Old 21st May 2009, 13:59   #16
Bubby's Avatar
Thanked: 152 Times
This issue has been eating my head. I have noticed that the rev isnt constant even at constant throttle input. Another things that I have noticed is momentary jerks as if the engine has missed a beat or was starved of fuel while cruising.
ABS motors doesnt have a fuel pump in stock and since it is not a fast moving item they dont usually keep it. Now they are telling me that if they suspect its the fuel pump then they will order one for me but I will have to pay for it :(
The fuel pump alone is 11k's. Can I source the fuel pump from any outside spares shop in Delhi?
Hi there !
You may try and visit newly opened RAMA motors ( TATA/FIAT ) in Okhla, they have hired the best NCR mechanic for the Palios.
PM me if you want any further details on RAMA.
For a spare shop in Delhi, you can try Mahajan, they are in Lajpat Nagar-1.
Cheers.
Bubby is offline   Reply With Quote
Old 21st May 2009, 14:16   #17
Thanked: 96 Times
E_T -- when the car is running bad, stop and check the gas cap -- unscrew it do you hear the sound of air rushing in?
B
71Convertible is offline   Reply With Quote
Old 21st May 2009, 15:04   #18
extreme_torque's Avatar
Thanked: 1,317 Times
@71... do you mean the petrol cap?
extreme_torque is offline   Reply With Quote
Old 21st May 2009, 15:05   #19
Originally Posted by Bubby View Post
Hi there !
Cheers.
Thanks mate.
Can you pm me the no. of the works manager? I have heard a lot of good things about them and will give them a visit as soon as the time permits.
Old 21st May 2009, 22:02   #20
Thanked: 96 Times
sorry -- yes the petrol cap
Old 11th June 2009, 12:24   #21
Speed Pujari's Avatar
Thanked: 385 Times
What is the top speed you guys are getting in the highways with and without AC.
For me
without AC plain road- 120-130 kmph max
with AC - 90-100 kmph max
with AC on it difficult for me to overtake a M800 .
I tested the car on Hunsur-kushalnagar road while on the way to coorg. Once while climbing down the car did a 140 kmph with AC..
The average FE i got was 15+ (10% AC ) while going and 12+ while returning (90-100% AC).
Are my stats matching with other Palio 1.2 ELX owners? Mine is a 2003 model.
Is it a time for me to contact hariprasad enterprises guys?
Speed Pujari is offline   Reply With Quote
Old 11th June 2009, 14:52   #22
Even I am able to go only upto 120 kmph with A/C and that I think is pretty low coz I have touched 145 kmph with relative ease before.
Old 11th June 2009, 14:57   #23
JVH
JVH's Avatar
Thanked: 148 Times
ET - Any update on the issue? Did you visit Rama motors?
JVH is offline   Reply With Quote
Old 15th June 2009, 12:07   #24
vrprabhu's Avatar
Thanked: 351 Times
I tried to do (emulate!) your conditions over the last month - had the chance when we travelled form Pune to Shirdi with six on board - four adults (approx 65 - 70 kgs each) and two kids (about 40 -45 kgs) - two at front, two adults + two kids at the rear. My observations on acceleration :-
a. In the ghat section (not much of a ghat between Pune & Ahmednagar) vehicle could not climb in 5th even with AC off - had to down shift to 4th and at times 3rd for it to pull cleanly. But cruising on 5th at 120+ was smooth;
b. Even when I tried to go up carrying initial speeds of 80 - 100, the going got appreciably slower nearer the top - had to switch off the AC and come down to 4th;
c. Tank was almost full while going and half-full while returning - did not notice any appreciable difference;
So over 400 kms the behaviour was - can't accelerate up slopes on 5th with pay load of about 500 kgs. (Try to do 'hyper-miling' on highways - tires are inflated at 32psi - 2psi more than normal).
But - surpise - now driving in the city after the trip can't climb flyovers on the 5th with AC on! Without AC there is not much fuss.
Planning to go for service in a couple of weeks - will keep you posted on the feedback after discussing the issue with the service centre guys.
vrprabhu is offline   Reply With Quote
Old 15th June 2009, 13:53   #25
I am yet to give Rama motors visit due to time contraints but will do so at the earliest oppurtunity... I am starting to belive that it could be an issue with the fuel pump working.
Old 15th June 2009, 18:04   #26
s3va's Avatar
i too face the same issue, the fuel pump was replaced and the lines cleared but didnt do any good. Can it be the clutch ? My 2003 Palio 1.2 has done about 20k kms..
s3va is offline   Reply With Quote
Old 15th June 2009, 18:41   #27
Is this a widespread issue with the Palio? If it is then we can collectively write an email to Fiat and get our cars properly diagnosed. Can other Palio 1.2 owners confirm?
Old 15th June 2009, 19:05   #28
planet_rocker's Avatar
Thanked: 365 Times
Did you try getting help from the PUG and the Palio - The FIAT Forum ?
planet_rocker is online now   Reply With Quote
Old 15th June 2009, 19:44   #29
@planet.... I did from PUG and did what they suggested... checked the HT Coils, got the injectors cleaned, checked the ECU for any error codes, cleaned the throttle body but the issue persists. :(
Old 15th June 2009, 19:58   #30
lohithrao's Avatar
Thanked: 163 Times
e_t, my 1.6 was sluggish the day i bought it(used one) recently got it rectified it was due to "ignition coil"
lohithrao is offline   Reply With Quote
Starting problem in Palio 1.2 ELX petrol 2002 ObsessedByFIAT Technical Stuff 14 11th May 2015 15:07
Palio 1.2 ELX: 55,000 kms review - Now Sold, A tribute to the Palio iceman7 Long-Term Ownership Reviews 44 2nd February 2012 21:24
Strange Palio Problem? 1.2 ELX extreme_torque Technical Stuff 7 2nd October 2007 23:05
Difficult to diagnose noise from Santro dj_2006 Technical Stuff 2 2nd July 2007 23:28
Fiat Petra 1.6 ELXP or Palio 1.6 sports or Palio 1.2 nv ELX? Travel-X Hatchbacks 20 8th November 2006 18:36
