Thread Tools
Old 7th June 2005, 13:16   #31 (permalink)
Steeroid's Avatar
Originally Posted by epyupc
Do you mean downforce is usable only after 200kmph...
Or that downforce from small spoilers found on most cars is negligible below 200kmph?
Because especially at slow tracks like monaco, downforce settings are very high.
Average speed of a lap at monaco is only 150 or thereabouts.
First of all, those arent my findings but those of my ex-colleague.
Secondly, he meant that for a spoiler to become useful the vehicle should be doing 200kmph or more (assuming no headwind). Only then does the force of the wind become sufficient for a well designed spoiler to have any effect on the handling of the vehicle.
I think we can conclude that <200 kmph gunny bags (filled with sand/cement/gravel) are the best aftermarket add-ons for handling.
__________________
Steer
The Land is in the past, now where do I find the 6-cylinder Ponton?
Steeroid is offline   Reply With Quote
Old 7th June 2005, 13:24   #32 (permalink)
Shan2nu's Avatar
Somehow i'm not satisfied with that theory. Downforce is also dependant on the surface area of the spoiler and the angle at which it cuts through the air.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 7th June 2005, 16:49   #33 (permalink)
Originally Posted by iceman91
hey,...think this has been discussed a lot of times before...but at high speeds tire pressure needs to be reduced not increased.
Iceman, I think you meant the other way. At higher speeds and/or higher loads , tyre pressures should be higher than normal.
__________________
Drive fast, but drive safe.
RX135 is offline   Reply With Quote
Old 7th June 2005, 16:51   #34 (permalink)
Team-BHP Moderator
Samurai's Avatar
Originally Posted by Shan2nu
Did you get the offset checked before buying your alloys? i still can't see why it should happen at 130kmph, that's cruising speed!!!
The wheel shop guy didn't know what an offset was, but I made sure it was within normal parameters, which is 38 in my case.
__________________
Samurai
The notchy gearshift of GV has become buttery smooth after I started driving the Jeep.
Old 7th June 2005, 17:19   #35 (permalink)
Shan2nu's Avatar
In that case, it can't be a problem with the car. Try driving at 130+ on a diff road. Try the Blore-Tumkur road, i did 160 on that road and the car felt calm and steady.
Shan2nu
__________________
Old 7th June 2005, 17:39   #36 (permalink)
speedsatya's Avatar
Originally Posted by Samurai
Recently I have started pushing my new Baleno to higher speeds. Two weeks back On the Hassan-Bangalore highway I started flooring it and was quite disappointed when the car started feel light (levitation?) at mere 130KMPH, I decided not to push it further.
What could be the reason? I didn't expect that to happen until 160+.
het samuraI,
I too had similar problems after upgrading to tires of lesser OD.inspite of better tires ,the handling was not as i had expected it to be.
this was because i used to keep the same air pressure as the previous tires which had higher OD.
So after i kept slightly lower psi in my tires,the ride and handling seems to be better.
so why dont u do some trial and error on ur psi readings,by lowering it.
but be careful that u dont underinflate the tires.this u can make out by looking at the tires
speedsatya is offline   Reply With Quote
Old 7th June 2005, 17:46   #37 (permalink)
Team-BHP Moderator
Samurai's Avatar
I'll try in different roads and see how it feels.
I don't have any problems with the handling, that is very good. This lightness was felt in straight road.
__________________
Samurai
Old 7th June 2005, 17:59   #38 (permalink)
Shan2nu's Avatar
Also, get your wheels alligned. A car going in a straight line doesn't always read as "alligned wheels".
If both your front tyres have equal toe-out, it improves handling but reduces straightline stability, without steering to one side.
The toe angles for the front and rear wheels will be mentioned in your car manual.
Shan2nu
__________________
Old 7th June 2005, 18:05   #39 (permalink)
speedsatya's Avatar
The lightness at higher speeds had probably something to do with your tires .mabbe as the tires get heated at speeds,the contact patch with the road is less.that s why u might be getting that feel.
BTW do u fill same air as before.
maruti says
33psi for 145/7or13 in a wagon r ,but says 32 psi for 155/65r13 which has slightly lesser OD.
so try doing that as well
Old 7th June 2005, 18:18   #40 (permalink)
Shan2nu's Avatar
Well, if the contact patch is infact getting reduced (which i doubt it does), shouldn't it affect handling too?
I don't think a 1 psi diff changes the contact area, it takes a lot more psi than that.
Shan2nu
__________________
Old 7th June 2005, 18:53   #41 (permalink)
Samurai, if possible, try driving someone else's car (which is not supposed to feel light) and see if you feel that lightness. Many times it is more subjective, especially when you own a new vehicle.
__________________
Old 7th June 2005, 18:58   #42 (permalink)
Shan2nu's Avatar
Good point. Maybe there isn't anything wrong with the car. Maybe that's how every Baleno with stock suspenssion feels at 130.
I'd probably feel the same if i was to come down from an Acura TL to a Maruti Baleno.
But do get your allignment checked.
Shan2nu
__________________
Old 7th June 2005, 19:00   #43 (permalink)
Team-BHP Moderator
Samurai's Avatar
I got my wheels changed on the day of delivery. They only did balancing after changing the wheels/tyres and not alignment. They said alignment is not necessary since it is new car.
__________________
Samurai
Old 7th June 2005, 19:12   #44 (permalink)
Rice_tuner's Avatar
er...175!!? er...indica?? is the indica modded? if it aint...that a MAJOR speedo error we are lookin at..
__________________
1986 RD350
1998 Suzuki Shogun
2006 Honda Unicorn
2000 Suzuki Zen (carb, headers,mildly ported)
Rice_tuner is offline   Reply With Quote
Old 7th June 2005, 19:16   #45 (permalink)
Shan2nu's Avatar
What r you talking about????
Shan2nu
__________________
Thread Tools
Any cure for tyre flat spots dj_2006 Tyre & Alloy wheel Section 3 26th November 2006 18:07
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
