Old 5th May 2009, 10:57   #16
amit_mechengg's Avatar
Thanked: 1,556 Times
"have a Green Twister CAI, full FFE, 76mm high comp pistons, Exedy Stage 1 clutch, custom gear ratios and a standalone RD ECU directing the show".
posted by blackmagic. 3rd gear and redlined
Old 7th May 2009, 02:02   #17
Thanked: 12 Times
Amit, didnt quite understand what you were trying to convey. once more?
by the way, she is back and kicking. a lot of fine tuning is required though. Im gonna use this opportunity to iron out every kink. could not find a new engine mounting bracket ANYWHERE. so used one from a condemned car. it is slightly bent, but is holding okay.
the mechanic with all his good intentions left one strut assembly untouched [LHS] and changed only the damaged strut [RHS]. now I have three stiffened shock absorbers and one stock. handling is all over the place and the steering is all wonky at high speed. she also pulls sharply to the left when braking at high speed.
now the plan is to get her painted and in decent enough shape to reach Bangalore safely where the good folks at RD should make her leaner, meaner and better than before.
all said, the most important part has not changed one bit. for that I thank my lucky stars. when powershifting, there is wheelspin in 4th gear!
blacmagic is offline   Reply With Quote
Old 7th May 2009, 09:56   #18
someone here was doubting a honda city doing speeds of 200kmph. so i just quoted that its not a stock. happy revving. yours is a damn fast car.
Chevrolet Cruze Recall in India (PVC bracket in the engine bay) ghostrider The Indian Car Scene 15 9th January 2015 17:14
This car (also) climbed Mount Washington & Mount Mansfield, VT amitoj Travelogues 30 12th October 2013 01:35
What is engine type in OHC 1.5? Prelude2000 Technical Stuff 22 27th April 2010 16:09
Swap: Vtec engine into OHC Type I crazydiablo Modifications & Accessories 7 28th September 2007 00:13
