Old 12th May 2009, 03:54   #1
dionysus's Avatar
Thanked: 18 Times
Default Swift rumbling at 80Kms
Hi Fellows
I drive a Swift VXI with K n N filter and automech exhaust. For the past couple of weeks the car picks up a strange rumble as the speed approaches 80kms and decreases around 100kms and above but never dies away. A lot of vibrations also accompany the rumble. I have tried to analyse the situation and have engaged neutral at about 90kms to check if engine is the culprit but the rumble still persists totally indifferent to the neutral. I recon its got to do with the mechanics rather than the engine.
Also if I stear the stearing towards the left the rumble and the vibrations dissapear till the stearing is left turned. Dosnt happen when I turn right.
Trouble is these speeds can only be attained on highway or toll roads so I am not sure how to prove my point when I go to a maruti work shop.
This is really annoying and has totally killed driving pleasure.
I request for your insightful comments on whats the pain!
Thanks for reading.
dionysus is offline   Reply With Quote
Old 13th May 2009, 03:02   #2
dionysus's Avatar
Thanked: 18 Times
HI All
Request for assistance!
The noise seems to come from the front portion of the vehical.
Old 13th May 2009, 08:14   #3
vibhu_f430's Avatar
Thanked: 67 Times
Hello mate ,
If that ''rumbling" can be felt through your steering , then you need to get your wheel balenced & alligned !
Also get your wheels rotated , Might make a difference !
Cheers !
vibhu_f430 is online now   Reply With Quote
Old 13th May 2009, 08:49   #4
Thanked: 141 Times
@ dionysus: as rightly said by vibhu, it is mostly the issue of wheel balancing, first get all your wheels balanced from a good tyre shop / M.A.S.S. then test drive to see the issue persists. If not try the wheel alignment as other option.
The issue must die away with the first one itself.
narayanang76 is offline   Reply With Quote
Old 13th May 2009, 22:34   #5
Thanked: 660 Times
also check for any issue of bend rims if you have them. Alloy is no problem.
Old 15th May 2009, 04:02   #6
dionysus's Avatar
Thanked: 18 Times
Thanks a lot for your replies...will execute! cheers
Old 28th May 2009, 02:59   #7
dionysus's Avatar
Thanked: 18 Times
Fellows, got the wheel aligned and balanced however the rumbling still persists. Rohan motors in Noida tell me its because of the bearings on the front left tyre. The mechanic said when the left tyre was moved he could feel a bit of vibration in the suspension (tyre was rotated by hand). The rest of the 3 tyres were fine as per him.
Does that make sense! I mean bearings gone faulty can make so much of noise ? Please help me out here
Old 28th May 2009, 04:58   #8
srikant's Avatar
Thanked: 9 Times
Yes, a worn out bearing may be a chance of the problem. You should give it a try.
srikant is offline   Reply With Quote
Old 28th May 2009, 10:22   #9
gpa
gpa's Avatar
Thanked: 282 Times
This definitely looks like worn bearings. How many kms has your car covered?
I had a similar problem after about 60,000 kms in one of my old cars. Problem was sorted as soon as the bearings of the front wheels were replaced.
Cheers,
gpa
Old 28th May 2009, 10:24   #10
Jaggu's Avatar
Thanked: 8,684 Times
If its a "Hum" then its definitely the bearing.
Old 28th May 2009, 10:35   #11
amit_mechengg's Avatar
Thanked: 1,556 Times
go on a very smooth road and check the same. if there is a humming sound then its definitely the bearings.also check the tyre wear out.
Old 2nd June 2009, 23:33   #12
dionysus's Avatar
Thanked: 18 Times
it sure is a hum! but the cars done 36K kms and bearings given way! wonder why the noise gets killed when i move the stearing towards the left
Swift Mods : Post all queries / pics of Swift Modifications here. blindrage Modifications & Accessories 2264 15th April 2018 23:33
Swift VXI - Delivery delayed by 3 weeks, Do I buy Ford Ikon? EDIT : Bought Swift Ldi nikunj_cal Hatchbacks 142 6th September 2007 14:12
80kms running which car BUSA Sedans 43 21st April 2007 18:26
Swift Vxi or Swift Vdi or New Ikon Flair nikunj_cal Hatchbacks 16 4th April 2007 02:40
WagonR or Swift?(calling swift and wagonR owners) rajshenoy Hatchbacks 43 29th March 2007 09:54
