Old 8th May 2009, 08:29   #1
Default Fabia AC/Blower ineffectiveness
I live in Gurgaon and this is the first time my Fabia's (diesel) AC is being truly tested in the summers.
I find the blower severely inadequate. With the temperature set to 16 and the blower set on maximum(4), I cannot feel the air blowing out with full intensity, it is much weaker compared to other cars. The grill is completely chilled but there is little circulation.
If I put it in the `re-circulation' mode the blower makes louder noise but the recirculation is still inadequate.
Has any other Fabia owner noticed this problem? Is it hereditary to the Fabia or could it be a problem with just my car.
Asking the wise men here before I take the car to the clueless Skoda service.
saraf_suman is offline   Reply With Quote
Old 8th May 2009, 09:18   #2
Invinsible's Avatar
Thanked: 60 Times
Originally Posted by saraf_suman View Post
Hi, How many kms has your fabia done?
I suppose there is something called pollen filter which comes with the blower, it filters the minute dust particle as the blower sucks the air through it, just like the air filter. Get your pollen filter checked, I doubt that it might be choked.
Second there is a recirculation/exhaust button next to the AC switch on/off button. One is suppose to keep the recirculation button on i.e. you will see a light coming on as you press it on. Don't put it off where the light goes off. Always keep that button on.
Check both these things, it should help. If the problem still persist get it checked completely with the dealer, which I suppose there wouldn't be need to.
We have been facing severe heat hear as well where last month temp going to almost 39 in Bombay. But Yet in that with the amount of humidity, the AC worked fine. For me I use it just on 2nd speed and barely put it on 3rd or 4th.
Fabia has a bigger blower and a compressor for it's size.
All the best.
Invinsible is offline   Reply With Quote
Old 8th May 2009, 14:35   #3
Thanked: 103,375 Times
From the description, you are definitely sitting on a blockage or leakage somewhere. Have you gotten the car checked by the Skoda after sales (God help you!) or an air-con specialist?
Old 8th May 2009, 23:21   #4
gpa
gpa's Avatar
Thanked: 282 Times
From what you have said, it looks like a clear case of a blocked or chocked vent. This has happened to one of my friends's Swift in the past where we were on the highway and after two days of poor circulation in the cabin in the Tamil Nadu heat, we took the car to the mechanic who opened up the condenser box underneath the dash and out came almost 500 grams of dried leaves, parking tickets and even dead ants!
Post this the fan speed increased and cooling was even throughout the cabin. Do get it checked.
Cheers,
gpa
Old 9th May 2009, 00:04   #5
Roy.S's Avatar
Thanked: 110 Times
Better to live with it than go down that road.
Would not be too difficult to troubleshoot as a DIY, I think.
Roy.S is offline   Reply With Quote
Old 9th May 2009, 00:08   #6
kunaldhami's Avatar
Thanked: 62 Times
I had similar problem in my car..gave my car car to Dealer for 2 hours, they cleaned filters and all and it worked..
kunaldhami is offline   Reply With Quote
Old 9th May 2009, 02:47   #7
Raccoon's Avatar
Thanked: 105 Times
Cheers,
gpa
Do you need to open up the dashboard to do this?
Old 9th May 2009, 10:54   #8
toiingg's Avatar
Thanked: 83 Times
Its below the dash IIRC. Passenger side
toiingg is offline   Reply With Quote
Old 9th May 2009, 11:53   #9
gpa
gpa's Avatar
Thanked: 282 Times
Not the whole dash. Just below the dash on the LHS where the condenser coils are located
Old 13th May 2009, 11:51   #10
Default It was the dust/pollen filter
Took it to Skoda service, where they removed the filter(from underneath the passenger side dash) and cleaned it with the air jet.
The AC is rocking now.
Old 13th May 2009, 12:22   #11
gpa
gpa's Avatar
Thanked: 282 Times
Glad your problem is solved!
Cheers,
gpa
Old 13th May 2009, 14:13   #12
HKS
HKS's Avatar
The your A/C serviced. Either your blower fan has some issues with its speed as you said the grille becomes chilled, there shouldn't be a problem with the gas.
HKS is offline   Reply With Quote
6 lakhs to repair Skoda Fabia engine. EDIT: Owner sells Fabia as scrap! zombiedriver Technical Stuff 234 27th July 2016 16:32
Blower noise NHC SCH Technical Stuff 6 2nd May 2012 17:00
Swift: Ventilation blower pumps in HOT air k36 Technical Stuff 20 10th January 2011 11:23
A/C blower 1 and 2 setting not working Dippy Technical Stuff 13 13th November 2009 15:36
Whistling Soung from Blower mobike008 Technical Stuff 9 21st February 2008 01:05
