Old 19th May 2009, 18:01   #16
mclaren1885's Avatar
Thanked: 28 Times
Infractions: 0/1 (10)
Yes, Mohit it is for both fronts. Looks like even Riju has confirmed this now.
Old 19th May 2009, 18:39   #17
crazydiablo's Avatar
Thanked: 21 Times
Cool, I need a set for the other car.
crazydiablo is offline   Reply With Quote
Old 19th May 2009, 20:49   #18
shadyrulez's Avatar
Originally Posted by WhiteKnight View Post
Buddy, are you on your first set of tyres? What is the condition of those? The skidding could be due to old worn out tyres.
I changed my tyres just a month back. Got the Potenza g2 or 3 not sure the unidirectional threaded tyre
And thanks for informing me the price of the brake. I will try reaching another service center and find out the pricing and stuff...
Does the back brakes also need a change ????
shadyrulez is offline   Reply With Quote
Old 19th May 2009, 20:58   #19
Thanked: 21 Times
Advisable to change the rear brake liners also. Should not cost much.
Old 19th May 2009, 21:33   #20
kaushik_s's Avatar
Thanked: 148 Times
Does Baleno brakes bite less than that of Swift? My car atleast feels so and so I was thinking that probably it's like this for a Baleno. I always feel that the bite is less in my car specially while driving fast and there is need for sudden braking. But it does slow down although confident level is not that high during those moments.
Another thing I felt that the braking efficiency actually decreased after the change of tires from the stock ones (currently using yokohama S-drives). But this may be just in mind as I was expecting better braking performance after the change.
BTW, the price of the front brake pads were around 1249 Rs with labor charges along with a door clip.
kaushik_s is offline   Reply With Quote
Old 19th May 2009, 22:15   #21
shadyrulez's Avatar
Guess i will go down to some other Service center and talk to them regarding this.
Are the brake pads and lining readly available.
Cause when i enquired they many people said they are out of stock.
Old 20th May 2009, 17:55   #22
Thanked: 21 Times
Readily available in bangalore. Its not a slow moving item so they should have it in stock.
Kaushik:The bite or sharpness of brake is more in a swift. Must be the booster design. If the bite has gone down, time to look at your pads.
Old 20th May 2009, 20:03   #23
kaushik_s's Avatar
Thanked: 148 Times
Pads are very new, probably now it's only 5k old. I'm kind of suspecting the boosters for this. BTW, I'm having another problem with the brakes, have a look at this thread guys, http://www.team-bhp.com/forum/techni...low-speed.html
Old 27th May 2009, 18:17   #24
shadyrulez's Avatar
Thanks guys for all the help provided on the thread.
Got my brake pads changed. Bite of the brakes have improved.
Got them for 2500rs in ABT chennai. Then a full car service. The car feels way better than before now.
Thank you guys
Old 27th May 2009, 21:36   #25
kaushik_s's Avatar
Thanked: 148 Times
2500 Rs is double the price, how come a MASS charging double for a OEM part? Is this with a proper bill?
Old 28th May 2009, 16:29   #26
shadyrulez's Avatar
Yup thats what they charged me. To be more accurate it cost me Rs2359.11
Atleast these guys had the pad with them....
Old 29th May 2009, 12:16   #27
Thanked: 21 Times
I dont know why such a difference in price. Maybe its old stock and they are charging the old MRP.
Old 30th May 2009, 03:14   #28
v1p3r's Avatar
Thanked: 26 Times
Must be SGP vs MGP pricing.
Old 4th June 2009, 16:46   #29
Awaiting Email Confirmation
Changed the front break pads from mandovi bangalore, it came around Rs 2700 , it is an SGP item. They told that theu don't have an MGP part for baleno. The package date for the item showed Jan 2009.
nisam76 is offline   Reply With Quote
Old 21st June 2009, 09:50   #30
kailashnj's Avatar
Thanked: 275 Times
Hi Guys.
My baleno,s front brake pads have worn out and need to be changed. I had been to a Maruti Service Centre yesterday and they said the charges for the Baleno brake pads are 2700 for the SGP. I asked them if they have any MGP available the answer was negative. I read this thread before and many confirming the price to be around 1300bucks I did not change the pads. Can anyone from Mumbai please confirm the prices for the Baleno brakes and also where can I procure them.
Are there any aftermarket brake pads which would also improve the brake bite would be welcome too.
Kailash
kailashnj is offline   Reply With Quote
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
Baleno BS-III to Baleno BS-II BlackBull Technical Stuff 0 22nd September 2006 21:50
How to improve brakes in baleno? RoaringEngine Technical Stuff 22 21st May 2006 16:45
