| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Jun 2006 Location: Trivandrum
| I have my Palio 1.2 fitted with LPG Kit and has run almost 10K kms on LPG. Recently I have noticed that the Petrol level keeps coming down even its being run on LPG. The car runs fine on LPG with no traces of petrol being consumed along with LPG (No misfires, no rich mixture smell). Since the Fuel pump is detached automatically by Electronic control switch on LPG Mode, there is no chance of getting Petrol being pumped into the engine. Still the petrol level keeps on coming down. The Kit is of Indian make (HOVEL) and the emulator and Switch of some J.S(Indian Make). Please let me know the reason for this prob. If you have some contact with any LPG GURUs; please explain this problem to them and get me some checkpoints.
__________________ | Fiat Palio 1.2 | Fiat 118NE (Sold) | Honda Unicorn | Honda Eterno | Kinetic Kine | Hero Winner (Sold) | Bajak Chetak (Sold) |
| | #2 (permalink) | |
| BHPian | Quote:
Check with your installer, may be he forgot to connect the fuel pump to the LPG controller. Last edited by live2drive : 4th May 2009 at 21:12. | |
| | #4 (permalink) |
| BHPian | Correct working of Petrol shutoff valve is one reason. Secondly, ensure that the fuel mode changes to LPG before start moving the car. In some cases, the fuel mode changes to LPG only after revving the engine to 1500-2000 rpm. So the car will run comfortably in petrol mode if driven slowly untill the rpm crosses that range. This happens to many people.
__________________ LPG run SWIFT rolls on YOKOHAMA ADVAN NEOVAS :P |
| | #5 (permalink) |
| I am yet to check up with what Live2drive has said. Sir Alec, It is consuming almost 50% as if run on Petrol mode. nikkibike, Mine is not having an automatic changeover. Its a manual control switch. Usually I cold start with Petrol and within 2-3 mins, once the engine gets warmed, I change over to LPG.
| | #6 (permalink) |
| Senior - BHPian Join Date: Feb 2007 Location: Delhi
| Start your veichle, shift to LPG, Close LPG manually and see if car still runs normally or not. In a normal scenario it shut down with a minute after consuming gas in the pipeline, but in case if not then get the switch checked.
__________________ Ashish K "Ninety percent of the politicians give the other ten percent a bad reputation." |
| | #7 (permalink) |
| I could not find any way to close the LPG. Its running on GAS TANK, I dont know how I could close the flow of LPG.
| | #8 (permalink) |
| BANNED | Just start your vehicle in LPG mode. It should start in petrol mode by default. You'll see this by the indicator light on the switch. Then accelerate till it automatically switches to LPG. As long as you have gas in the tank make sure the switch is always in LPG mode. |
| | #9 (permalink) |
| I believe it must be knob near to tank or somewhere in engine. Why not ask your installer... ??
| | #10 (permalink) |
| BHPian Join Date: Nov 2008 Location: New Delhi
| Well I also faced this problem but generally i was keeping the petrol tank empty for this.But today i decided to search the cause .My case is with a carburetted M800 CNG Tomasttoe kit.There is a petrol solenoid switch .Now in case of electrical failure this switch will bypass and provide petrol directly .On this solenoid there is a manual clip with which you can permanently run the car in petrol in case something goes wrong now as far as i got the information and understood if this clip is not on the extreme other end it will lead to very tiny amount of fuel sucked into the system thus emptying the tank.So in short one end is normal and other end is pure petrol anything in between leads to consumption of petrol with gas. |
| Thread Tools | |
Similar Threads | ||||
| LPG Kit fitment for a 2001 Palio 1.6 GTX | ravikn | Modifications & Accessories | 22 | 11th August 2009 00:08 |
| Want to fit LPG Kit to Palio Adventure 1.6 | zaphod | Technical Stuff | 23 | 7th August 2009 15:20 |
| Starting trouble in LPG mode | Hashim | Technical Stuff | 16 | 25th March 2009 21:04 |
| LPG Kit on Palio 1.6?? | amitshah | Technical Stuff | 9 | 22nd June 2007 20:05 |
| Retrofitted LPG/CNG kit in PALIO | purnendubagchi | Modifications & Accessories | 1 | 10th July 2006 01:30 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
