Old 4th June 2005, 11:19   #1
Rodeo's Avatar
Thanked: 21 Times
Question Palio 1.9D Fuel injection problem
I hv been facing a problem with my Palio diesel... When i try to start the car i get Fuel injection pump light... and if i start the car with the light on then my car accelerates and decelerates on its on.... If i switch off and restart my car the light goes off and my car runs smoothly...
Any idea what wrong...
Thanks...
Rodeo is offline   Reply With Quote
Old 4th June 2005, 22:48   #2
moralfibre's Avatar
Thanked: 6,533 Times
Arrow
I feel it is due to bad quality Diesel in the pump... if the Diesel Pump (Made by Bosch) is dead then get ready to spare around 60k to replace it if the car is not under warranty.. the part is called FYP by Mechanical engineers...! an ECU reset MIGHT work!!.. There was a cure to this fault from Fiat.. I will consult a friend of mine and let you know..!
Old 4th June 2005, 23:53   #3
Mpower's Avatar
Thanked: 1,687 Times
Sounds like an electrical glitch to me. Tell them to reflash the ECU.
Old 5th June 2005, 10:25   #4
Rodeo's Avatar
Thanked: 21 Times
Once the light goes off after a restart then i do not face any problem so i doubt if there is a problem with Diesel pump...
Old 5th June 2005, 12:11   #5
nitrous's Avatar
Thanked: 285 Times
Check engine electricals and ECU. and see if the problem persists.
btw, 60k for a diesel pump. I'm never gonna look at the Fiat showroom anymore
Old 8th June 2005, 15:16   #6
Rodeo's Avatar
Thanked: 21 Times
Had taken the car to the service centre... They hv confirmed the problem is with fuel pump and it will be replaced by the company and the stock will only come after 2 months... Some 70 cars have faced the same problem...
I dont understand one thing why cant they get the stock of fuel pump when they know lot of people are facing the problem... I dont think fiat can ever improve...
Old 8th June 2005, 15:22   #7
Thanked: 1,642 Times
Fuel Pump replacement! How old is your car, dude?
Steeroid is offline   Reply With Quote
Old 8th June 2005, 15:24   #8
hasopi's Avatar
The culprit here is bad diesel which we get..In India...one more reason why manufacturers think twice before putting up a CRDi engine!
Its gud that FIAT said they will replace..they are improving!
hasopi is offline   Reply With Quote
Old 8th June 2005, 15:25   #9
satish_appasani's Avatar
Thanked: 45 Times
There is an issue with fuel pump in Palio D, I think they were all early models. One of my friend who bough a used car had this problem and the dealer replaced it free of cost. My Palio D has yet did not show up this problem.
satish_appasani is offline   Reply With Quote
Old 8th June 2005, 15:29   #10
Rodeo's Avatar
Thanked: 21 Times
My car is around 18months old... done just 24000 kms... I only use Speed Diesel or Shakti diesel...
Old 8th June 2005, 15:39   #11
Rodeo's Avatar
Thanked: 21 Times
I dont see any Good service?? They are going to take 2 months to replace the fuel pump and i will have to pay Rs 750 out of my pocket... And during this time i cant even give my car in Valet parking...
Old 30th June 2005, 14:55   #12
Rodeo's Avatar
Thanked: 21 Times
Is there a email ID for fiat's customer care whom i can contact and speed up the process..
Old 30th June 2005, 19:21   #13
Its been 22 days since your last post and you still dont have a solution? Try the consumer court for what its worth - I'm not sure how long it takes to get any sort of redressal, though.
Old 30th June 2005, 20:20   #14
Rodeo's Avatar
Thanked: 21 Times
I dont understand why they need 2 months to source diesel pump...
Old 30th June 2005, 20:23   #15
Did you contact Satish Appasani who is also in Hyderabad and who says they replaced the fuel pump of a 2nd hand car free of cost?
Fuel Injection for India bikes? turbo_v12 Motorbikes 15 28th May 2009 16:08
Bajaj Auto is going for fuel injection RoaringEngine Motorbikes 8 22nd May 2006 19:59
Does Fuel Injection really give that much of an advantage? Steeroid Technical Stuff 48 8th May 2006 21:59
Pre Fuel injection treatment by Electronic Convertor for Diesel and Petrol Suryam Technical Stuff 0 1st February 2005 11:39
Tuned port fuel injection kakx Technical Stuff 4 17th April 2004 14:37
