Old 11th November 2016, 16:15   #421
Thanked: 13,411 Times
Default Re: Swift DDIS Turbo issues: Report & Resolution thread
Originally Posted by 2W-4W View Post
Also, do we need to keep a check on that Right foot after turbo replacement? Asking this because I will go on a road trip to Rajasthan next week and roads there are straight out of F1 track.
AFAIK, any new component in the car needs some time to bed in so it is reliable.
Be sure to following the 30 second idling rule at shutdown mainly and when startup don't revv the car a lot. Keep varying the RPM a bit in the initial 500 kms post which you can stretch it a bit gradually.
a4anurag is offline   (1) Thanks Reply With Quote
Old 12th November 2016, 10:49   #422
Jaggu's Avatar
Thanked: 8,114 Times
Nothing much apart from letting the turbo lube up, basically idling the car for 10-15 seconds at start and idling for a minute or two after long hard runs before shutting down. This should suffice.
Jaggu is offline   (1) Thanks Reply With Quote
Old 2nd January 2017, 15:52   #423
bkc
bkc's Avatar
Thanked: 103 Times
Unhappy Re: Swift DDIS Turbo issues: Report & Resolution thread
Experts of DDIS; is this normal i.e. oil over the intercooler hoses?? Please look at the pictures below and comment.
Swift DDIS Turbo issues: Report & Resolution thread-img_20170102_142624.jpg
Swift DDIS Turbo issues: Report & Resolution thread-img_20170102_142632.jpg
Mine is 36xxx Kms run 2015 swift and under warranty. I have taken the extended warranty but, how to verify the extended warranty on my vehicle?? ; I have not received any certificate for the same.
I am facing steering shake at turbo zone right from day one of purchase and nobody could pin-point issue at MASS. The below, are the parts replaced under warranty, yet, could not identify the root cause.
1) Gear jump from day one and rectified by replacing some part at 9xxkms; issue was the gear jump from second to neutral while overtaking, rectified by MASS.
2) Steering shake started since then and both service managers namely Vijay Babu (left job now) and Santosh at Mandovi were helpful in diagnosing and interest in solving but, till now the issue is unsorted and got fed up (felt safe as I have warranty).
  • Initially said due to 195 tyres but I argued and asked them to check with their TD car tyres and I was right.
  • Replaced clutch, flywheel at 9,xxx Kms but that did not resolve the issue.
3) Replaced lower arm driver side as the boot rubber had cut, noticed during washing outside. (even that is not the issue for steering shake)
4) Replaced Tie rods by paying from pocket during 30xxxkm service saying it doesn’t come under warranty and is a rubber part.
5) Alignment is always an issue and car pulls towards left. (any serious chassis issue??)
Please suggest on anything else to be checked, for resolving the issue. If any Swift owner/bhpian is willing to get in touch and drive my vehicle to know the exact issue, kindly let me know (I live nearby basaveshwaranagar, Bangalore).
Thanks in advance for help and suggestions.
Last edited by bkc : 2nd January 2017 at 16:01. Reason: Please do not post personal information (mobile no, email ID etc) on an open forum.
bkc is offline   Reply With Quote
Old 2nd January 2017, 16:13   #424
rakesh_r's Avatar
Thanked: 705 Times
Ideally the Intercooler hose should not have any oil residue. How is the engine response? Do you get the turbo kick? If not, chances are the Intercooler is clogged with Oil. Please check the oil level. I am sure the monkeys at MASS filled 3.5L of engine oil instead of the specified 3.1L.
rakesh_r is offline   Reply With Quote
Old 2nd January 2017, 16:21   #425
bkc
bkc's Avatar
Thanked: 103 Times
Hi Rakesh,
Yes, you might be right, the Dip stick 'oil mark' seems more than the marked position. I shall check the same with MASS.
Turbo kick although exists, is not as crazy as it was, after the 10000kms service.
Old 2nd January 2017, 18:04   #426
Originally Posted by bkc View Post
Not at all normal buddy.
Clear case of engine oil over-filling.
