Old 28th January 2013, 22:25   #256
Thanked: 21 Times
Default Re: Tips on driving an automatic
Hi All, Its a standard practice in all Automatics to press the Brake and then shift from N to D & visa versa, or N to R & visa versa. I want to know whether, Brake is pressed only to prevent the car from creeping forward / reverse or does the Brake engage some sort of a clutch inside to remove load from the transmission box during the shift? Another way to ask the same question is that is it safe for the tranny box to shift from N to D without using Brake if the way ahead is absolutely clear. Similarly, is it safe for the tranny box to be shifted from D to N while coasting (say approaching red light 15-20 meters away). I just bought an Altis Automatic and am driving an AT for the first time. Since you have been driving them for years and are an Engineer too, I thought you might be able to answer me satisfactorily.
anujatwork is offline   Reply With Quote
Old 29th January 2013, 00:09   #257
echo77's Avatar
Thanked: 33 Times
Brake does not engage any "clutch" because there is no clutch. You can go from N to D or D to N or N to R without brake.
N to R in some automatics will have a lock button on the gearshift that needs to be pressed (for eg honda city), which is usually to prevent accidental shift to R.
echo77 is offline   Reply With Quote
Old 29th January 2013, 00:23   #258
manim's Avatar
Thanked: 396 Times
Post Re: Tips on driving an automatic
I do these at times, modern AT's are electronically controlled so they should be safe.
manim is offline   Reply With Quote
Old 29th January 2013, 00:30   #259
Akshay1234's Avatar
Thanked: 7,243 Times
The brake is like a secondary lock, besides the button on the knob which most cars have. Its to prevent any surprises and sudden jerks. You should press the brakes which shifting from N to D or R, you can try without but there will be a jerk.
If a signal is just ahead then take your foot of the accel and see the revvs drop to almost an idle, it is almost as good as coasting. Incase you have to move ahead and you are coasting in N you will have to come to a near stop to engage D.
Do remember to put it into N at signals longer than 20 seconds.
Old 29th January 2013, 12:36   #260
Thanked: 21 Times
Toyota Corolla Altis does not have button on the knob. Instead, it has zig zag slit to move the Stick.
You are right, there is a nudge but I got your point. I only wanted to be sure that there will no damage to hardware inside if I 'shift' without using the brake.
Old 29th January 2013, 13:39   #261
echo77's Avatar
Thanked: 33 Times
There is no hardware damage to car, even if you were accelerating. My kid once accidentally hit D to N and the car just revved up in neutral. There was no noticeable jerk.
Old 29th January 2013, 13:43   #262
msaudf's Avatar
Thanked: 152 Times
I haven't noticed this scenario in any of the auto transmission cars I've used, if we shift back to D from N when the car is moving forward at a reasonable speed of say 40 or 50 km/h, the transmission simply shifts back to the gear of the appropriate speed (mostly 4th) and moves on.
The auto transmissions I've used are mid 90's Toyota's and Mitsubishi's of the same era, oh and a 93 Mercedes 300D.
The reason i think it was OK to do so is because the shift lever were restricted by some kind of mechanism that only released if the brake pedal was pressed and this restriction mostly comes into play while shifting to R from N, shifting from P to any position and shifting from 2 or L or D2 to D1 and ofcourse shifting to P
I could have been handling those cars wrongly as i have not read the user manuals of the said cars as we bought them second hand and they never came with the said manuals.
msaudf is offline   Reply With Quote
Old 29th January 2013, 13:56   #263
Akshay1234's Avatar
The jerk is there from N to D or N to R if your foot is not on the brake. That too if your car lets to shift without your foot on the brake.
Well yes that does happen, now I am no engineer but from what I understand it does put more stress on the transmission. I would rather not make a habit out of that and only do it if its needed.
Old 29th January 2013, 13:58   #264
echo77's Avatar
Thanked: 33 Times
When its a fluid coupling, gear# depends on the speed of the rotating fluid...
echo77 is offline   (1) Thanks Reply With Quote
Old 29th January 2013, 14:19   #265
msaudf's Avatar
Thanked: 152 Times
Thanks echo77, so will CVT's and DSG's or other modern automatics behave differently or get damaged of shifted into D from N while moving at some speed?
Old 29th January 2013, 14:25   #266
echo77's Avatar
Thanked: 33 Times
Sorry, I don't know the details of CVT or DSG.
Old 29th January 2013, 17:52   #267
Thanked: 9,025 Times
The jerk is there from N to D or N to R if your foot is not on the brake. That too if your car lets to shift without your foot on the brake..
Really depends on the car. On my Jaguar XJR I can go from N to D without my foot on the brake without any jerk. It just goes from standstill to slightly creeping in one fluid motion. I assume it's a combination of a lot of torque and a very sublime auto box.
And the XJR drives at quite a steady pace when just idling in D. Unless you engage Sportsmode it will pull away in second gear! Still, no jerks!
Jeroen
Jeroen is offline   Reply With Quote
Old 29th January 2013, 18:34   #268
Thanked: 548 Times
Can you elaborate this point?
Guna is offline   Reply With Quote
Old 29th January 2013, 19:08   #269
echo77's Avatar
Thanked: 33 Times
IIRC there is something called speed governor and it depends on the rotating speed at the load (output)
http://en.wikipedia.org/wiki/Fluid_coupling
http://en.wikipedia.org/wiki/Torque_convaerter
Old 29th January 2013, 20:04   #270
Akshay1234's Avatar
Jeroen
Of course there is no hard or fast rule about the jerk, but then again we are talking about a Corolla while your car is a Jyaguar. Again I guess it depends from gearbox to gearbox, but in India I would say its better to keep your foot on D rather than have your car go slightly forward even by mistake considering the cars here are inches apart.
Driving in India after driving outside (abroad) - tips to avoid common mistakes mmxylorider Drive Safe 24 9th October 2014 20:06
The Driving Tips Thread normally_crazy Drive Safe 43 17th September 2011 21:49
Tips to drive better: But are the tips correct? Spinnerr Technical Stuff 11 22nd June 2009 13:00
Driving Tips.. karthik247 Technical Stuff 3 17th April 2005 16:32
INFO : Tips on driving in Fog Technocrat The Indian Car Scene 2 1st February 2005 10:19
