Old 6th April 2010, 10:23   #16
Jaggu's Avatar
Thanked: 8,686 Times
First do a complete tune up and then see if the injectors needs to be re-calibrated. Looks like a fueling issue than anything to do with overheating. To be on the safe side, check if you dont have any head gasket failure and compression loss at the cylinders.
Old 9th April 2010, 16:45   #17
Would this be a problem due to a damaged intercooler? I also faced a similar type of problem wherein my car used to jerk whenever I changed gears from 1 to 2 or from 2 to 3 during low RPMS. Also, the pick up was poor. Finally I had to replace the intercooler.
Also,please share the details once the diagnosis is done for your car and problem resolved.
Last edited by roadracer : 9th April 2010 at 16:49. Reason: I wanted to get some information.
roadracer is offline   Reply With Quote
Old 9th May 2010, 17:54   #18
Crazy_Eddy's Avatar
Thanked: 25 Times
Frank, were you able to resolve the issue? Facing *exactly* the same problem on a Linea.
My clutch play went wonky after it went in for some work recently.. however I've noticed this weird deceleration even otherwise.
Crazy_Eddy is offline   Reply With Quote
Old 9th May 2010, 17:57   #19
frankmehta's Avatar
Thanked: 2,334 Times
Hi there. This problem was there for a few weeks, and it just 'sorted itself' out sir. I could attribute it to a situation I call sticky clutch/brakes. Something was impeding the car from going further. I don't know how to explain it, but I think you should get the brake pads/clutch setting checked. It's a small issue, annoying, but easily rectifiable!
frankmehta is online now   Reply With Quote
Old 9th May 2010, 18:11   #20
Crazy_Eddy's Avatar
Thanked: 25 Times
Yep I know what you mean, if feels like someone hit the brakes.
The brake pads aren't the issue in my case, since as you mentioned this behaviour doesn't show up when the gears aren't engaged.
Unfortunately for me, this isn't sorting itself out :(
Old 9th May 2010, 21:23   #21
I have got the same problem with my 2006 M800. The jerk is so violent with a thud that you feel something is awfully wrong. I had recently gotten my clutch overhauled!
vjabraham is offline   Reply With Quote
Engine randomly coughs & jerks while driving arnieshwartz Technical Stuff 21 14th June 2018 11:33
Fiesta engine jerks and rpm varies while idling tortoise Technical Stuff 45 19th May 2017 21:46
Exhaust pop on deceleration, occasional stalling hellmet Motorbikes 26 24th February 2015 12:16
Engine Knocking / Jerks vij4all Technical Stuff 15 16th March 2013 20:58
My engine jerks on acceleration - Expert advice required please bvikas Technical Stuff 3 6th April 2010 09:54
