and noise levels are higher too.This happens on AC or otherwise.
You reckon a weakened EGR valve is the culprit ?
On cooler days / when its raining or at mornings / nights this does not occur.
HIGHNOON is offline   Reply With Quote
Old 28th August 2009, 14:02   #24
teknophobia's Avatar
Thanked: 22 Times
It's perfectly normal, you'll notice this on new cars too
teknophobia is offline   Reply With Quote
Old 28th August 2009, 22:13   #25
HIGHNOON's Avatar
Thanked: 56 Times
I hope so. I got the car checked at Fortune , Powai. The EGR was functioning alright.
Is it so that the particular time when he checked it the car was behaving normally. Had taken a half an hour stop at Military road. So the car just didnt have time to heat up. Also traffic was fast moving.
My question is ' IS the EGR VALVE solenoid fails when its hot and the slightly weakened EGR valve is functioning almost alright under rest of the conditions ? So it malfunctions only when its really hot and its B2B TRAFFIC and the at other times car behaves ...well normally.
I mean the car is in absolutely prime condition.
@ GREENHORN ! Could it be anything related to FIP?
Old 29th August 2009, 15:54   #26
Thanked: 22 Times
Read the posts at the beginning of the thread, you'll find out why this happens, it's not a technical fault, it is because of the laws of physics.
Yamaha R15 - Engine feeling sluggish fusionbang Motorbikes 24 26th March 2014 07:01
Can the DiCOR engine on an Indigo be replaced with a TDi engine? cnaganathan Technical Stuff 11 5th March 2012 12:54
Figo TDCi EXi vs Indigo CS LX TDi. Update: Its the Indigo. vivekgk What Car? 32 22nd November 2010 21:59
Sluggish Accent CRDI after engine rebuild. clipto333 Technical Stuff 30 10th March 2008 23:44
