Old 8th December 2013, 22:27   #331
Peter's Avatar
Thanked: 45 Times
Default Re: Swift DDIS Turbo issues: Report & Resolution thread
Hello Team,
Have ecountered a weird issue today , while driving on the Pune expressway there was a need for sudden increase in speed at an incline , normally this was the best part of the DDIS where in the engine would instantly respond but today there was no response at all ... however much I depressed the throttle there was no response , meaning I did not notice any change in performance , shifting down a gear and hard acceleration also did not help , the car would just not pull.
The issue somehow resolved itself after sometime and was able to drive smothly for another 100 kms when again the power drop was noticed for a few mins.
The weird thing about this is that this issue of lack of pickup is not consistent and resolves itself but then this behaviour is a cause of concern, also another thing that Ive noticed is that when the power / boost is lost the engine sounds a bit rough as well .
Any ideas as to what could be going wrong ? need to figure this out before the issue becomes any worse ... and to be honest without the much needed boost / torque , driving becomes more pain then pleasure , please help
Peter is offline   Reply With Quote
Old 8th December 2013, 23:00   #332
Thanked: 14,594 Times
Originally Posted by Peter View Post
Hello Team,
I guess there is a problem either with the fuel or the fuel pump is not working as it should.
May be the fuel is not being supplied causing no power output or the ECU is not able to get the signal from the accelerator input.
Anurag.
a4anurag is offline   (1) Thanks Reply With Quote
Old 8th December 2013, 23:12   #333
DRIV3R's Avatar
Thanked: 1,433 Times
Peter, are you sure you were not there in the turbo lag zone when you stomped on the accelerator?
DRIV3R is offline   Reply With Quote
Old 9th December 2013, 09:33   #334
PearlJam's Avatar
Thanked: 346 Times
I had a similar issue, please see my earlier update. After starting to fill regularly from a known fuel outlet, I haven't hit this problem ever since.
PearlJam is offline   Reply With Quote
Old 9th December 2013, 11:35   #335
bhp_maniac's Avatar
Thanked: 111 Times
For the Swift it must work post mid-2009 models and not earlier as they are OBD I.
Anurag.
Are you sure about this? Because once I asked someone from service center and the guy was sure it won't work for me. But recently heard like the ELM327 woks on BS4 Swift DDiS. Mine is a BS4 model made in May 2010. Any chance?
bhp_maniac is offline   Reply With Quote
Old 9th December 2013, 11:45   #336
OBD II is after 2008 manufactured vehicles. I presume it will be standard post mid-2009.
It was a general point that I made but it should work in your car as it is a 2010 manufactured vehicle. By the way did you try using the OBD II reader?
Anurag.
Old 9th December 2013, 11:46   #337
Jaggu's Avatar
Thanked: 8,670 Times
Hello Team,
Might be a bad terminal at the accelerator pedal side. Try doing this, while parked and with engine switched OFF. Press the accelerator pedal fully couple of times and in a swift manner. If there is some dirt or minor corrosion at the contacts, this will help in clearing it away. Happened to my car also once, and followed the procedure above. Issue never came back.
Jaggu is offline   (1) Thanks Reply With Quote
Old 9th December 2013, 12:32   #338
Peter's Avatar
Thanked: 45 Times
Anurag.
Thanks Anurag ... am doubting the fuel quality as well , though hope its not a pump issue , on my way back I refuelled at the COCO pump on the way back at the Pune expressway and the performance seemed to have improved , dont know whether its my imagination yet.
Thanks for asking , was indeed beyond the turbo lag ... even If I was in the lag zone then the engine would respond after a few secs as it got out of it , this occurence there was no intention to move ahead but rather stayed there
Hope its indeed a fuel issue Pearljam and not anything more then that , though I have been filling up regularly at a COCO pump at Kharghar Navi Mumbai only for the past 2 years but then again even a COCO pump could have issues at times !!
Thanks Jaggu , will try that.
@ All : Just occurred to me that just before I noticed this issue a few days before I had cleaned the air filter with a vacuum cleaner thinking that it would do a good job , though am thinking that the vacuum cleaner should not damage the air filter , at least visually I do not see any damage but just thought as this was the only thing that I did prior to noticing the issue.
Old 9th December 2013, 12:34   #339
shashank.nk's Avatar
Thanked: 749 Times
It seems like my Swift Zdi has a small issue, this is what happens, when the rpm is between 1500-2000 the power delivery tends to be jerky, though not violently that passengers feel it,I as driver can definitely feel it. It happens from 2nd onwards, but whenever I try to replicate it, the degree of jerkiness varies and sometime is totally absent.
What could be possibly wrong ?
shashank.nk is offline   Reply With Quote
Old 9th December 2013, 12:42   #340
Jaggu's Avatar
Did you use vacuum cleaner to blow or suck the dust, if its former better to get the filter replaced since it would have damaged the filter surface. Blowing will not cause any serious issue as long as its opp direction of air flow through the filter.
This could be a minor block of filter or in the injectors, had this issue sometime back though the filter was clean. Did an italian tune up and it was ok.
If you drive alot in city, stretching the engine out with longer runs and at higher rpm is a good idea once in a while.
Old 9th December 2013, 12:49   #341
Thanked: 749 Times
I just cameback from a 600km drive and did take the car to higher rpms so that should clear out the blocked injector ? Will take the car to get filter cleaned. Also can you please explain what in italian tune up is.
EDIT: Figured out italian tune up. For blocked indicators System G/Bardahl klene would help ?
@Anurag: Nope, this isn't turbo lag or driving at a higher gear than should be.
Old 9th December 2013, 12:51   #342
That is the famous turbo lag range.
I have felt this jerkiness a couple of times but cannot replicate it if I want.
I am clueless here. Hooked up the OBD II Reader but no issues found at this RPM range.
I drive the car till redline for a few seconds every 2000 kms. Does get rid of the sooth from exhaust pipe.
What is an Italian tune up?
Anurag.
Old 9th December 2013, 13:01   #343
Jaggu's Avatar
Anurag.
Italian tune up is similar. http://en.wikipedia.org/wiki/Italian_tuneup
Basically run the engine at higher rpms/low gears for sometime so that all the soot clears off from the system. Ensure you do it once the engine is heated up and on open road stretches with minimal traffic so that the acceleration/deceleration and soot doesn't effect other road users.
Old 9th December 2013, 13:34   #344
bhp_maniac's Avatar
Thanked: 111 Times
Anurag.
Never got a chance to try it out. Anyway, planning for a Bangalore trip in the coming weeks, hopefully will get a chance to check up with some ELM 327 sellers, have communicated with couple of them in Bangalore.
Old 9th December 2013, 13:44   #345
Jaggu's Avatar
Let me know, i have one and you can try it out for free if you are in Koramangala, Indira Nagar side to see if it works.
economy diesel duel: Maruti Ritz DDiS vs Suzuki Swift DDis vs Vista quadrajet aura. s_pphilip Test-Drives & Initial Ownership Reports 25 29th October 2009 09:43
Swift DDiS vs Ritz DDiS vs iKool ? anoovis Hatchbacks 1 21st October 2009 13:09
