Old 4th May 2009, 12:54   #1
althaaf's Avatar
Thanked: 59 Times
Thumbs up santro zip plus engine over rev problem
Hi friends,
I have a 2001 santro zip plus ls run around 57000 kms. recently i noticed that when driving at a normal speed and and if i press the clutch to change the gear, after removing my legs off the accelerator, the engine continues to maintain the rpm. that is the acceleration or rpm is not coming down even if i take my foot off the accelerator. but if i wait for some more time, the acceleration or the rpm comes to normal. because of this high rpm being maintained, my cars fuel economy has reduced and the engine is getting heated up very fast. hope i explained my doubt clearly. please guru's and expert bhpian's help. suggest me the reason for this problem and what to do to avoid this issue. how much expensive it will be? my engine oil will be changed by tomorrow.
please reply back
thanks in advance.
althaaf is offline   Reply With Quote
Old 4th May 2009, 13:00   #2
suren181's Avatar
No expert here, but I guess you need to get the throttle body in your car cleaned up.
I used to face a similar problem in my Santro too sometime back and when the TB cleaning did not work, I realized it may have been the fuel quality. Drained the tank out, poured in fuel from my trusted pump and the problem vanished soon after.
suren181 is offline   Reply With Quote
Old 4th May 2009, 13:39   #3
ghpk's Avatar
Thanked: 193 Times
must be a stiff accelerator cable or Lever, you can get it checked and cleaned, it should give you the throttle operation back to normal.
while car engine is OFF Try to press the lever with hand and see if its coming back up slowly or instantly, it it comes back in slow motion (hydraulic motion) its jammed somewhere.
Old 4th May 2009, 15:15   #4
althaaf's Avatar
Thanked: 59 Times
Thumbs up thanks buddy
i dont think it should be fuel prob as i tried it in various pumps and no change in rev at idle and while running. i dont know about throttle body cleaning. i ll try telling this to the mechanic. recently i noticed a few drops of oil in the car porch after i park it inside. i have noticed that this happens only if the car is too hot. any idea dude?
no dude, i already checked accelerator cable thing, its free. its comming back to normal immediately.
by the way, do you have any idea if any problem with the clutch can cause this prob?
Old 12th October 2009, 19:56   #5
I recently bought a used Santro LE (2001) and it too had the same described problem. I took it to Trident Service on the Intermediate ring road, Bangalore. The guy said he'll try cleaning the Throttle body as part of the regular service that I'd wanted done. Since he also had to replace the air filter (due replacement) the problem only manifested bigger after the full service. He then said it needs an "Idle speed actuator" replacement and that it would put a Rs.5500/- worth hole in my pocket - and that's beside an already expensive service
Just wanted to check with the experts here - did anybody here get their problem fixed? If yes, did you have to change the ISA? Is there any other "fix" to the ISA that a probably-talented mechanic can do instead of replacing it to buy a bit more time? (I'm already over budget!) How do I rule out other fixes before going in for an ISA replacement?
PS: I did hear that the ISA costs only Rs.1500/- or so from the stolen parts market in Shivaji nagar. But I believe its important for not only me, but each of us to stop incentivizing stolen parts. On the lines of how some wildlife campaign slogan says "If the buying stops, the stealing can too".
sunson is offline   Reply With Quote
Old 22nd December 2014, 23:32   #6
pavan_6818's Avatar
Default Re: santro zip plus engine over rev problem
Originally Posted by althaaf View Post
Hi friends,
Mate,
Apologies for using the very old thread. I have the same problem with my Santro 2001 ZipDrive.
What was the cause and solution to this problem, please help me.
pavan_6818 is offline   Reply With Quote
Old 22nd December 2014, 23:46   #7
humyum's Avatar
Thanked: 2,503 Times
Originally Posted by pavan_6818 View Post
Mate,
I think it could be the Accelerator Cable or the Throttle body. None of them are expensive fixes.
humyum is offline   (1) Thanks Reply With Quote
Old 22nd December 2014, 23:54   #8
pavan_6818's Avatar
If it is due to Accelerator cable, why does it persist only when the AC is ON. Not sure what is throttle body (limited gyan on cars).
Old 22nd December 2014, 23:58   #9
humyum's Avatar
Oh It comes only with the AC on, Sorry I did not know that. It's 99.99% the idle speed actuator then.
Old 23rd December 2014, 00:14   #10
Thanked: 130 Times
That's a part of normal running, idle rpm is increased when the ac switches on. Let a mechanic see the car, in case the increase is too much.
fighterace is offline   Reply With Quote
Old 23rd December 2014, 13:25   #11
Thanked: 11 Times
Mate,
I think its due to a sensor which controls the engine RPM. Clean the sensor with petrol by a local mechanic. the sensor may not work accurately due to rust or dust deposits. if that did not work , test with a new sensor if the rpm comes down then change it. i am sure this will work
svpatra is offline   Reply With Quote
Old 23rd December 2014, 14:02   #12
pavan_6818's Avatar
I have recently serviced the car and found this issue after servicing, not sure if it persist prior to servicing since not observed much.
How much would the sensor cost?
Old 23rd December 2014, 16:50   #13
Thanked: 11 Times
if this has happened after the servicing then water must have gone to the sensor. The service guy may have used high pressure while cleaning the engine bay. my suggestion would be clean the sensor carefully with petrol.
its appox 5000 bucks
Old 23rd December 2014, 17:31   #14
Thanked: 130 Times
Sensors are tough, they don't go bad easily. take the opinion of a good independent mechanic along with the HASS before replacing it. More often than not its an air leak in the IAC system. Even if the sensor is gone, try getting a used one from a written-off vehicle. If it is due to water damage, ask for a free replacement as Hyundai explicitly forbids pressure cleaning of the engine.
All the best.
2 problems with Santro Zip plus!!! loving_alaap Technical Stuff 2 27th April 2009 18:12
Santro Zip Plus LS 2002 - 74,000kms review suren181 Long-Term Ownership Reviews 29 17th July 2008 18:21
Urgently Wanted Santro GS Zip Plus BUSA Shifting gears 0 3rd September 2006 17:22
Width of Santro Zip Plus psynaps3 Hatchbacks 4 15th April 2006 23:14
