| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Team-BHP Moderator ![]() | Hi, I have found that while driving at extreme speeds(150-160 range) the car gets light footed. As if it has shed 500kilos. As in the steering gets exremely light. This problem is not at all there before 140. The tyres are 155/80R13. To cure this problem are wider tyres advised or a spoiler will do the trick. Also how much impact on top speed will the spoiler have. Are there any scientificaly designed spoilers available for hatches. Most of the after market stuff i have seen are cosmetic jobs with no measuments on angle and stuff. I usually run 2-3psi above manufacturer recommendation for high speeds.
__________________ .--- ..- ... - - .-- --- -- --- .-. . -.. .- -.-- ... - --- --. --- !! |
| | #3 (permalink) |
| Team-BHP Moderator ![]() | Indica does not cross 130(DLS i have). this i am talking about the Getz. At around 160 i felt as if the car had slightly lifted off. I am wondering wether the 155 width tyres are to blame or is it the aerodynamics. I am scared to drive at recommended pressures because they are the "minimum" and risk of tyre burst is high at those pressures.
| | #4 (permalink) |
| Senior - BHPian | The suspension causes this....changing the tyres wont help much in lightfootedness....but upgrade from 155s to atleast 175 for the getz...actually i didnt know the getz came with 155s. 175s will make the steering a bit heavier...which will help a little at high speeds. Drifter
__________________ Slow Everything Down And Feel Like God - Tata Safari |
| | #6 (permalink) |
| Team-BHP Moderator ![]() | The GL does! Since tyres dont help, wont a spoiler increase the downforce and help in this case. On a related note, i may be buying indigo Tdi in near future which is capable of 150kmph. Would it be useful to put in a spoiler. I have used indigo for about 1K kms, and found high speed handling to be stable at 130-140. Any other user can give me feedback regarding handling at higher speeds?
| | #7 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Just fitting a spoiler without knowing the effects of it on your car can be devastating. If your car doesn't feel comfortable at 160, then it clearly shows that it's not supposed to be driven at such speeds. Try and limit yourself to 140kmph. Thats the easiest and the safest cure i could think of. Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE | |
| | #8 (permalink) |
| BHPian Join Date: Mar 2004 Location: bangalore
| WOW you've hit speeds of 150-160 in your indicar???...super!!... sorry just read the rest of the post...still these speeds are possible on a getz..pretty good eh??
__________________ AAKGC- Activist Against Killing a Good Car Last edited by anoops : 3rd June 2005 at 12:51. |
| | #9 (permalink) | |
Therefore I really doubt if adding a spoiler to an Indica or a Gets will make things better. Apparently aero skirts make more of a difference at those speeds, but you dont want to drive in india with those.
__________________ Cheers Steer Where all think alike, no one really thinks very much. | |
| | #10 (permalink) |
| Senior - BHPian Join Date: Dec 2004 Location: pune
| @steer, at 150+, the effect may not be as drastic as 200+ speeds, but still it should be able to provide downforce to assist (or mess up) handling. Race cars would require far more downforce due to their extreme powered engines, which will not be the case with road cars. So, installing an OEM spoiler should be some help, especially for cars which oversteer.
__________________ Drive fast, but drive safe. |
| | #11 (permalink) | |
| BHPian | Quote:
hrag | |
| | #12 (permalink) |
| BANNED | try keepin a gunny bag or two in the boot if driving alone. also spoilers on almost all cars simply cosmetic. actually its only above 120kph that feather weighted sports cars do tend to lift of fthe ground .so the spoiler comes into the picture only after these speeds.thats the reason wven in some porsches the spoiler comes out only after 120kph. about the getz,simply adding a spoiler will only increase its cd figures.as itis its too heavy to be airborne. and if u feel its light at 160 the simple answer is "dont drive at 160".its not all meant to be driven at those speeds.a limit of 120 kph on our roads is more than enough. |
| | #13 (permalink) |
| Newbie Join Date: Jan 2005 Location: mumbai
| guys i have done 175kmph in my indica petrol (lsi) of course with 175/60/13R rubbers and even at that speed the car felt rock solid .............. the car is very stable at any speed and at any condition that to with out any spoiler or anything................ |
| | #14 (permalink) | |
| Team-BHP Moderator ![]() | Quote:
. I too think 120-130 is the limit for expressway!
__________________ .--- ..- ... - - .-- --- -- --- .-. . -.. .- -.-- ... - --- --. --- !! | |
| | #15 (permalink) |
| BHPian | I am sure the spoilers are more to do with cosmetics than downforce on these hatches although cant say there wont be any effect at all at speeds lower than 200... Mostly the spoilers will help grip the road better while taking fast turns rather than at top speed runs on a straight... anupam9055 : are you sure you did 175 in your car ? has it been modded at all? since it is good for abt 155 (maybe 165 on the speedo) also all Indicas (Petrol) have a spoiler......as far as I know but agree that the car is very solid at speeds upto 120/125 (my personal max upto now) |
| Thread Tools | |
Similar Threads | ||||
| Any cure for tyre flat spots | dj_2006 | Tyre & Alloy wheel Section | 3 | 26th November 2006 18:07 |
