Old 21st May 2009, 11:36   #16
sgiitk's Avatar
Thanked: 3,883 Times
Originally Posted by arindamray View Post
Didn't get it? FE is based on Odo reading, isn't it?
Does the negative error in Speedo indicate a positive error in Odo? I thought Odo readings were ok, based on my observation with the milestones.
A few percentage points cannot be detected with milestones. If you go on a highway you will see Location A is say 60 km. Another couple of km towards A and all of a sudden it becomes 62km. Have seen things like this even on the GQ!
Old 21st May 2009, 12:08   #17
dilipkumar7278's Avatar
Thanked: 26 Times
Default SPEEDO error
Guys
My swift vdi odo has a peculiar problem. I have noticed that whenever car comes to a halt the speedo shows 15kmph and only after 2-3 seconds it comes to rest. Is it a common problem in swift. My Lancer doesnt have this problem. When I enquired the SA at sai motors he told that was ok. I dont believe him because it was the same one who told me that the service light goes off only after starting the engine.(I think I know more about ddis than him owing to folks here at Team-BHP. FYI, the tyres are stock 165/80R14 JK crap on alloys.
Dilip Kumar
dilipkumar7278 is offline   Reply With Quote
Old 21st May 2009, 12:45   #18
Thanked: 49 Times
We have a Petrol Padmini S1 that has significant odometer error (the odo showed 12 Kms for every 10 actually traveled) but the speedometer shows about the same reading when driven side by side with other cars.
IMO - PAL must have intentionally added the odo error to boost the perceived FE figures of the S1. So highway FE readings if calculated by the odometer come to 18-19 kmpl while the actual figure is closer to 15 kmpl.
CrackedHead is offline   Reply With Quote
Old 21st May 2009, 13:16   #19
extreme_torque's Avatar
Thanked: 1,489 Times
The Palio suffered from positive speedo error, as oppossed to negative speedo error for all other cars. This meant that even though palio was just 5% less FE than the bunch, measured FE was actually 10-15% lower.
When the fuel efficient palio NV came out, the most important mod to improve FE was change the speedometer.
Was the palio always like that? No, brazilian palio had negative speedo error, but when that came to India, they upsized the tires without bothering about the speedo.
They forgot, that in India, anything can make or break a car, and hence the straw that broke the camels back was actually the speedometer!
EXactly..... I did a study which confirms this, thanks to my GPS enabled Nokia N82.
http://www.team-bhp.com/forum/indian...efficient.html (A Study:Is Fiat Palio 1.2 Pre-NV really fuel in-efficient?)
extreme_torque is offline   Reply With Quote
How accurate is the distance to empty aravind84 Technical Stuff 42 14th June 2016 17:56
About Non-Linear Speedometers akash_m Technical Stuff 23 24th March 2014 20:17
Younger people prefer digital shimmer to accurate sound greenhorn Shifting gears 18 17th March 2010 07:34
Whats is the accurate method of measuring FE Anju Technical Stuff 9 10th December 2007 16:52
Makes you wonder how accurate TopGear tests are(inside M6 vs 996TT) 1Day The International Automotive Scene 2 25th June 2006 12:35
