Old 5th May 2009, 10:33   #1
Thanked: 159 Times
Default Starter/Solenoid problem M800
Hi Guys,
My car is giving starting problems. It was running just fine till yesterday. It was not cranking only today morning. I checked all lights, horn, indicators. Everything is working fine. So I guess it has to be starter/solenoid. Is my conclusion right? If yes, any idea how much does it cost to repair/replace it?
Thanks!
shipnil is online now   Reply With Quote
Old 5th May 2009, 13:44   #2
Rehaan's Avatar
Thanked: 22,566 Times
Shipnil,
If you're lucky - its only a relay that has stopped working, or the solenoid for the starter motor is just stuck.
When you turn the key do you hear a tak-tak noise coming from the starter motor solenoid (in the engine bay, near the flywheel) ?
- If this is the case then the solenoid might be stuck. Sometimes a whack with a rubber mallet is enough to free it.
If theres no tak-tak from there, is there a click coming from the relay box?
- If there is no click coming from the relay box, chances are the relay is bust and it needs to be replaced.
Also try putting the car in gear and pushing it forwards/backwards a little and then try again for what its worth.
cya
R
PS - Also see this thread : http://www.team-bhp.com/forum/techni...r-problem.html (Battery problem or starter problem or....??)
Old 6th May 2009, 10:33   #3
santsharan's Avatar
Originally Posted by shipnil View Post
Hi Guys,
Thanks!
Shipnil, The solenoid shoud cost you around Rs 650 & if its the Starter motor (which is also called a Self) would cost you around Rs 2500.
santsharan is offline   Reply With Quote
Old 12th May 2009, 11:57   #4
Thanked: 159 Times
Thanks guys for the replies. The car used to start without any touch up on one day and would not on another. As I was little busy, I couldn't take it to any mechanic. This went on for about 4/5 day until one day, I opened up the bonnet to see if I can figure out anything. Tried to locate the starter motor and voila, a connector was loosely touching the pin. It was the power supply that had come lose and hence the motor couldn't kick in at the turn of key. I fixed that and the car is starting fine now.
Old 18th May 2009, 17:10   #5
santsharan's Avatar
Wow so much for a simple problem. Anyways, Alls well that ends well Keep Revving.
Battery problem or starter problem or....?? Srinivas Technical Stuff 21 16th June 2017 14:06
Starter motor solenoid lock - Causes? tsk1979 Technical Stuff 6 27th April 2017 21:01
Accent Viva Crdi: Purge Control Solenoid Valves - Rs.16.5k! EDIT: Fixin it DIY style! AbhiJ DIY - Do it yourself 64 11th December 2014 13:38
Fabia Starter Motor; Solenoid Switch jnpai Technical Stuff 3 18th September 2011 21:44
Battery or started/solenoid tsk1979 Technical Stuff 2 10th May 2005 16:18
