Old 11th May 2009, 13:57   #1
Default Strange Heating Problem in 2002 model santro Pls..... help
I am using 2002 model Santo ZipPlus LP. It has done 97000 km with full AC on.
From last month, particularly during summer, whenever I drive more than 1 hour, it stops all of a sudden with jerks seems like due to over-heated engine. After the sudden halt I could able to switch the engine on but it's not moving. To move it again the car needs to be parked offroad for around 30/45mins.
Initially this problem was coming with AC on. Recently, I am facing this issue without using AC also.
Note: Vehicle is serviced in regular intervals and last service was done @ 95000.
Coolant levels are adequate and there is no leakage.
No abnormalities in Temparature meter
I have visited no of auth service centres.But couldn't got any solution/rootcause so far.
Request you all to throw some light on this and advice me
Thank You
manne is offline   Reply With Quote
Old 16th May 2009, 06:52   #2
vkochar's Avatar
Thanked: 219 Times
You need to write to Hyundai regarding this if no one is able to help you regarding your problem.
I do not know what the solution is, BUT it may be a serious problem.
vkochar is offline   Reply With Quote
Old 16th May 2009, 13:33   #3
vdiatech's Avatar
HI has has the ECU been checked for any fault codes ? I did a google and it could be air / fuel mix ratio.
vdiatech is offline   Reply With Quote
Old 16th May 2009, 14:09   #4
kannan666's Avatar
Thanked: 70 Times
Very unlikely that it is due to an over heating engine though, difficult to diagnose without an inspection. If the ECU is suspect, why don't you do a soft 'reboot' of the same and check. Please go through this thread on how to do a soft reset of the ECU - http://www.team-bhp.com/forum/techni...resetting.html (Basic ECM Resetting)
kannan666 is offline   Reply With Quote
Old 16th May 2009, 21:51   #5
Thanked: 149 Times
Looks like an overheating engine. Please look if the radiator fan is working, a few minutes after the engine is switched on.
Old 16th May 2009, 23:33   #6
kannan666's Avatar
Thanked: 70 Times
But he says there are no abnormalities in the temperature guage and he also says the that the authorised service centre has checked the vehicle. I am sure that the service centre would have suspected engine overheating becuase of the symptoms and this (the temperature guage) would have been the first thing that they checked for correctness and accuracy !
Old 16th May 2009, 23:52   #7
humyum's Avatar
Thanked: 2,503 Times
Check the radiator when the car is cold, it most probably is empty.
Leaking Hosepipes will leak all the radiator water and the lack of vaccume will not cause water from the coolant tank to be sucked in the radiator and the coolant tank will still show as full
Conform the level of water in the radiator.
Caution: WHEN THE CAR IS COLD AND NOT HOT.PLEASE DONOT EVEN THINK ABOUT OPENING THE RADIATOR WHEN ITS HOT!
humyum is online now   Reply With Quote
Old 17th May 2009, 00:02   #8
kannan666's Avatar
Thanked: 70 Times
Very elementary this but that also just might be the problem here that the A.S.S failed to check ! And if there is no water / coolant in the radiator, I guess the temperature guage will not work as the sensor is actually monitoring the temperature of the water / coolant circulating in the radiator !
Old 17th May 2009, 00:06   #9
humyum's Avatar
Exactly, Thats why i suggestested to check the radiator for water.His symtoms point towards an overheating engine and without anything in the water jackets, the needle wont show overheating!
Had this problem in a relatives santro, and his temperature needle used to take ages to wake up and never showed any overheating until the engine would shut down on its own!
Old 17th May 2009, 03:53   #10
TRAUMASURG's Avatar
This sounds like thermostat sensor fault. Check that out
TRAUMASURG is offline   Reply With Quote
Lancer SLX 2002 Model Electrical Problem harikr Technical Stuff 30 29th November 2015 22:36
Hyundai Santro Zip Drive 2002 Model, Restoration Project. ashishsonileo Modifications & Accessories 13 13th August 2015 21:18
Opel Corsa Sail 1.4 Engine heating problem. Please Help! stevie Technical Stuff 15 20th January 2010 00:59
Baleno / Altura 2002 model, pls suggest naveendhyani Sedans 0 27th February 2006 10:56