Here is my DIY thread on cleaning the intercooler. You can do it yourself if you are a DIY person.
http://www.team-bhp.com/forum/diy-do...tercooler.html (DIY: Cleaning the Intercooler)
Else take it to MASS, get the intercooler cleaning done thoroughly and refill the engine oil to the correct quantity which is 3.1L. Drive around for 50 to 100 kms and see if there is any difference.
Over-filling oil will kill the turbocharger sooner than normal.
Stay at the service centre with the car when they are doing this. Insist you to stay there.
Old 3rd January 2017, 16:14   #427
bkc
bkc's Avatar
Thanked: 103 Times
Thanks Anurag. I have given the car to MASS in the morning, having discussed the issue with service manager. He assigned to a SA, meanwhile, I checked for my extended warranty with records but seem it is not there.
Right now, it still comes under normal warranty but, I had paid for extended warranty.
There seems to be some issue with Mandovi; I spoke to the marketing executive who sold me the car and he asked for some time to check records and give me the details. If there is some game in the sale, I am going to mail Maruti with these issues. I even checked with them for new extended warranty if I chose to buy again (why pay twice); it comes to nearly 15k.
Old 3rd January 2017, 17:41   #428
bkc
bkc's Avatar
Thanked: 103 Times
Smile Re: Swift DDIS Turbo issues: Report & Resolution thread
Update:
Met with the SA and he was ready with two invoices, that I paid during my car purchase.
  1. One was the amount; I paid before the cheque arrived from bank. (Road tax + extended warranty + incidental charges)
  2. Amount credited from bank to their account.
The total amount paid + 10K cash discount - insurance amount = car price + Rs 4xxx amount.
The Rs4xxx amount was refunded to me, via a cheque. Insurance was taken by me, separately outside, at a much cheaper cost.
Took the SA to service centre and the cost was total 14025Rs for extended warranty (around 10000Rs if bought during car purchase). He agreed to pay 10000Rs for his mistake (asked not to escalate) and I added an additional 4000Rs feeling, sorry for him. Finally, peace of mind for additional 43000kms.
Swift DDIS Turbo issues: Report & Resolution thread-img_20170103_171608.jpg
bkc is offline   (1) Thanks Reply With Quote
Old 6th November 2017, 00:30   #429
cpbopanna's Avatar
Thanked: 793 Times
Thanks to the initiator and many contributors to this thread!
My SX4 Diesel had a problem with the turbo not kicking-in intermittently
My service advisor suggested that since the engine had run 90000 km+ and we had not cleaned the EGR valve earlier, probably that was the cause!
I had the EGR valve, injectors cleaned and the problem appeared to have been solved - I actually had no time to go on a long test-drive!
After a month, during a long drive, the same issue cropped-up again! Sometimes the turbo would kick-in and many times wouldn't!
It was absolutely frustrating when the engine just revved up with no corresponding increase in power/torque
During my next visit to the MASS, the SA, as expected, concluded that the turbo had failed and said that it required to be replaced!
I argued with him that I was one of those enthusiasts that kept the engine idling (for a minute) after starting-up and before switching-off, and took such good care of my vehicles; there was no way the turbo-charger could fail!
Also, when the turbo did kick in, the boost was quite satisfactory! A failed turbo would not kick in at all!
I gently coaxed him to check all the plumbing attached to the turbo, and lo and behold, one of the (vacuum) hoses was cut!
I asked him to change ALL the hoses. Total cost of replacement - Rs. 500
Cost of a new turbo-charger - upwards of Rs. 30k!
Had I actually changed the turbo (without checking the hoses), the service center would have invariably replaced all the plumbing and the matter would have been anyway resolved.
And the SA would have said - "Sir, I told you that replacing the turbo would solve the problem!"
cpbopanna is offline   (3) Thanks Reply With Quote
economy diesel duel: Maruti Ritz DDiS vs Suzuki Swift DDis vs Vista quadrajet aura. s_pphilip Test-Drives & Initial Ownership Reports 25 29th October 2009 09:43
Swift DDiS vs Ritz DDiS vs iKool ? anoovis Hatchbacks 1 21st October 2009 13:09
