Old 18th December 2009, 12:01   #46
vrprabhu's Avatar
Thanked: 368 Times
No this was before I got the CNG installation done.
Definitely then it is an indication that the mixture is too lean.
Originally Posted by DKG
If your car has a ecu and a catalytic converter then a faulty oxygen sensor can also bugger up engine performance
+1 to that. Better get the ECU checked. I had a problem earlier when the fuel injector light stayed on - however, the problem was quickly diagnosed as water in the injectors.
vrprabhu is offline   Reply With Quote
Starting problem in Palio 1.2 ELX petrol 2002 ObsessedByFIAT Technical Stuff 14 11th May 2015 15:07
Palio 1.2 ELX: 55,000 kms review - Now Sold, A tribute to the Palio iceman7 Long-Term Ownership Reviews 44 2nd February 2012 21:24
Strange Palio Problem? 1.2 ELX extreme_torque Technical Stuff 7 2nd October 2007 23:05
Difficult to diagnose noise from Santro dj_2006 Technical Stuff 2 2nd July 2007 23:28
Fiat Petra 1.6 ELXP or Palio 1.6 sports or Palio 1.2 nv ELX? Travel-X Hatchbacks 20 8th November 2006 18:36
