Old 5th August 2008, 14:47   #31
abhik's Avatar
Originally Posted by Deeps View Post
Abhik, Are you the guy I met at Janpath on an afternoon a few weeks back checking out the palio??
Ya that was me! Good to hear from you!
abhik is offline   Reply With Quote
Old 5th August 2008, 21:32   #32
Deeps's Avatar
Thanked: 68 Times
Indeed. You own a CNG car?? Details. Any reviews?
Deeps is online now   Reply With Quote
Old 5th August 2008, 23:27   #33
phamilyman's Avatar
Thanked: 3,526 Times
Surely, you're kidding, Deeps!!
Old 6th August 2008, 20:13   #34
Deeps's Avatar
Thanked: 68 Times
Got my answer, hits...
Old 7th August 2008, 14:35   #35
abhik's Avatar
Didnt get you guys here????
Old 9th August 2008, 18:33   #36
Thanked: 132 Times
Originally Posted by amitverma View Post
thats the main issue. i havent come across anyone who has a CNG kit fitted in their palio. while i do understand that the car would face a strong lag in performance but i reckon when i wud have CNG fitted i wud not hesitate to drive in higher revs, isnt it?
do not confuse me with a boring driver. i am all for performance and high revving but when u see the fuel gauge needle coming down like a rocket, you tend to switch to a more subtle driving style. monetory issues is a....#$%^&.
Hi Amit,
Any updates on getting CNG installed on your Palio. I am also just gonna start researching with the CNG kitwallas in Bombay and see what they advise. Do keep us posted on your latest..
Cheers,
Sahakar
sahakar is offline   Reply With Quote
Old 11th August 2008, 15:49   #37
amitverma's Avatar
Hi
its no longer a question of if and what but rather a question of when. its a hefty investment of around ~40k and I dont want to put this burden on my parents. So it turns out I am in the process of bounty hunting.
So if anyone here wants to take advantage of a web-developer desperately in need for money for a CNG kit, may kindly contact me
amitverma is offline   Reply With Quote
Old 20th August 2008, 17:25   #38
HI
I am in the same boat here, want to get cng on my palio gtx, could anyone in delhi hook me up with contact info of some intelligent fitters here ( esp in noida)
i dont think i can afford the sequential kit, prolly with go with TAP or lamda...all suggestions are welcome
peace
A
afterburn is offline   Reply With Quote
Old 27th August 2008, 10:44   #39
amitverma's Avatar
took the plunge. got the kit installed last week.
first of, its better to look at petrol pumps now. i dont get scared of them anymore.
but the car is slow off the line. i mean...SLLOOOWWWW.
how do i get some help here. after 3rd gear, its fine.
also tell me what all to do to make performance better. i am not talking petrol-whipping performance but atleast, something..?
for example, spark plugs positioning etc.
also tell me what difference would a TAP make? would it be absolutely friggin awesome or "dude, where did the money go" kind of thing?
help needed.
Old 27th August 2008, 20:08   #40
An ECU remap can probably help.
e1t1bet is offline   Reply With Quote
Old 28th August 2008, 10:52   #41
abhik's Avatar
Remaps are only available for VAG cars now so forget remaps.
Old 28th August 2008, 10:58   #42
abhik's Avatar
help needed.
Get A TAP, i always recommended that to you else the Palio 1.2 will remain SLOWWWWWW.
Get a high-flow filter and a cat-back exhaust or a full FFE, will not make a huge difference in performance but you will surely like it as torque would increase, stick to the original diameter of the intake pipe. Colder plugs again definately help CNG combustion so go for Iridiums or Platinums.
But your First priority would be a TAP. It will atleast get you what you had on petrol.
Old 28th August 2008, 14:27   #43
extreme_torque's Avatar
Thanked: 1,489 Times
Pardon me but whats TAP?
extreme_torque is offline   Reply With Quote
Old 28th August 2008, 14:54   #44
abhik's Avatar
Timing Advancer Program-Electronic device which has presets(usually 3 maps/presets) inbuit maps/programs to advance the timing when the vehicle is running on CNG to increase pick-up of the vehicle and overall performance.
Basically TAP works best in an open loop kit as gas which is, induced through the air-intake is, not regulated(timed). Open- loop works like a carb system, the flow of fuel is constant with air-intake so timing the ignition at a faster rate helps combustion of the gas faster and less is left unburnt.
Old 28th August 2008, 16:45   #45
Isn't a closed loop kit better? How about an closed loop kit with TAP and Lambda Sensor?
CNG Oil Change - Regular or any CNG specials? panky12345 Technical Stuff 5 20th May 2016 11:56
Wagon R LXI CNG Vs Wagon R VXI + CNG Kit ajay387 Hatchbacks 37 7th October 2013 22:54
Company Workhorse : New Eeco 5 seater CNG or Used Dzire + CNG kit? NMM What Car? 2 4th February 2013 19:29
Swift Lxi (CNG Fitted) vs Santro GLS (CNG) coolaxe Hatchbacks 18 28th June 2012 16:58
